Staples SP7106
  • ajd15
    • Oct 2011
    • 12
    • united states
    Staples SP7106
    I have been trying to find who manufactures these monitors. The tech tell me they don't know, but bring it in and they will look at it.
    My problem is : the screen is black,power light on.
    caps have been replaced.
    If I can get a schematic I can do a better test.
    Any help would be appreciated.
    Tony
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Staples SP7106
    1) There could be a fuse in the inverter area which would explain the black screen.
    2) There could be shorted fets in the inverter area.
    3) Post pictures of your boards using the manage attachments button so they are hosted here. Please do not post pictures inline as they slow down the loading of pages.
    For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
    Here is an example of the pictures we want.
    https://www.badcaps.net/forum/showpo...94&postcount=1
    --- begin sig file ---
    --- end sig file ---
    • jetadm123
      • 2169
      Re: Staples SP7106
      Tony
      Since the same power supply can be used by different manufacturers for different models, post some photos per retiredcaps suggestion and maybe someone can give you a different monitor model that your power supply is used in.
      • killian6pk
        • Apr 2010
        • 502
        Re: Staples SP7106
        I have a Staples SP9106 it is actually made by a company called Hann Star. There is also Hanns G and I think one other name that all produced by the same company. Open it up and post pictures and I tell better if yours is made by the same company as mine.
        Have you ever stopped to think and then forget to start thinking again?
        As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Re: Staples SP7106
          Yes, HannStar makes Hanns-G (Hanns Graphics) monitors. They're also pretty big in the laptop motherboard market.
          A working TV? How boring!
          • ajd15
            • Oct 2011
            • 12
            • united states
            Re: Staples SP7106
            pictures.
            • kaboom
              "Oh, Grouchy!"
              • Jan 2011
              • 2507
              Re: Staples SP7106
              85c GP Xicons/Lelons??? How about some FMs, FCs, PWs, HEs, maybe HDs?
              How does the soldering on those jumpers and transformers look?
              -Paul
              "pokemon go... to hell!"
              EOL it...
              All style and no substance.
              guilty,guilty,guilty,guilty!
              guilty of being cheap-made!
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Re: Staples SP7106
                Mm. It's one of those external PSU things. Have you tried a different power brick? Also check the output of all regulators on the logic board. The regulators are the 3-leg devices with a tab on the top side, in your first pic there's two of them right next to the connector that joins the two boards.
                • killian6pk
                  • Apr 2010
                  • 502
                  Re: Staples SP7106
                  Yours looks just like mine on the power side. My main board does not have the DVI connector. I opened my power supply but nothing looked bad. I had tested it for proper voltage. I bought a second new power supply just to keep on hand. My problems are the same with either of the power supplies. I tested the inverter transformers and found two of them were bad. I had replacements so I went ahead and changed them out. Still did not get a picture. I changed the caps on both boards, but that did not get it going either. I have about given up on mine. Looking more and more like a parts monitor. I have done a pretty in-depth search for a Service Manual without any luck.
                  • bohaboha
                    Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                    by bohaboha
                    Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                    anyhow i couldn't t read anything else
                    the backlight is on strong and the screen does not get dark or very dark but no pictures
                    the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                    01-02-2025, 08:04 PM
                  • valvashon
                    LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                    by valvashon
                    The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                    Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                    11-24-2024, 12:08 PM
                  • VitalComputing
                    Taking Pictures Of Large Circuit Boards
                    by VitalComputing
                    Hi friends,
                    I am trying to take good quality pictures of rather large desktop motherboards for a project I'm working on. I had a brilliant idea of scanning them with a flatbed scanner I have but it only focuses on the bits of the board that are flush to the scanning glass. And the through hole components tend to lift the main board from the scanning glass. Everything else just looks out of focus. So it seems that that option wont run.
                    I have been capturing the images with my iPhone 11 and it's okay but wont capture the whole board. I have to grab it in sections and...
                    11-22-2022, 04:15 PM
                  • E--Man
                    Samsung LED UHD TV - Bad Main Board or Bad T-Con Board? Pictures inside
                    by E--Man
                    Hi All,
                    Thanks for reading. Based on the interesting fact that the vertical lines issue don't seem to effect the menus whatsoever but rather everything around the menu regardless of video is shown, I'm trying to set mine whether the issue is the main board or the t-con board.
                    Again what's baffling is that the menu is not effected whatsoever. However, any other video displayed regardless of inputs or when no inputs exist exhibits the vertical lines and seem to effect black areas only.
                    The lines are green in color when the tv is in "Game Mode" and...
                    05-12-2024, 10:52 AM
                  • hyva_ana
                    Pictures
                    by hyva_ana
                    02-13-2023, 02:22 AM
