Acer x223w first white screen, now no backlight
  • teri3s
    • Oct 2011
    • 25
    Yesterday, monitor was in use for a few hours then screen just turned white. I could still see a bit of the video I was playing showing through. Tried unplugging power, plugged back in...same issue. Screen was a messy white and grey.
    When I turned it on, it would come on, with blue led "on light" on keyboard, switch to amber with screen going black, then back on with the messy white.
    Took monitor apart, disconnected input board, plugged back in a few times, turned on, and screen was completely white as though the backlight was up to maximum intensity. Started checking the voltages, they seemed alright. Turned monitor on again later after combing online for similar issues. Backlight no longer came on, couldn't see anything on screen.
    At present I get no voltage readings from inverter side of board.
    I am a novice when it comes to the intricacies of component testing, so any advice is appreciated.
    Edit: right now when hook everything up, and turn it on, the led goes from amber to blue and stays blue.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Acer x223w first white screen, now no backlight
    1) Excellent photos. It helps a lot in troubleshooting.
    2) On CN801, what are the voltages for all the pins?
    3) On the logic board, there is a voltage regulator at U106. What are the voltages for all 3 pins with respect to ground?
    4) Check picofuse F802 (yellow fuse near top of board on the inverter side). A good fuse should measure less than 1.0 ohms.
    --- begin sig file ---
    --- end sig file ---
    • teri3s
      • Oct 2011
      • 25
      Thank you retiredcaps, I was a bit nervous about the pics had to retake them and then started worrying about the long shadows.
      I just noticed that when I touch the black lead to ground and the red lead to the heatsink next to CN801, the voltmeter is reading minus 75V. The other heatsink registers no voltage.
      2) CN801
      1. VCC 5V (reads 5V)
      2. VCC 5V (reads 5V)
      3. GND
      4. GND
      remaining 4 pins (in order, on/off, Brightness, Vol, Mute) read zero volts.
      3) U106 (Logic Board)
      Pin 1 reads 0 volts
      Pin 2 reads 3.2 volts
      Pin 3 reads 4.7 volts
      4) F802 (Inverter Side of PSU)
      Reads below 1.0 ohms (using a DMM and an analog)
      • retiredcaps
        • Apr 2010
        • 9271
        I believe that heatsink is "live". It is attached to the power mosfet. I'm guessing your ground was probably on the cold side, that is why you get -75V reading.
        Do you get any DC voltage reading across F802? If yes, what is it?
        • teri3s
          • Oct 2011
          • 25
          Across F802 I get +5V
          The jumper above, "J808" I get +17.6V
          • retiredcaps
            • Apr 2010
            • 9271
            U501 and U502 are n channel mosfets. Thanks to the excellent photo, I can read the part number. The datasheet is at
            http://pdf1.alldatasheet.com/datashe.../AP9971GD.html
            Check for shorts between S1-D1, S1-G1, and D1-G1. Do the same for the "2"'s. See the datasheet for the proper pin orientation.
            Any resistance reading below 30 ohms suggest it may be shorted. Report all readings.
            • teri3s
              • Oct 2011
              • 25
              Alright retiredcaps, will do. Also, a sincere thank you for all the help thus far.
              • pedro
                • 199
                • AUSTRALIA
                Did you really mean "across F802"? If so, that's a problem ...
                Friends don't let friends buy Samsung ....
                • teri3s
                  • Oct 2011
                  • 25
                  Not sure what you mean pedro?
                  • teri3s
                    • Oct 2011
                    • 25
                    I am not sure what I'm looking for exactly in terms of ohmmeter readings while checking for shorts so I'll just post what I found and if I say anything stupid.......well please bear with me lol.
                    Am I supposed to desolder these devices to test them?
                    But in the meantime, using an analog meter, when I touch the probes to S1 and D1 it goes from near 0ohms and then gradually falls back to infinite ohms.
                    D1 and G1 it goes from about 50 ohms and the needle falls back to infinite resistance.
                    S1 and G1, the needle stays at about 50 ohms (or the middle of the scale).
                    This goes for both mosfets.
                    When the power button is off, I get 17.7V at U501 and U502.
                    When the power button is on, I get 18.0V at U501 and U502.
