Acer x223w first white screen, now no backlight
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Acer x223w first white screen, now no backlight
    Originally posted by teri3s
    Scale was set to 10x
    I'm curious. Can you remeasure the n channel mosfets "in circuit" with your digital multimeter?
    I have nothing against analog multimeters, but I'm curious if you get the same 50 ohm reading on the digital.
    --- begin sig file ---
    --- end sig file ---
    • teri3s
      • Oct 2011
      • 25
      I just rechecked CN801 (plugging in the logic board this time) with the digital multimeter against the ground where the plug is and I get
      While off
      1) 5.05v (VCC 5V)
      2) 5.05v (VCC 5V)
      3) 0V (GND)
      4) 0V (GND)
      5) 0.03V (on/off)
      6) 2.56V (Brightness)
      7) 0.04V (Vol) -----no speakers on this monitor
      8) 1.75V (Mute)
      While on
      all other pins are the same values except
      5) 3.12V (on/off)
      Brightness voltage is the same
      • teri3s
        • Oct 2011
        • 25
        Not even sure how to explain the testing of the mosfets. Pretty much every combination has the display unchanging from '1' except with ohms set at 200k, with the black probe at S1 and the red probe at D1 I get a number that keeps ascending. I tried discharging the gate with my finger first, but right now the number is 33.5 ohms ascending.
        The behaviour of both mosfets is identical, seemingly synchronized.
        • retiredcaps
          • Apr 2010
          • 9271
          Okay, let's do another simple test.
          Hookup a working computer displaying your favourite wallpaper to the lcd. Do you see the wallpaper even briefly? If you turn off all the lights and shine a flashlight onto the lcd, do you see the wallpaper?
          • teri3s
            • Oct 2011
            • 25
            Okay, um.............tried a few times to make sure......and I'm not seeing anything displayed on the screen while shining the flash light on it in the dark.
            • retiredcaps
              • Apr 2010
              • 9271
              #26
              Okay, here is what we have tested so far and looks okay.
              1) n channel mosfets do not seem shorted
              2) picofuse is good
              3) inverter transformer readings (secondary) are good
              4) secondary inverter voltages are present (the 17.x V DC seems correct - each manufacturer/board varies).
              The only thing I can think of is the 16 pin IC on the back of the board. What is the part number of that chip?
              • alexanna
                • Mar 2010
                • 1346
                #27
                2) picofuse is good
                The messy white gray screen mentioned in the first post is interesting; its making me think there may be more than 1 problem.
                The backlight on and dim voltages look to be correct, so I am wondering why no backlights?
                I see a couple of jumpers on the back side of the power supply J509 and 510 that the solder looks bad. One of those could be power or ground to the 16 pin backlight controller.
                Hopefully there will be a data sheet on the 16 pin controller.
                • teri3s
                  • Oct 2011
                  • 25
                  #28
                  That 16 pin IC is difficult to read, it looks like OZ9938GN. Googled it to see what would come up and came across this
                  Pin 2 (VDD based on the datasheet) to ground reads as 240 ohms.
                  OZ9938GN Datasheet
                  • alexanna
                    • Mar 2010
                    • 1346
                    #29
                    This shouid be the data sheet.
                    never mind you found it
                    • Rtech
                      • Jul 2010
                      • 1095
                      #30
                      Would you expect a voltage on the brightness pin, when the unit is NOT switched on,and then does not change when it is switched on ???,I have not seen this Monitor, but the Dim/Brightness voltage comes from the Logic on a lot of monitors, is that not the case here then ??
                      • PlainBill
                        • Feb 2009
                        • 7034
                        You seem to be missing a couple of points.
                        1. Most monitors combine all control functions into the graphics processor.
                        2. The processor is always 'on'; the power required is minimal - the backlight and the display panel consume the most power.
                        3. The brightness is set by the output of a D/A converter. Once set, no additional processing is required to maintain it.
                        4. Whether or not the brightness voltage is maintained when the monitor goes into standby is at the whim of the programmer. Clearly, it must be set when the monitor comes active; it isn't clear that turning it off serves any useful purpose.
                        PlainBill
                        • Rtech
                          • Jul 2010
                          • 1095
                          #32
                          Bill, thanks for that, unfortunately I misread Post 22,must be having one of those Blonde,but rapidly turning Grey days ...
                          • teri3s
                            • Oct 2011
                            • 25
                            #33
                            Hrmmmmm.......I've been running some tests on the OZ9938GN chip and it seems to demonstrate some odd behaviour. Elsewhere I found someone recommending grounding either the 'Timer' on Pin 3 or the 'Overvoltage Protection' on Pin 7 to test if the problem is the backlight tubes, the inverters or the IC.
                            After ground Pin 3 or Pin 7 the voltage reading from VDDA (supply voltage input) Pin 2 was 3.14V. (With the monitor 'off' the reading is 2.41V) Backlight still was not on and transformers were not getting warm.
