Re: Samsung Syncmaster 245B - Screen freeze -> screen flash 4 diff colours
I cleaned all the cables between the PSU PCB and the video PCB, plus the cable going from the PCB into the LCD panel....
10 days now without a hiccup. Didn't expect that....
I previously recapped my 245B and it worked for some time. Now it does exactly as described above.
All caps were replaced with Panasonic FC and the big one was replaced with a Nichicon AR. Resistors were replaced with heavier wattage ones.
There is one Nichicon VZ 470uf 35v near CN801 and a Panasonic NHG 22uf 50v near the infamous 3 resistors
None of the caps look bulged in any way. Is this now failing from wrong series caps?Leave a comment:
I have finally finished the job. While I am not happy with a lot of the solder joints I made (if you look at the picture), my monitor is, however, functioning right now, so that has to be a good sign! I am staying guarded because the monitor would work for a while before having issues, so we'll see. I also changed the resistors and scraped most of the yellow glue off. After more research, and an inability to find silicon that I was 100% comfortable using on my board, I opted to use heat shrink tubing to insulate them. It seems to be working OK with less mess.
I wanted to sincerely thank you both, retiredcaps and PlainBill. It was your help and kind support that gave me motivation and confidence to attempt to fix this myself.
Thank you!Leave a comment:
I tried to gentle wobble the resistors, but this stuff has a death grip on them. What is it and how do I safely remove it so I can replace the resistors?Leave a comment:
I forgot to add, the three resistors on the bottom that everyone recommends to replace are all stuck together with this weird yellow gunk. I tried to gentle wobble the resistors, but this stuff has a death grip on them. What is it and how do I safely remove it so I can replace the resistors?Leave a comment:
Thanks for the heads up to double check my board.
Oddly, my board has 3x 47UF 50V instead of 2 of those and a 47UF 10V. I would have been really confused what to do with that 10V when it arrived :P.Leave a comment:
I should mention that the PPC68W-2CT-ND part number came from the 245B megathread at (thanks to PlainBill)
https://www.badcaps.net/forum/showpo...&postcount=334
Feel free to substitute as you see fit.Leave a comment:
One other MAJOR thing. Manufacturers routinely make revisions and sometimes completely change boards. So CHECK your board with the capacitors above BEFORE ordering.
PS. Also make sure the height and diameter are okay for your board.
PPS. Now would also be a good time to add other things (maybe soldering items) to the digikey order to "ammortize" the $8 USD shipping/handling.Leave a comment:
See below.
I don't understand the mixing in of the Nichicon capacitors with the Panasonics... Maybe he doesn't have the equivalent Panasonics on hand.
If you follow PlainBill's quick instructions at
https://www.badcaps.net/forum/showpo...&postcount=399
you can find out that ordering on your own will save you a few dollars and you get all Panasonic caps.
I did it just to see what the markup was. Keep in mind that the ebay seller is making much more because he buys in bulk whereas this is only quantity = 1 or 2.
1 1 P12357-ND CAP ALUM 2200UF 10V 20% RADIAL 0 0.91000 $0.91
2 2 P14445-ND CAP ALUM 1000UF 35V 20% RADIAL 0 1.08000 $2.16
3 2 P14378-ND CAP ALUM 1000UF 10V 20% RADIAL 0 0.65000 $1.30
4 1 P14441-ND CAP ALUM 470UF 35V 20% RADIAL 0 0.76000 $0.76
5 1 P12392-ND CAP ALUM 100UF 50V 20% RADIAL 0 0.48000 $0.48
6 1 P10341-ND CAP ALUM 68UF 63V 20% RADIAL 0 0.51000 $0.51
7 2 P10321-ND CAP ALUM 47UF 50V 20% RADIAL 0 0.36000 $0.72
8 1 P11180-ND CAP ALUM 47UF 10V 20% RADIAL 0 0.47000 $0.47
9 1 P14452-ND CAP ALUM 22UF 50V 20% RADIAL 0 0.35000 $0.35
10 1 P10316-ND CAP ALUM 10UF 50V 20% RADIAL 0 0.35000 $0.35
11 1 P10312-ND CAP ALUM 1UF 50V 20% RADIAL 0 0.35000 $0.35
12 3 PPC68W-2CT-ND RES 68 OHM METAL FILM 2W 5% 0 0.58000 $1.74
Subtotal $10.10
Shipping $8.00
GST unknown
HST unknown
Total unknownLeave a comment:
I was looking at getting one of those capacitor kits sold on ebay. I messaged the seller, and these where the ones he said came in the kit:
1 - 10V 2200uF, Panasonic FM
2 - 35V 1000uF, Panasonic FR
2 - 10V 1000uF, Panasonic FM
1 - 35V 470uF, Panasonic FM
1 - 50V 100uF, Nichicon PWM
1 - 63V 68uF, Panasonic FC
2 - 50V 47uF, Nichicon PWM
1 - 10V 47uF, Panasonic FC
1 - 50V 22uF, Panasonic FM
1 - 50V 10uF, Panasonic FC
1 - 50V 1uF, Panasonic FC
1 - Resistor uF-3 2w (That triple resistor that often fails in this model monitor)
Cost to me would be 16.95 US + 6.95 shipping (I'm in Canada)
Do these look like they will work?
