Hp 2159M Bad display
  • Mr Bill
    • Nov 2011
    • 648
    The main 4A fuse was blown when i got this monitor. Changed out the fuse and this is what i see. I checked the fuse on the t-con and it measures 0.3ohm. The main board is full of capxon caps. Can a bad cap cause a display like this or am i looking at a failing lcd panel? I ordered a Peak Atlas 70 ESR meter on monday so when i get it i can check the capacitance and esr of the caps on the main board.
    Just seeing if anybody has had any similar situations.
    Edit:
    I did clean and reconnect the 30 pin cable going from the main board to the screen
  • jetadm123
    • 2169
    Re: Hp 2159M Bad display
    Could be caps. However, I suggest you try measuring the output of the voltage regulator, U201 (located right side middle of board). Use a mounting screw for your ground probe and measure voltage at each pin.
    • retiredcaps
      • Apr 2010
      • 9271
      1) If you bring up the on screen menu, does it shows the same problem?
      2) On the main board, there are two voltage regulators U201 and U202. They look like they have been replaced by someone because the tab doesn't fit the pcb silkscreen?
      3) You should check U201 and U202 to see if they are outputting the correct voltage as well. It looks like U201 is a 3.3 and I can't make out U202 despite the excellent photo.
      4) And yes, Capxon makes crap caps.
      5) jetadm123 beat me re the U201, but not the U202!
      --- begin sig file ---
      --- end sig file ---
      • jetadm123
        • 2169
        Good catch!
        • Mr Bill
          • Nov 2011
          • 648
          Here are my results...
          If i pull up the menu it looks nasty too.
          The 2 voltage regulators (U201, U202) are part # AX1117, i uploaded the datasheet for you. Using the ground pin here are my results.
          U201
          V-in 3.301 volts
          V-out 5.15 volts
          U202
          V-in 3.575 volts
          V-out 1.796 volts
          Both are the same part number. I also got the same readings using the ground pin on the connector coming from the power board.
          • Mr Bill
            • Nov 2011
            • 648
            Well...............
            I went to turn my test computer off and now the display is perfect..
            When i did the readings i taped cardboard to the back of the screen and then the power and main boards were taped to the cardboard. When i stood the monitor up to power off the computer the monitor slid a little bit on top of my tower. When i caught it my fingers "bumped" the vga d-sub connector.
            And here we are.
            I'm wondering if the vga cable i was using has a loose connection in it. I used a different cable and i'm pulling, wiggle, slapping and i'm not getting the crappy display now. I'm going to try the "suspect" vga cable on a known good monitor tomorow and see if i get the same results.
            • Mr Bill
              • Nov 2011
              • 648
              UPDATE
              Its not the vga cable. Just messing around with the resolution it would go from good to bad then back to good. I'm thinking its in the mainboard itself.
              The 2 voltage regulators are actually 2 different parts. (reading the entire datasheet helps )
              U201 is the 3.3 volt out with a 4.8 volt input. I'm getting 5.15 volt in and 3.301 out.
              U202 is 1.8 volt output with a 3.3 volt input. I'm getting 3.575 in and 1.796 out.
              On both regulators i'm right in tolerance for the output but a little high on the input. I'm not sure if the .275 to .350 volt difference would define it as bad. It seems that if i turn the monitor on and off several times thats when it goes bad then back to good. So if i ever get my esr meter i'm going to start checking the capxon caps that are on the mainboard. If i find even 1 bad cap i'm just going to recap the entire mainboard.
              • Scenic
                o.O
                • Sep 2007
                • 2642
                Check each of those regulators (output voltage) when the image is messed up. One of them might be on its way out, but sometimes working normally.
                I've seen that happen before. In my case, the 1.8V regulator for the main controller IC sometimes dipped down by 0.2V on the output, causing all kinds of glitchy-ness..
                • sabre504
                  • May 2010
                  • 449
                  • United Kingdom
                  Hi had the same with a regulator on a board ok when cold on startup till you turned it off then no joy till you pushed down on it .
                  I assumed that the pressure helped make the connection but this was cured by replacing
                  • Mr Bill
                    • Nov 2011
                    • 648
                    I checked the outputs of the voltage regulators with the display distorted and i'm still getting 1.796v and 3.301v.
                    I did check every capxon cap in the main board and all of them had an esr of less than 1 ohm. I also checked the 5v going to the t-con from the main board on the lvds cable and i'm getting 5.04v. I then checked the fuse on the t-con and it measured 0.001 ohm with 4.97v going through it with the monitor on.
                    Now there apears to be 2 (maybe) mosfets that may drive the lcd panel (Q3 & Q4). On Q4 Putting my black probe on pin 7 of the lvds cable (ground), i'm getting 4.99v, 12.49v, 4.92v
                    And on Q3 i'm getting 4.92v, 0.000, 4.98v
                    I don't know if the missing 12 volts from Q3 could be my problem, i tried checking for shorts but i'm getting well over 30 ohms. The side of the tcon that these 2 mosfets are on is the more distorted side of the monitor.
                    The part numbers are
                    Q3
                    81 Y917
                    Q4
                    92 Y914
                    I tried finding a datasheet but i'm coming up empty.
                    • nickgronk
                      64PN5500 | BN44-00618A Main fuse keeps popping
                      by nickgronk
                      Power supply board BN44-00618A keeps blowing main fuse and nothing plugged in to it.
                      I was gifted a 64PN5500AF, picture was amazing, but tv smelled like cigarettes and was dusty AF. I opened it up, blew all the dust out of it, removed PSB & main, and cleaned the metal underneath. Also blew all the dust off all other boards. Put the power supply back in, then mainboard. Soon as I turned it on there was a "pop".
                      The main fuse (T12AH250V) blew
                      I removed the power supply to be sure nothing underneath, all good. Soldered on a t12ah250v fuse and sure enough it popped...
                      01-22-2022, 10:43 PM
                    • dimis7
                      LG 37LS5600 blows main fuse
                      by dimis7
                      Need some advice to troubleshoot this TV.
                      PSU blow the main fuse F100, 3.15A.
                      I replace the fuse with another 3A (but not ceramic) and blows it again after few seconds when i plugged in to the wall, with nothing connected to PSU, just the power cord.
                      I checked with DMM for dead sorts but didn't found any.
                      Checked bridge rectifier and seems ok.
                      Also check main filter cap with transistor / cap / esr tester (the usual cheap transistor testers from ebay) and found ok.
                      PSU p/n is EAX64405901 (1.6)...
                      10-28-2022, 05:15 AM
                    • cheeky2
                      by cheeky2
                      05-25-2024, 03:27 AM
                    • Dani_2024
                      by Dani_2024
                      10-28-2024, 05:06 PM
                    • ygorsan
                      by ygorsan
                      🧩 Problem Summary:
                      • I
                      Yesterday, 08:34 AM
