Envision G19LWK with yellow color problem
  • matthew_crane
    • May 2011
    • 7
    I have Envision G19LWK that was given to me for free. Initially, the monitor would only power up for about 3 seconds then go into standby. This turned out to be bad ccfl's so, I replaced them. The power/display board appeared to be fine also. I reassembled the monitor for testing, and discovered that the monitor worked, but with a heavy yellow tint. I tried resetting the color settings to the defaults ,but that made no real difference. Something I notice is that the OSD displays all of the colors on it correctly with no yellow tint. I think the issue is with how the monitor processes signal color but I have no clue what to check for to fix this. The yellow tint appears on both the vga and dvi inputs. Any assistance would be greatly appreciated.
    by momaka
    03-15-2023, 10:17 PM
  • dfranks
    AOC Envision 24" monitor with Yellow tinge
    by dfranks
    Hi everyone. I have an AOC(?) Envision 24" computer monitor, model TFT24W90PS, Product name G416. Its worked fine for years but now has a yellow tinge on the screen. I tried various adjustments via the monitor controls but no good. I swapped the monitor with another to see if it was the video card or video cable but other monitor looks fine.
    I have it apart right now looking at the boards. I have replace the electrolytic capacitors on the inverter board but still same problem. All of the electrolytic caps on the power supply (and inverter board) visually look ok, no bulges or leaks....
    10-04-2020, 10:28 AM
  • valscu
    EIZO SW3031W monitor blue color instead of black
    by valscu
    I have an Eizo SX3031W monitor and after a period i had problems with the tcon board. I did reflow, it went well for a while after but the problems appeared again. The second reflow attempt was a failure, the tcon board stopped working. In the meantime, I bought a perfectly functional Samsung 305T monitor from which I took the tcon board and installed it in the Eizo monitor. Since I turned on the monitor, the blue color appeared in the background instead of black. And also in Windows, appears blue instead of black. I tried various settings from the monitor and driver settings but...
    08-10-2022, 02:08 PM
  • wattage
    by wattage
    Hello Badcaps Community,
    07-13-2025, 04:41 PM
  • ant3202
    HP 27es - LED monitor - Monitor Flashing On - Off
    by ant3202
    Hi Everyone
    Lately I am experiencing the deja-vu incident on one of the led monitor like this.
    https://www.badcaps.net/forum/troubl...lashing-on-off
    The monitor is HP 27es LED Monitor
    https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
    The monitor will randomly blackout and display no signal and will recover again.
    Sometimes need to power and off again to restore the display but...
    03-20-2025, 07:30 PM
