Anyone with the schematic diagram of the main regulator section CT-934D? I just want to know the values of the burnt resistors and capacitors; these were surface mounted components. Could I replace them with standard capacitors and resistors? The assy number is DAC - 19M001A.
CMV CT-934D Burnt SMC(Surface Mounted Components)
by jinu_jHi Folks
This has to do with a LED light driver rated for Output - DC36-65V 300mA. This is used to drive a 15W LED panel light.
Now this does not work so opened up and found 2 resistors burnt to crisp. Sensing a learning moment, i looked around the circuit to figure out that it is built around the OB2538 chip. The circuit to a large extent follows the sample application circuit mentioned in the data sheet. I have traced the actual circuit and the same is also attached for reference.
But i have some queries on this circuit
1. The resistors that burnt to crisp... -
by Sam ScarboMy Sparkle (SPI) PC power supply has broken. Originally, there was totally no power output. The 5V-standby was not there. I have replaced a few bulged capacitors but not helping.
I was trying to do more troubleshooting but burned more components. Some got burned so badly that the markings were gone. And also, the markings of a few transistors were gone because the component surface was worn out somehow.
If you happened to have disassembled the same PSU model, please help to provide the markings of some of these components.
See the attached two pictures of the small...09-18-2024, 08:29 AM -
by gravsHey everyone!
I wanted to upgrade the SSD on my ASUS laptop (Zephyrus S GX502GV) and everything went just fine, except when I tried to put it back together I accidentally inserted the battery before the screen connector. When inserting the screen I hit the connector on the board and a spark happened.
The situation now is that the computer works (outputs over HDMI) but the screen doesn't turn on.
I've tracked the burned components on the motherboard and found a schematic for the laptop. My problem now is that I can't figure out the exact name or operation... -
by TinkerTronHey everyone,
I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
Instead, here's what's been bugging me so far:
The schematic...3 Photos-
by karatzdiHello,
I know some might say... just buy another one. Sell it as parts..!
So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
Spent some time downloading the Service...-
06-11-2024, 08:38 AM -
- Loading...
