X2 Gen
+ More Options
Posts
  • wayneg
    zeno
    • Dec 2010
    X2 Gen
    I have an X2 Gen monitor that shows green but no display, what to do?
    Opened monitor looked for bad caps, could find none. What else to do?? thx
  • jayoung
    • May 2011
    • 172
    Re: X2 Gen
    The power LED shows green? or the screen shows green?
    Does the screen flash when the power button is pressed? With the monitor hooked up to a source, can you see the image on the screen using a flash light?
    First things first would be to post good, clear, well lit (no flash) pictures of the power and logic board - front and back. Post them using managed attachments and not inline.
    • MOSSEP
      Monitor Audio RSW12 - Green light but no audio
      by MOSSEP
      Hi
      Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
      Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
      The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
      I have already tried replacing all of the...
      01-26-2025, 08:18 AM
    • MOSSEP
      Monitor Audio RSW12 - Green light, but no sound
      by MOSSEP
      Hi
      01-26-2025, 08:33 AM
    • matthewmcconaughey
      I need help with my friend Sony GDM-FW900 24” CRT
      by matthewmcconaughey
      Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
      I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
      1. It started with a bright and greenish picture upon starting a cold monitor.
      2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
      05-16-2023, 03:15 PM
    • ekozeko333
      by ekozeko333
      🧠 What I’ve Done So Far
      Flashed...
      06-21-2025, 02:48 AM
    • corrize
      Nikon D800 camera - flash don’t work and capacitor don’t charge
      by corrize
      Hello, I'm stuck in troubleshooting…
      The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
      In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
      When I press the flash button, it's detected by the system, flash icon appear on LDC display....
      10-01-2022, 10:02 AM