Thanks,Last edited by drkbef; 11-13-2011, 06:48 PM.Leave a comment:
Sadly, I don't have anyone that regularly solders electronics... My only option would be to learn myself, or just buy a board :PLeave a comment:
https://www.badcaps.net/forum/showthread.php?t=485
Good soldering video at
http://www.youtube.com/watch?v=I_NU2ruzyc4
If you are not going to do another repair in the future, maybe get one of your family/friends to replace the caps for you.
If you are going to replace the caps on your own, then maybe practice on a couple of junk boards?Leave a comment:
Wow, such quick replies, you guys are really impressive!
This is my first time with any electronics repair, and it is kind of intimidating. I'll have to do my research this week on how to replace caps on a board.
Thank you both RetiredCaps and PlainBill, you're both great!!Leave a comment:
Also this monitor has problems with the resistors burning up. The three that are suspect are the ones just right of the BN44-00175A. I believe they should read 68 Ohms as per this megathread ...
https://www.badcaps.net/forum/showth...=245b+resistor
Since you have the monitor open, it is best to test them now and compare them to the color band as per
http://en.wikipedia.org/wiki/Electro...r_and_inductor
Even if they are good, you might want to pre-order spares along with the replacement caps to save on future shipping.Last edited by retiredcaps; 11-06-2011, 06:19 PM.Leave a comment:
Two caps circled in red - obviously bad. The must be replaced with low ESR name brand caps, such as Panasonic FM series.
Caps circled in yellow. The recommendation is to replace them with low ESR name brand caps such as Panasonic FM.
Cap circled in blue. Replace if you wish; it is unlikely it is bad.
Shucks, retiredcaps beat me to it.
PlainBillLeave a comment:
2) You have at least 2 domed/bulged (I'm sure you can determine which 2 are obviously domed) caps by connector CN801 (bottom right hand corner). At minimum, I would replace all 4 in that section.
3) There are 15 electrolytic caps in total. Since this is a nice big monitor, most here would recommend replacing all of them except the largest one which rarely, but not never, fails.
4) Capacitors (C designation on the PCB board) die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad. They can be out of tolerance uF (a 1000uF measures 20uF) and/or have high ESR (ohm). A multimeter will be insufficient to test for ESR. For that you need an ESR tester which costs between $50 and $300.
5) PCBONEZ talks about how to choose the right series at
https://www.badcaps.net/forum/showpo...47&postcount=3
6) If you don't want to do all that work in step 5, then choose Panasonic FR, FM, and FC caps (in that order of preference) from digikey following PlainBill's ordering instructions at
https://www.badcaps.net/forum/showpo...33&postcount=2Last edited by retiredcaps; 11-06-2011, 06:12 PM.Leave a comment:
Sorry for the ridiculous delay in getting these images. Just started a new job and things have been hectic.
Anyway, I have some even closer shots of the boards done in sections should you require. Please let me know.
Thank you again for your attention and help!Leave a comment:
Thank you for your kind reply!
I will do as you ask later in the week when I have time.Leave a comment:
For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
Here is an example of the pictures we want.
https://www.badcaps.net/forum/showpo...94&postcount=1
You can post pictures here and member can help you. Please follow the guidelines in my sig file below.Last edited by retiredcaps; 10-23-2011, 06:01 PM.Leave a comment:
by warsztatHi, trademil Horizon freeze after start like video, i try reset (3sek push stop), remove and I put new ones capaticors 3,3V line digital and analog line.
The device in service mode passes all tests, except for the display test, where it hangs. The display in service mode during engine testing, etc. seems to behave correctly, it shows values, the engine is working, I can adjust its speed but only in service mode, in normal operation after pressing start the machine freezes
All the multiplexers that support the display seem to be working. It's like the processor... -
by MandorHello people.
I have the samo problem as described in this thread:
https://www.badcaps.net/forum/showth...highlight=245b
The monitor was on standby and one day the screen (or just the backlight) would not turn on. Computer still recognized the monitor and was acting like it was there (5 screen setup). I switched the monitor off with the big switch by the cable, waited 5ish seconds and switched it back on. I heard a loud bang.
Both fuses blown, resistor blown, bad mosfets.
I checked most electrolitic caps in circuit and...-
by maleksaMy Yamaha MOX8 synthesizer recently developed two issues.
Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...-
11-07-2024, 03:28 AM -
by soopacrucialHi folks,
Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...3 Photos-
by EsIstSimonHi there,
i have a Lenovo Ideapad 5 15ARE05 that will freeze randomly.
Sometimes it wont even post, sometimes i can use it for a couple seconds or minutes before it completely freezes.
Sometimes the screen freezes, but still displays the last frame, sometimes (pretty rare) the screen goes black
It does not matter what i do. Installing windows, starting Fedora or just sitting in the bios. After some time it will freeze.
When the freeze occurs, the laptop draws a pretty constant wattage (it will just stay on the value that it draws, when it locks... - Loading...
