power board repair questions, help
  • balls20
    • Nov 2011
    • 4
    I have a 19inch gateway lcd monitor. It has not power when plugging it in not even a led light from the power button. when i jiggle the power cord it will briefly blink with lights on the power button and the screen itself.
    after taking it all apart i find that all 6 of my caps are bulging and there is a burn mark on the board.
    http://tinypic.com/r/20jimur/5
    you cant tell but the caps are bulged, but im worried about the burn mark. Could this whole board be bad?
    after i get some fedback of, if this is worth the money in caps to repair or if the board looks trashed. I will order some caps from ebay or go to radioshack and begin the repair.
    and tips would be appreciated. This is my first cap repair. And I am a newb at electronic repairs.
  • mariushm
    • May 2011
    • 3799
    Re: power board repair questions, help
    It's not unusual to have boards like that, looking like they're burned. it doesn't mean it's bad.
    A new board will cost you around 25-30$ - capacitors will cost you about 10$ (shipping included). You should change all except the big large one rated for 200-400v - I'm counting 11 on the board (there's one by the transformer that's important)
    You don't need a lot of experience to replace them, they're easy to solder on but if you don't have a soldering gun and soldering wire, it may be cheaper to buy a new board from eBay.
    • trebo
      • 514
      • Wales, UK
      balls20
      check out the 3 fuses on the board you may need to order a new one as well
      if you dont have solderig, iron beg or borrow one and have fun repairing it
      • balls20
        • Nov 2011
        • 4
        Just to ease me mind from worry. This has to be a board problem right? No power = problem with power board is what I'm hoping for hate to spend money and have no results.
        i was told that even if my caps are bulged it should still work? from another forum.
        could anyone show me wear to order a board like this? only boards ive seen like this is repair kits caps only.
        or
        is it possible others boards will fit and work?
        ya i got soldiering gun and paper clips so im good on that.
        • retiredcaps
          • Apr 2010
          • 9271
          What site would that be? Can you provide a link?
          --- begin sig file ---
          --- end sig file ---
          • balls20
            • Nov 2011
            • 4
            Heres a link to wear i that.
            http://www.tomshardware.com/forum/31...8-monitor-wont
            does this guy know what he's talking about?
            • retiredcaps
              • Apr 2010
              • 9271
              In the future, we prefer pictures uploaded to this forum and not posted inline for a number of reasons. You can add pictures using the manage attachments feature.
              We can definitely tell the caps are bloated.
              Because the caps are bloated, they will not be functioning properly. This means the voltages supplied to the logic board (where you VGA and DVI are) and the inverter board (where the backlights are) will be low. This means the power LED and backlight will not function properly.
              Replacing the caps will likely solve your problem, but it is not 100% guarantee because the bad caps may have caused other components to fail.
              If you are new to electronics repair and have no multimeter, no soldering iron, no solder, and have no desire to learn, then buying a replacement board might be your best option.
              RadioShack will not carry the proper capacitors. Ebay may have sellers selling counterfeit caps. Online vendors like digikey and mouser have the proper caps and are legit.
              • retiredcaps
                • Apr 2010
                • 9271
                Bloated caps MAY work. I have seen ATX power supplies and motherboards personally that have bloated caps and still function. It may not function well with BSODs and low voltage or fluctating voltage.
                For example, if the caps are parallel, one bloated cap may not be enough to cause the circuit to fail. Say there are 5 caps in parallel and 1 is bloated, the other 4 may keep the circuit running.
                • balls20
                  • Nov 2011
                  • 4
                  all 6 of the caps are bloated. but when i jiggle the power cord near the monitor power input it gives me a flicker of light on button and the screen, could this be indicating that the the caps are *not my main problem? If all the caps are bad then is there a good chance that it has damaged another part of the board? With bad caps shouldn't i at least get the orange standby light on the monitor off and on button?
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    No, not necessarily. I've had a monitor not power up due to 1 bad cap, and that cap wasn't even bulged.
                    Also, don't buy caps from Radio Shack or through ebay! Radio Shack doesn't have the right kind of caps for this application and most of the caps on ebay are fake and will eventually bloat just like the ones you have now. There's only 1 seller on ebay that sells genuine legit caps.
                    As retiredcaps suggested, digikey.com and mouser.com are good online places to buy caps (if you're in the USA). The Badcaps.net store might also have the caps you need.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      This is NOT a 100% correct analogy, but it might help explain the situation.
                      Since it is close to the holiday season, let's take the example of parallel vs series holiday lights.
                      Lights in parallel will still work if one or more of them are out. If enough lights are out, the aesthetics may look poor, but the display is working. If only 1 light is out, the aesthetics may look pleasing and no one may notice the 1 light out.
                      Lights in seres will NOT work if one or more lights are out. It may momentarily come on and flash, but will quickly die.
                      So depending on the layout of the power board, that is why bloated (i.e. bad) caps MAY work. It all depends on circuit layout (think parallel vs series). Some circuits will may tolerate a bad cap or two and others won't.
                      Let me be crystal clear. Bloated caps are ALWAYS BAD.
                      • PlainBill
                        • Feb 2009
                        • 7034
                        One thing that stands out - jiggling the power cord causes a change. This should NOT be happening. Resolder the power input connector, make sure the power cord is firmly seated, and look for bad solder joints in the input area.
                        As far as the bloated caps, recap with name brand, low ESR caps. Don't screw around at Radio Shack, eBay, or some TV repair shop that insists CapXon caps are excellent.
                        With respect for retiredcaps, his analogy to lights is appropriate for the season, but flawed. A better analogy would be the lug nuts holding the wheels on a car. If all are properly torqued, you don't have to worry about any wheels coming off. If a few are loose, it places greater stress on the rest AND on the wheels. And the consequences of failure can be catastrophic.
                        PlainBill
