Viewsonic VX2235WM
  • iwant2byteu2
    • Jan 2012
    • 4
    Viewsonic VX2235WM
    I think I've read everything available on this sight for My monitor and this is definitely a lot of info.
    Here we go :
    Bought this (1of3) VX2235WM new a few years ago.
    Symptoms : Screen 6mos ago started going BLACK. I could hit reset and it would come right back. Eventually reset stopped working. Monitor is still recognized by my pc just have no screen to trail a mouse across.
    After reading as much as I could on your site I pulled out board with all the capacitors in it and looks like there are a few that can be changed.
    I'm confident I can replace the Caps. What I am confused about is What caps to get. When I goto Badcaps.net the numbers are mind boggling.
    Is there a cap kit for this monitor or can one be made ?
    Does this board seem to have a cap problem after seeing the board and does the cap problem match the symptoms?
    Thank you very much for any help.
    Last edited by iwant2byteu2; 01-08-2012, 07:50 PM. Reason: Don't see my attached Photo's.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Viewsonic VX2235WM
    Buying caps from badcaps.net supports the forum. The below was written for digikey, but the same principle applies. The badcaps store caters towards motherboards and sometimes doesn't have the higher voltage caps that lcd monitors and TV require.
    Have a read through. If you have clarficiation questions, please let us know.
    --- standard answer, regulars can skip ---
    https://www.badcaps.net/forum/showpo...84&postcount=3
    --- begin sig file ---
    --- end sig file ---
      by momaka
      03-15-2023, 10:17 PM
    • wattage
      AOC AG493UCX 49-inch monitor - Firmware request
      by wattage
      Hello Badcaps Community,
      The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
      07-13-2025, 04:41 PM
    • ant3202
      HP 27es - LED monitor - Monitor Flashing On - Off
      by ant3202
      Hi Everyone
      Lately I am experiencing the deja-vu incident on one of the led monitor like this.
      https://www.badcaps.net/forum/troubl...lashing-on-off
      The monitor is HP 27es LED Monitor
      https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
      The monitor will randomly blackout and display no signal and will recover again.
      Sometimes need to power and off again to restore the display but...
      03-20-2025, 07:30 PM
    • Rick_1234
      LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
      by Rick_1234
      Good evening, gentlemen.
      I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
      To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
      https://drive.google.com/file/d/1L6S...ew?usp=sharing
      Things I tried
      - Bought a new AC adapter thinking that was the problem but the problem...
      06-22-2024, 04:44 PM
      Wise Wing F199 19'' LCD monitor - recapped
      by momaka
      Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
      I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
      When I saw the Craigslist post, I wasn't...
      08-24-2020, 10:58 AM
