Viewsonic VG150, invisible crack
  • mathog
    • Mar 2010
    • 2655
    Found what looked like a really clean Viewsonic VG150 in the dispose pile at work, minus the external power supply. No notes on it. Inspected it carefully under reasonably bright fluorescent light and didn't see anything wrong with it. Sure it is an old display, but who knows, maybe it was just thrown out because it was replaced with something bigger?
    Spent a day trying to find an adapter that would fit, failed, and so opened it up and soldered a wire onto the +12V DC and put the ground wire under a screw, then ran it from a PC power supply. It started right up, and revealed an inch wide swath of dead pixels near the top, alongside a fine dark line that looked like a glass crack. However, that crack was only visible with the backlight on.
    Turned it off, inspected it again (still inside) and could not see anything wrong with the screen glass, even knowing now where the problem was. Ran my fingernail over the screen and couldn't feel a discontinuity. Finally took it outside in the bright sun for inspection. Still couldn't see a crack in the glass under that illumination, but there was a swirling effect over the blown pixels that wasn't present anywhere else on the screen.
    This is a new one for me. Usually a cracked screen is pretty obvious but not this time. Here it looks like the LCD layer split while the glass stayed mostly (entirely?) intact. I didn't care enough to tear it down further to find out for sure, and it went out to the ewaste.
  • lostone
    Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
    by lostone
    Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
    First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
    When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
    05-19-2024, 11:40 AM
  • tongshadow
    Panasonic Plasma 2008 TH-42PV/PX series - Removing the coating from the Front Glass
    by tongshadow
    I got this set for very cheap, it works perfectly but the catch is that the protective coating was damaged. About 45% of the screen had a green tint, you can see exactly where the layer changed colors to a blueish tone (that actually makes everything green).
    "Ok, that's probably just the anti-glare layer" - I thought. So using a microfiber cloth and automotive metal polish I was easily able to turn it into a nice mirror.
    Unfortunately, the damage was beyond this layer and everything still had a horrible green tint. I initially...
    03-12-2023, 12:06 PM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • StefanNg
    Viewsonic VX2718-PC-mhd SG2701B01-8
    by StefanNg
    Hi, Badcaps.
    I am troubleshooting a monitor
    Viewsonic VX2718-PC-mhd.
    Panel model SG2701BSG2701-8
    Symptoms is no image.
    This panel has 2 panel board connected by a U-ribbon.
    When I disconnected the ribbon, I get a perfect half screen image.
    I took some test point voltage, when ribbon disconnected.
    HVAA 8.38v
    FVDD12 1.21v
    FDD33 3.3v
    VIN 11.79v
    VAA 16.85v
    VGHF 30.16v
    VGL -8.02v
    CK1_I ~ CK8_I 1.403v
    CK1_L ~ CK8_L 8.26v
    When I connect both panel board
    HVAA, VGHF, and CKx_L...
    05-17-2025, 01:43 AM
  • SarcasticOP
    Replaced the glass IC on a Series X, Pin 13 in now OL.
    by SarcasticOP
    Hello!
    I am replacing the booster IC (glass IC on the other side of the HDMI port) and I had to use a bypass chip I from Sourcely. I got everything set up and resolved the issue I was having from that (different line was OL) but now I am contending with this one. Is there something I can do to restore the signal?
    Attached is a photo with the pad in question that is supposed to supply the signal to pin 13 on the HDMI port. Tweezers where I am pointing to.
    12-18-2024, 02:29 PM
