HP w19e - Control Board Button
  • jayoung
    • May 2011
    • 172
    I have an HP w19e that works great except for something to do with the control board. There are 5 buttons on the control board - AUTO, VOL -, POWER, VOL +, MENU. Sometimes the control board works OK, sometimes not. The OSD will show up on screen automatically, the power button doesn't work, can't change between menus, etc. Through trial and error, I have narrowed the malfunctioning button to the VOL +. With VOL + unplugged, all other buttons function normally and as expected.
    The question I have, is there a chance that the actual button is malfunctioning or could it be something else? I have another button available from a scrapped out monitor and could replace it if that could be the cause.
    I can post pictures of the power board, logic board, and / or control board if they would be helpful.
    Thanks in advance.
  • 999999999
    • Sep 2006
    • 774
    Re: HP w19e - Control Board Button
    Button is just a switch. Probably the switch mechanism broke internally and is closing the circuit, locking out other button signals from having an effect.
    Manually complete the circuit by using multimeter probes on current measurement mode. Do it like the switch would, momentarily complete the circuit and see if it has the desired effect. Remove probes and try other buttons' function.
    If that seems beyond your ability, go ahead and put the replacement switch in then try it.
    • jayoung
      • May 2011
      • 172
      Completing the circuit manually worked as excepted, so I went ahead and swapped out the button with one from the scrapped monitor (a bit difficult removing 5 solder points in close proximity on a narrow pcb). I raised a portion of the trace while removing the original button, but I completed the circuit with some small wire soldered to the trace to complete the circuit.
      Thanks again.
      • Yanleb
        LG 60PK550 Logic Control Board EBR63450301
        by Yanleb
        Hi all, I just want to share the repair of my 60PK550-UA TV set.
        The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
        But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
        All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
        C57: 3.30V
        C61:...
        07-20-2023, 12:38 AM
      • Darren Hibbert
        MacBook A2179 Audio board+Power button boardview & schematic needed
        by Darren Hibbert
        Hi.
        Long shot but does anyone have a schematic & boardview for the audio board+power button on a Macbook A2179?
        There is a shorted cap on mine and I need to know if I can safely remove it or whether I need to replace it and with what capacitor.
        Many thanks. ...
        08-21-2025, 02:38 PM
      • bohaboha
        Use different IR SENSOR /TV CONTROL BUTTONS BOARD Possible
        by bohaboha
        Hi everyone is it possible to change or use a different IR SENSOR / CONTROL BUTTONS BOARD on a tv?
        exp: from a Philips to a Samsung or any
        if it breaks or if there is some odd brand or if universal remote control would not work
        05-05-2023, 07:24 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