                    • PlainBill
                      • Feb 2009
                      • 7034
                      This may be a communication problem. When I hear 'Across F802 I get +5V', I interpret it to mean that you put one probe on one end of F802, the other probe on the other end of F802, and read 5 volts. The only way that can occur is if F802 is open. And that is a problem, because when a fuse goes open it is usually because something has failed (shorted).
                      PlainBill
                      • teri3s
                        • Oct 2011
                        • 25
                        Thanks for that PlainBill. Yeah, I got an inkling that "across" would cause confusion.
                        The picofuse is not open. It reads nearly 0 ohms when the probes are placed at opposite ends. No voltage registers if probed "across".
                        If I go from a ground point to the picofuse I get the 5V reading.
                        • PlainBill
                          • Feb 2009
                          • 7034
                          Yeah, that makes more sense. It's a nasty area, because when I see 'At the fuse' I wonder 'which side of the fuse?'
                          PlainBill
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            Generally in order to get an accurate reading, yes. However, I usually test "in circuit" first and if the readings suggest a short, then I desolder to verify.
                            What about the "2"s? S2-D2, S2-G2, D2-G2?
                            On the analog meter, what scale is your dial set to? 1x? 10x?
                            • teri3s
                              • Oct 2011
                              • 25
                              Scale was set to 10x
                              The "2's" displayed the same pattern.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                Hmm, I wondering about the 50 ohms and wonder if it could be shorted? If you can, desolder the chip and retest out of circuit.
                                Before you do that, please measure the resistance between the yellow dots and the red dots. Report both.
                                You are measuring the resistance of the inverter transformer secondaries. Do this with power off. I don't need any voltage readings from this area.
                                • teri3s
                                  • Oct 2011
                                  • 25
                                  With Rx10 setting on analog, about 500 ohms at both the red and yellow dots.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    Both those readings look good.
                                    The 50 ohm reading is still suspicious to me. You may want to desolder and retest them just to be sure.
                                    • alexanna
                                      • Mar 2010
                                      • 1346
                                      It looks like there may be a voltage missing on the signal card, for the backlights to come on the great majority of monitors there will be around 3 volts on the backlight on pin.
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        Good catch. I totally missed that.
                                          Acer Chromebook 12" HD+ screen, Intel Celeron, 4GB RAM, 32GB Hybrid (2-in-1) Spin 512 Specification for Upgrade or Repair
                                          This specification for the Acer Chromebook 12" HD+ screen, Intel Celeron, 4GB RAM, 32GB Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 12" HD+ screen, Intel Celeron, 4GB RAM, 32GB boardview and 12" HD+ screen, Intel Celeron, 4GB RAM, 32GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                                          09-06-2024, 04:40 PM
                                        • harp
                                          White screen repairs
                                          by harp
                                          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                          05-13-2024, 03:43 AM
                                        • DaniK
                                          Acer Aspire E5-574-52RH - black screen
                                          by DaniK
                                          I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                          Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                          Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                          Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                          The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                          Symptoms are:
                                          - random black screen after displaying Acer logo...
                                          02-21-2024, 06:27 AM
                                        • amennone
                                          Acer A315-24p-r2km , black screen. Bios
                                          by amennone
                                          Acer A315-24p-r2km Acer N23C3 snid: 32400005934 s/n NXKDEET00B3240003B3400 Main: IH5JM LA-M611P Rev: 1A
                                          As per the title, the screen remains black. When the power button is pressed, the blue LED lights up, but the screen is black.
                                          With an external monitor and HDMI output, there is no image. I loaded the following bins, same situation: ACER_A315_24P_IH5JM_LA_M611P_REV_1A_2022_08_22_WORKING_BIOS_100% IH5JM120.bin from this address https://www.badcaps.net/forum/troubl...a-m611p-rev-1a With the RT 809F programmer, I can't read the contents of the original XMC 25QU128CH1Q SPI, I get the...
                                          07-31-2025, 04:19 PM
                                        • DeXXter
                                          [Question] Acer nitro 5 image on HDMI without screen
                                          by DeXXter
                                          Hello, I was offered an acer nitro 5 motherboard (i5 10300h + gtx 1650) and I have this little question, is it possible to just connect this motherboard through hdmi and have picture and access the bios without the drivers and windows? because I don't have the display for this one.
                                          I had an old acer with ryzen 2500u without display that was able to access the bios using hdmi only, but with this intel model I don't know. So it would be appreciated if someone knows if this is possible.
                                          Thanks!
                                          09-25-2025, 09:48 PM
