Re: Fujitsu-Siemens L22-1W - PI-190DTLB board (2 sec to black)
Well you will need a set to substitute,perhaps you have a recycle centre/tip where you could get a old monitor and take out a set,or the other alternative is :- https://www.badcaps.net/forum/showth...ght=test+lamps
My tests backlight:
When I connect the first tube to a source of voltage lights. OK first tube. Monitor goes into standby mode.
When I connect a second tube, also lights up. The second tube OK. A monitor goes into standby mode.
But when I connect both tubes and the green LED lights. Then the LED turns off.
Confusion !!!! What Tube to what voltage ????? The Monitor has 2 tubes at the top and 2 at the bottom,if any 1 fails then the monitor will not work.Normally backlights come mounted in a metal channel in pairs.All four sockets on the Board have to have lamps fitted (original OR test ones), to test.
Hi Sabre504
I have a Fujitsu/Siemens Monitor L22-1W that died after being unplugged from the mains.
No way to switch it on again. Followed your capacitor replacement suggestion and it worked perfectly after that. The P.S board look just like the one in the photo in your thread, a bit black around the MOSFETs but did not need to replace them.
Thanks for your help. Really appreciated.
