dell e228wfp goes blank
  • chetreynolds
    chet
    • Aug 2010
    • 77
    I have a dell monitor that turns the invereor off when an input is attached . The inverter turns back on when the input is removed.
  • alexanna
    • Mar 2010
    • 1346
    Re: dell e228wfp goes blank
    Dell monitors when no signal is supplied will float a self test box around the screen.
    When a signal is applied a different circuit takes over.
    Your monitor is a very high resolution monitor, Are you sure your video card can support It?
    Have you tried setting your computer to different resolutions, Try starting at a low resolution and work the way up to the highest resolution of your video card.
    • alexanna
      • Mar 2010
      • 1346
      Have you selected the correct input by pushing buttons on the front panel switch?
      • chetreynolds
        chet
        • Aug 2010
        • 77
        yes I only have an analog input
        • trebo
          • 514
          • Wales, UK
          can you tell us if those caps are ok?
          the reason I ask is, it looks like you have a cap or possibly 2 that are rounded on the top on the psu
          hard to tell from the pic
          the 2 in question are in pic4 bottom right hand corner cap, and the one above it
          they may be your problem
          • chetreynolds
            chet
            • Aug 2010
            • 77
            All of the caps are ok and have a low esr when measured in circuit
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              When you put in the input is the power LED green or orange?
              Also, it looks like you have some KZG caps in there - these are notorious for failing without any visible signs (meaning they could be bad even though they aren't bloated).
              I would remove them then test ESR again on each KZQ cap.
              Then again your pictures are blurry maybe I made a mistake about the presence of KZG. But please check! If possible, list the brand and series of the caps in your monitor.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Black caps on video board look 'puffy' - like just beginning to bloat.
                Mann-Made Global Warming.
                - Dr Seuss
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  KZE or KY would be more typical in a screen.
                  Those both come in brown too.
                  I can't read them either though.
                  - Dr Seuss
                  • Borse2008
                    Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                    by Borse2008
                    Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                    I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                    • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                    • There’s
                    07-15-2025, 04:55 AM
                  • Rick_1234
                    LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                    by Rick_1234
                    Good evening, gentlemen.
                    I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                    To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                    https://drive.google.com/file/d/1L6S...ew?usp=sharing
                    Things I tried
                    - Bought a new AC adapter thinking that was the problem but the problem...
                    06-22-2024, 04:44 PM
                  • andrhouseolly
                    Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                    by andrhouseolly
                    Hi.
                    I kindly ask you to help me solve the problem.
                    Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                    The board turns on, there is no image.
                    Read more. When the power supply is connected, the front panel indicators light up briefly.
                    When you press the power button, the button indicator lights up. The board works
                    there is no image, there is no matrix initialization, there is no image on HDMI.
                    When turned on, the fans do not spin, but when they warm up they start spinning.
                    When you turn off the button, the fans spin up to full speed for a short...
                    05-11-2024, 03:14 PM
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • DanPoka
                    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                    by DanPoka
                    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                    02-15-2025, 05:05 AM
