Two Samsung Monitors with same model # same caps that pop there top
    • Jul 2011
    • 6037
    My boss ask me to look at two monitor with same model with the same power boards and video control board the same four caps that pop there tops
    The blue LED power light was the only thing that would work or come on
    So I open them up to see what had happen to them and this is what I found .....>
    Two caps in the inverter part of the board
    Two caps in the power supply part of the board
    I ordered the caps to recap the board except the main power cap
    The pic fuse that powers the inverter part of the board are blowen
    All parts for both Monitors from Digikey $14.00 plus $5.80 for shipping
    1000 uf @ 16 volts * pop top
    820 uf @ 25 volts * pop top
    330 uf @ 16 volts
    47 uf @ 50 volts
    10 uf @ 50 volts
    I will post some photo later with model #
  • tama4tama
    • Nov 2006
    • 56
    Re: Two Samsung Monitors with same model # same caps that pop there top
    Go ahead and changer all the bad caps and the fuse and let us know the out came.
    Good lucky.
      • Jul 2011
      • 6037
      I recap these two boards.......>
      With the fuse for the inverter in place NO blue LED Light
      With the fuse removed the blue LED lights on both boards
      later to day or in next few days I post some photo of this board
      • PlainBill
        • Feb 2009
        • 7034
        There are shorted drivers (transistors, ICs) in the inverter.
        PlainBill
          • Jul 2011
          • 6037
          Here are some photo of this board
          The two small sim chip
          Has a part # of STM8309
          Where the two cap are for the inverter across both cap I have a short which trace back to the output of the STM8309 which is a dual mosfet
          I found ten of the on Ebay for $18.00 and free shipping but from Hong Kong which will take about a month
          PlainBill
          Thanks for the info
          I did not have time at work to check any thing else after changing the four caps
          My boss told me to take them home and see what I could with them because a new one would cost $150.00 for this size
          • Scenic
            o.O
            • Sep 2007
            • 2642
            Just curious.. What model monitor is it?
            Might also help others to find this thread..
            Also:
            http://www.ebay.com/itm/320846018196
            http://www.ebay.com/itm/390166221090
              • Jul 2011
              • 6037
              I put the model later on
              Here is where I found 10@ $18.00
              http://www.ebay.com/itm/150658624891...84.m1423.l2649
              One note I did fix the two not so good soldiering joint that did not look so good
              • Scenic
                o.O
                • Sep 2007
                • 2642
                Oops.. I forgot you had 2 monitors.. ignore the ebay links I posted
                • mockingbird
                  • Dec 2008
                  • 5484
                  That looks like it came out of a Samsung 2053BW...
                  I just repaired one of those PSUs for like $5. That's not your PSU right? Someone already put Panasonic caps on that one. Mine had all Samwha. None of them were bloated, but after changing the caps, the screen worked perfectly (The symptom was that it was saying no input signal when connected).
                  • PlainBill
                    • Feb 2009
                    • 7034
                    The equivalent part is available from Digi-Key as either their part number SP8M5TBCT-ND ($1.30 ea) or SH8M5TB1CT-ND ($1.77 ea). They have different package designations, I'm not clear on the difference. I suspect either would work, but suggest calling Digi-Key to get an expert opinion. Specify USPS First class shipping. And both should be replaced on each monitor.
                    One other point - your communications skills leave a little to be desired, but your troubleshooting skills were first rate.
                    PlainBill
                      • Jul 2011
                      • 6037
                      PlainBill
                      I try to use the same part # if I can and I am not in any hurry any way
                      On your ...> "One other point" I have never been a very good speller or writer
                      I just do the best I can
                      I have been trouble shooting many different type equipment for many year
                      Thanks for the complement
                        • Jul 2011
                        • 6037
                        I put the Panasonic caps on this board and a new fuse
                          • Jul 2011
                          • 6037
                          No it is Samsung 2253BW
                          Note I order the STM8309 from that EBay seller that I post the link to I should get them the first part of March these parts are coming from Hong Kong
                            • Jul 2011
                            • 6037
                            Up-Date
                            Samsung 2253BW
                            Well the parts came in today I put them in both board
                            The bad new is one of the board has the 2 second ON then OFF
                            When I first got these monitors they where for the most part DEAD except for the blue power LED light so I open both of them up found four pop the top cap so I recap both board and both the power LED would not come ON
                            Then I remove one lead of the fuse to the inverter part of the board then the Blue power came back on so I check for short starting at the two caps next to the tiny mosfet chip and found both of them shorted
                            So today I replaced the tiny mosfets on both boards this was real fun now I have the 2 second ON then OFF
                            So I check the connector that goes from one board to the other board
                            There is one mark 3.3 volts this one reads 3.4 volts when back light is ON the same when OFF
                            There is one mark 5.0 volts this one reads 5.5 volts when back lights ON the same when OFF
                            There is one mark 13.0 volts this one reads 13.5 volts when back light is ON BUT when back light is OFF it reads 14.99 to 15.05 this seem not to be right
                            When the back light come ON it only lights up 3/4 of it from right to left the left side is a lot darker than the the right side
                            I know that the CFL tube are good on both monitor because other board will work both monitor
                            What should I check next
                              So far 14 down the thread and you still did not give us the model number to look up for more info. Any reason why?
                                • Jul 2011
                                • 6037
                                They are both a Samsung 2253BW
                                I put it in post 13
                                  Sorry, I thought it said no it is not 2253w.
                                  OK when the lamps are not fully lit, it can be caused by not enough high output voltage from the transformers due to 1) low power supply DC voltage, but you are getting about 13vdc which is about right since the two caps in the inverter are rated at 25vdc. 2) The inverter out put circuits is setup as a bridge type (4 MOSFET's 2 in each IC), the center output is connected to the primary winding of the transformers which are connected in series and another end of the winding is connected to the two coupling capacitors to ground, so check those two caps. 3) leaky small ballast caps (small blue caps on the output side of the transformers, more likely to be about 10~18pf 10kV, check them out.
                                  Luckily you have two identical monitors to look at and can compare some reading. The green fuse read less than one Ohm?
                                    • Jul 2011
                                    • 6037
                                    budm
                                    Thanks for your reply
                                    UpDate
                                    The problem was that I must have over heated one of the mosfet or it was bad to being with
                                    I now have both monitor working now they have been running for 60 minutes now and they both look very nice
                                    Two more monitor that did not end up in the land fill
                                    I want to thank ever one that reply to this post
                                    I have learn alot fix these two monitor
                                      Great two less monitors to the land fill. Thanks for the feedback also.
