Samsung 912N Problem
  • LAS
    • Sep 2011
    • 144
    Re: Samsung 912N Problem
    A quick update on my 912N project...I replaced the dual channel mosfet on the logic card this weekend, and it is still not working properly. The problem persists in that, with no pc connected, I get a steady green indicator light, and the 'Check Signal' box moves around the screen freely and does not turn off, albeit the box does not appear uniform (see photo above) but then once I attach the pc video source, using several different cables, the video goes completely dark. The difference is now, since replacing the mosfet on the video card, I can get the Check Signal box to appear for a few seconds first.
    I'm thinking that on the inverter board, there is a mosfet hidden on the underside of a smaller circuit board. Hopefully tonight I can post photos of the inverter board, and at that time I would like to ask the group if they recommend me to remove the little attached circuit card and test the mosfet under it.
    Thanks as always.
      You may want to check the BL_ON signal line to see if it changes when you have the monitor connected to the PC, I have a feeeling that the BL_ON changes when the PC is connected.
      • LAS
        • Sep 2011
        • 144
        Hi Budm,
        Thank you for the schematic diagrams. I have printed them out and taken a look but was unable to find reference to BL_ON. I did, however, see BL_EN on a few of the pages.
        This is my first time reviewing schematics for this monitor; could you offer me some guidance on how to locate what I am looking for? And then I can give it a try this evening, once I'm home from work.
        On another subject, I am in the final stages of assembling my Blue ESR meter. It was a lot of fun and my seven year old was an eager helper. Maybe he will take it to science class and impress his friends.
        Thanks all once again.
          BL_EN is the one. See if you do have CN600 on the logic board, then see if the connector CN600 PIN9 has voltage reading, RED PROBE on pin 9, black probe on the chassis. Turn on the monitor without hooking up to pc so you cane see "CHECK SIGNAL" and read the DC voltage, then hook it up to PC and see the voltage again.
          Service manual: http://elektrotanya.com/samsung_510n.../download.html
          • LAS
            • Sep 2011
            • 144
            Very helpful Budm. I will check this tonight, and report back shortly thereafter.
            • LAS
              • Sep 2011
              • 144
              Hi Budm,
              My logic board has no CN600...I took a look upthread at #22 where I posted a photo last week. It would have been right under the top left white multipin connector. Can BL_EN be checked some other way?
              • LAS
                • Sep 2011
                • 144
                I'll check Q600 right next to it for shorts. I missed that one while looking it over.
                  We are looking for the HI-LO signal on this pin, if it changes when the monitor gets the video signal from the PC, then it is not the inverter circuits problem, it is just some how being told to turn off the backlights when the monitor gets the video signal, se we want to verify if that is the case.
                  • jetadm123
                    • 2169
                    #49
                    Originally posted by LAS
                    Hi Budm,
                    Looking at the schematic that budm supplied, you should be able to monitor BL_EN at the collector pin of transistor Q601. The collector pin is the side of the transistor with one leg coming out of it. Q601 is located directly below the white 9-pin connector on the logic board.
                    • LAS
                      • Sep 2011
                      • 144
                      Thank you jetadm123. I have identified Q601 on the logic board, and I will test the one leg for hi / low and I will also test across the transistor for any shorts.
                      I have also found it on the schematic.
                      • LAS
                        • Sep 2011
                        • 144
                        Budm and jetadm123,
                        When the monitor is turned on, with no video cable attached, the Q601 pin which is on a side by itself (I am thinking the is the base, not the collector, yes?) I get 3.7v. When I plug in the video cable, it goes to zero. If I unplug the cable and give it a few seconds, the backlights come back on and the pin goes back to 3.7v.
                        The transistor does not appear to be shorted out.
                        • jetadm123
                          • 2169
                          #52
                          I suggested the collector because it's tied directly to the 9-pin connector. However, I see what you did. You measured the BL_EN voltage at the base, which is tied directly to the output of IC200, which is acceptable. It looks like the backlight is responding to the on/off commands. Sounds almost like the logic board can't handle the load when you plug in the video cable. Looking at the wiring diagram of the 9-pin connector, each pin has a voltage or ground associated with it. 14V, 5V. BL_EN, etc. I suggest you measure the voltage on every pin before you plug in the cable and again after you plug in the cable.
                            He measured at the Collector (PIN 9 of the connector) which is correct. If you have the 2 pins pointing toward you, the left pin is Base, the right pin is Emitter. The Collector has pull up resistor (R604, 10k), the transistor (NPN) is normally off which makes the Collect goes HI, when the controller send the positive signal to the Base, the transistor will turn on so the Collector voltage will go low.
                            That is, the BL_ON command output to the Base of Q601. So some how the controller chip tells the inverter to turn off when it gets the Video signal! The middle pin is Collector.
                            BL_EN HI = INVERTER OFF, Q601 turns ON, cOLLECTOR goes LO.
                            BL_EN LO = INVERTER ON, Q601 turns OFF, Collector goes HI.
                            You can force the Inverter to be on by connecting Base to Emitter.
                            See attached PDF for the transistor Q601, 2SC2412.
                            You will have to start checking the output of the voltage regulators, I see 3.3v, 2.5v, etc.
                            • jetadm123
                              • 2169
                              #54
                              While looking at your logic board photo, I noticed it had a Novatek controller, NT68F63L, which jarred my memory. Apparently, your logic board was also used on the 913N, which also had problems similar to yours:
                              https://www.badcaps.net/forum/showth...light=nt68f63l
                              Seems like this controller goes bad over time and the fix is to replace it and reload it's firmware. From what I can see, the success for this repair was pretty low.
                                Ah, that what I remember now! I know I see the symptom on other model before on this site, thanks for finding it, jetadm123.
                                • LAS
                                  • Sep 2011
                                  • 144
                                  Well, the good news is that the monitor was given to me, and while I did change the caps, they can always be taken out and used elsewhere. Alternatively, the day may come when I come across another 912N and I can create my own 'Frankenstein' version out of the spare parts.
                                  And the other good news is that my Blue ESR meter went together smoothly, and it's now complete. So I save these monitor parts for another day, and another monitor, and in the meantime I thank you all for your perserverence, help and extensive memories and experience.
                                  LAS.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #57
                                    $4 for an empty one, but then it needs to be programmed and the soldering looks a bit intimdating.
                                    http://www.ebay.com/itm/270825016266
                                    Well, it looks like you have some spare ccfls now to use for testing.
                                    --- begin sig file ---
                                    --- end sig file ---
                                    • LAS
                                      • Sep 2011
                                      • 144
                                      Retiredcaps, I'm ok with the $4 and I'm ok with the soldering, but the reprogramming - any special equipment required?
                                      LAS.
                                      • jetadm123
                                        • 2169
                                        #59
                                        LAS.
                                        On the link I supplied above, check out post #56. Gonzo0815 gives a rough idea of what hardware/software to use.
                                        • LAS
                                          • Sep 2011
                                          • 144
                                          Can anyone tell me if the login card on the 712N is the same as in the 912N? If so, I may be able to aquire one for a nominal amount.
