Two dead Princeton VL1916 monitors
  • Frh1
    • Dec 2011
    I have two Princeton VL1916 LCD Monitors. The one on my wife's computer stopped working a couple of years ago. I assumed the power supply was bad. I replaced them both of them with larger 21" monitors, but occasionally used the one in my home office with a laptop computer. When we moved, I put both monitors and power supplies in a box.
    Yesterday I decided to figure out which one works. I tried both monitors with both 12V 4.0A power supply blocks. The one that I thought was good is a little larger and not quite as heavy as the other one but neither monitor would power on with it. When I plugged the smaller power block into an AC cord (while not plugged into a monitor) the green light went on for a brief moment, then went out. Neither of the monitors would power on with it either.
    What concerns me is something like bad capacitors in one of the monitors might have caused both of the power supplies to burn out. If that were the case, replacing a power supply without knowing which monitor is bad could be a total waste of money.
    Any suggestions (other than throwing both of them out and buying a replacement to occasionally use with my laptop)?
    (I might add that I am not competent with a soldering iron, and the only thing I have to test a 12V circuit is a probe with a light in it for checking the light and brake circuits on my utility trailer.)
  • PlainBill
    • Feb 2009
    • 7034
    Re: Two dead Princeton VL1916 monitors
    If you can't solder, and don't have a DMM (or even a VOM), the best approach may be to sell them on Craigslist at $15 each or 2 for $25. I would suspect bad caps in both the power supplies and the monitors; certainly in the power supplies.
    The other option is to buy a power supply (or two). They are going for as low as $8.59 (with free shipping) on eBay.
    PlainBill
    • Frh1
      • Dec 2011
      Thanks for the reply PlainBill. I opened the larger of the two power supplies today. The inside of it was encased in tin that I did not try to remove. Several capacitors were visible and were not bulging. Given the low cost of replacing it, I would not even consider trying to repair the power supplies.
      When last used, one of the monitors worked just fine and buying a replacement power supply would make sense. That is, unless hooking it up to a bad monitor could make the new power supply fail? If that could happen, buying a replacement power supply might not be a smart thing to do. If it's safe to buy a new power supply, perhaps even attempting to repair one of the monitors might make sense.
      Another possibility might be to take or send them to a repair shop. The Badcaps website has pricing for repairing motherboards, but I could not find pricing for monitors.
      But, I noticed you are in the Phoenix area. I was unable to edit my User Profile, but I'm in Queen Creek (south east valley). I seem to recall a company in Mesa or Chandler advertising monitor repair a while back. Perhaps you might be able to point me to a local company that could check them out?
      • retiredcaps
        • Apr 2010
        • 9271
        Most repair shops are "board swappers" today. Very few do component level repair. Even if they did do component level repair, the cost would easily surpass $50 which makes it questionable.
        The owner here, AFAIK, only does motherboard repair.
        --- begin sig file ---
        --- end sig file ---
        • PlainBill
          • Feb 2009
          • 7034
          I'd be glad to check them out, but I'm more than half way across the valley from you (Near the Frys on Thunderbird). While I HAVE driven to Queen Creek (and beyond!) in search of a bargain non-working TV, I am less than eager to do so in this case.
          Here's my thoughts on this situation. Current SMPS design should allow a power supply of this type to survive being hooked to any reasonable load, including a dead short. One common failure of SMPS supplies results in them failing to start when AC power is applied. If they had constant AC power they could work for years in this state. So it is unlikely that you 'killed' a power brick by connecting it to a bad monitor.
          Given the cost of a replacement power supply, I would suggest ordering one, verifying it works with the 'good' monitor, then trying it on the 'bad' monitor. Or contact me via PM. I'm always up for what promises to be an easy repair.
          PlainBill
          • double_DD
            How can I be sure that my EC chip is dead?
            by double_DD
            As the title suggests, how can I be sure that my EC chip is really dead?
            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
            03-12-2025, 07:47 AM
          • disorder
            ps5 edm-033 dead after hdmi/usb ports destroyed
            by disorder
            hello guys,
            i need help to repair a edm-033 ps2
            history : as always hdmi port and usb ports destroyed after unplugged
            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
            so i changed it
            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
            i don't see any projection of liquid metal on pcb.
            01-14-2025, 12:48 PM
          • zunasthegreat
            Chieftec GPS-450-AA with dead 20N60C3
            by zunasthegreat
            Hello everyone hope all doing well!
            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
            09-01-2024, 07:12 PM
          • Beton
            Finding a dead short component
            by Beton
            Hi guys!
            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
            I have a bench PSU and if I try to inject voltage the voltage...
            12-10-2021, 01:05 PM
          • FiguringITout
            MSI Raider GE75 - Not posting, probable dead CPU
            by FiguringITout
            Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
            Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
            07-25-2024, 07:27 AM
