Samsung Syncmaster 203b no back light after cap replacement
  • starmaxpc
    • Oct 2009
    • 117
    i picked this item up locally for free. when i first plugged in to see whats happening, the blue power light blinked on and off continuously and no display no image dead! took item apart and found 3 bulged caps. 3 x 820uf/25 volt replaced with spares i had 3 x 1000uf / 25 volt. item back together now blue power light powers on stays on NO back light. i can see image with flash light. there is no 2 seconds to dark when powered on no back light activity. directions??
  • starmaxpc
    • Oct 2009
    • 117
    Re: Samsung Syncmaster 203b no back light after cap replacement
    not sure what happened to that photo upload?
    • retiredcaps
      • Apr 2010
      • 9271
      Originally posted by starmaxpc
      NO back light.
      1) Check fuse F301. A good fuse should measure less than 1.0 ohms.
      2) Check the 2 mosfets that are sandwiched in between the two transformers for shorts.
      --- begin sig file ---
      --- end sig file ---
      • jetadm123
        • 2169
        Your photo's a little blurry, but try checking the fuse, PF301? It's the green fuse between the heatsink and the inverter transformer on the left side of your photo.
        retiredcaps already beat me to it!
        • starmaxpc
          • Oct 2009
          • 117
          Thanks gentlemen!! the fuse was bad. it is now working good!!
          • pr0cess0r
            • Jan 2011
            • 110
            Thx i fixed 2 of those screen with 4 bad caps and bad fuse!!
              Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
              by sam_sam_sam
              This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
              I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
              I am comparing them to a brand new one that I installed
              The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
              I going to let it run for several days before I remount back on the wall next to the...
              09-05-2024, 06:48 PM
            • PNI E.
              tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
              by PNI E.
              hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
              02-20-2025, 08:36 AM
            • koby058
              vostro comes up with back light but no picture
              by koby058
              Hi people!!
              The owner said it showed bad picture once in a while (attached)
              I see that there is back light but no picture.
              I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
              Also attached schematic and BDV
              LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
              07-13-2025, 01:03 PM
            • Green Probe
              Recapping a Denon AVR X6400h SMPS
              by Green Probe
              (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
              Disclaimer: I'm an amateur hobbyist and will get things wrong.
              Always use caution when working around mains power and high voltage capacitors!
              Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
              SYMPTOMS:
              -No display...
              07-18-2025, 03:36 PM
