LG L1811S fast blinking LED
  • Rasta Beuher
    • May 2010
    • 5
    Hello everybody,
    I just get a LG L1811S with the green LED flashing 2 times per second.
    I managed to get the service manual and uploaded it here.
    As you can see in the service manual, there are 3 boards: the power board, the logic board and the inverter.
    Here are the tests I performed:
    - Power board disconnected from everything: the 12V and the 5V are perfectly stable and there is a fast ticking (I think it's coming from the main transformer, about 5 times per sec.).
    - When power board connected to the logic board, the 12V varies between 11.8 to 12.1, and the 5V from 4.6 to 4.7. The sames voltages are going to the inverter. The ticking slows down too 2 per sec, as the green LED.
    - When the inverter is not connected, no changes: I don't think the problem comes from it.
    - The voltage on pin 1 of U270 (74F14 IC) is from 2.6V to 4.3V. The output of the pin 2 (0.4V to 1.5V) seems to go to the panel board (with the control buttons and the LED) where it varies from 0.3 to 1V after a resistor (I think this cause the LED to blink). I didn't manage to see where the input on 74F14 pin 1 comes from, maybe from the GM2121 IC? I think the problem is upstream.
    I followed the "no power" section in the troubleshooting section (but actually there is power!), and at the step 3 the pin 103 of U203 (GM2121, the main IC) is at a solid 2.2V...
    I don't really know what to conclude with all this, and what to do next.
    Any help would be appreciated!
  • PlainBill
    • Feb 2009
    • 7034
    Re: LG L1811S fast blinking LED
    By the symptoms something on the signal board is overloading the power supply. As a first step, disconnect the LCD panel from the signal card. Beyound that, I would suspect the small caps near the SMPS controller.
    Pictures of your power supply will help us help you. At least 1000 x 1000 pixels, well lit and sharp, and attached using 'Manage Attachments' - below the test entry area.
    PlainBill
    • vaneno
      • Oct 2011
      • 7
      PlainBill
      ... i totally agree. I repair an lg1715s with same problem and fix it changin this caps. Another test if this not solve it, i'll try to change de double-diode on secondary (labeled as D906). good luck
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • pc_okay
        LENOVO IdeaPad 3-15ALC6 - 82KU (board NM-D521) blinking continuously 0.5A
        by pc_okay
        Hello friends,
        I have this laptop AMD Platform starting & not posting, fan spinning.
        When i press power button, the board get almost immediatly 0.5A ~ and board get stuck at 0.5A with power button led blinking indefinitly.
        If i stop the computer (pressing 5s power button), board stop and when i restart i get approx 0.37A ~ and
        I try to reflash the bios with no luck, same result, and i try disabling onboard ram (i remove resistors accordling schematic), no more progress.
        CPU and his area heat, maybe the cpu is dead?
        10-21-2024, 10:23 AM
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