                            I unplugged the monitor and then after plugging it back in and turning on, testing VDDA again the voltage wouldn't rise above ~2.6V.
                            Pin 10 the ON/OFF control of the IC was hovering around ~2.8V.
                            I was puzzled so I cycled the power and so on. Still same results. I put my finger on the IC and it seemed to be a bit warm now.
                            Checking the No. 6 pin (Brightness) at CN801 it remained at ~2.41V.
                            I'm letting the chip cool and will try it again to observe its behaviour.
                            Edit:
                            After letting it cool, not grounding any pins, the reading from VDDA is 3.42V, Pin 10 On/Off 3.1V
                            After about 10mins the readings from the IC were still the same. But checking CN801 Pin 1 and 2 VCC5v read 4.83V. So I found that weird and switched the monitor off. I checked VCC5V and it was now reading 5.03V.
                            Switching the monitor back on the IC's VDDA remained at ~2.6V and the On/off pin 2.9V.
                            CN801's VDD5v pins read 4.83V.
                            Power cycling the monitor from its switch and unplugging don't seem to change this behaviour. Only after unplugging it for several minutes does it seem to let OZ9938 come "on".
                            • alexanna
                              • Mar 2010
                              • 1346
                              #34
                              What voltage rating are the capacitors in the inverter area?
                              Did you re-solder those jumpers?
                              Are you seeing above 12 volts at the inverter fuse?
                              • teri3s
                                • Oct 2011
                                • 25
                                #35
                                Which one is the inverter's fuse?
                                • alexanna
                                  • Mar 2010
                                  • 1346
                                  #36
                                  F802 on the top of the P/S
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    VDAA (pin 2) is very low. Recommended voltage is 4.5-5.5 volts.
                                    PlainBill
                                    • teri3s
                                      • Oct 2011
                                      • 25
                                      #38
                                      It started doing something weird where one rail would get sufficient power and the other wouldn't. Power LED going amber if there was 5V on the 5V rail, but then the 18V rail (or whatever its supposed to be) would drop to 17 something volts.
                                      Then sometimes when you cycled the power, the 18V rail would be sufficiently powered and the power led would go blue, but the 5V would be under 5V. Now the power LED went off completely and the voltages across the board are just haywire, fluctuating rapidly but far below what they should be.
                                      All in all its beginning to sound like the other stories about bad caps. I probably just caught it early on or something.
                                      Unfortunately getting replacement caps around here isn't so easy, so I'll have to wait a while. The monitor wasn't even used that much before having this issue.
                                      E-caps from inverter side:
                                      Samxon GK(M)
                                      2x 420uF 25V
                                      1x 1000uF 10V
                                      Su'Scon
                                      1x 470uF 10V
                                      Lelon H823(M)
                                      1x 1000uF 25V
                                      • teri3s
                                        • Oct 2011
                                        • 25
                                        #39
                                        I just plugged in the power board by itself and smoke started emanating from that transformer (T502) on the bottom left side. I noticed it getting warm yesterday.
                                        Recommendations?
                                        • teri3s
                                          • Oct 2011
                                          • 25
                                          #40
                                          Nevermind, it was both N-channel mosfets U501 and U502 trying to basically melt
                                            Acer Chromebook 12" HD+ screen, Intel Celeron, 4GB RAM, 32GB Hybrid (2-in-1) Spin 512 Specification for Upgrade or Repair
                                            This specification for the Acer Chromebook 12" HD+ screen, Intel Celeron, 4GB RAM, 32GB Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 12" HD+ screen, Intel Celeron, 4GB RAM, 32GB boardview and 12" HD+ screen, Intel Celeron, 4GB RAM, 32GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                                            09-06-2024, 04:40 PM
                                          • harp
                                            White screen repairs
                                            by harp
                                            To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                            Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                            On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                            05-13-2024, 03:43 AM
                                          • DaniK
                                            Acer Aspire E5-574-52RH - black screen
                                            by DaniK
                                            I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                            Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                            Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                            Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                            The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                            Symptoms are:
                                            - random black screen after displaying Acer logo...
                                            02-21-2024, 06:27 AM
                                          • rybby
                                            Acer Aspire 5 A515-51 power on but black screen
                                            by rybby
                                            I have an acer aspire 5 a515-51 that turns on but has a black screen.
                                            This laptop has the same symptoms as https://www.badcaps.net/forum/showth...er+aspire+a515, however mine is a different model Acer Aspire A515-51 (without the 'G'). There is no onboard ram on this laptop.
                                            Description of the problem is the same: I press the power button, the fan spins for a few seconds and then stops, the computer stays on all the time (led blue), the cpu and gpu are lukewarm. If I leave the pc on for a few minutes the fan starts...
                                            06-16-2023, 09:41 AM
                                          • EazyBone
                                            Sharp LC-65Q620U White Screen
                                            by EazyBone
                                            Another TV topic!!
                                            I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                            The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                            Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                            08-21-2024, 12:56 PM
