HFE and Testing
  • killian6pk
    • Apr 2010
    • 502
    HFE and Testing
    I have an autoranging DMM that has a spot to put transistors labeled hfe and with a hole for: base, collector, emitter and collector and on my selector switch there is an hfe setting. Two questions. Is this sufficient to test these transistors and mosfets? Reading wise if I get a reading that falls within the minimum and maximum ratings on a Data Sheet for that transistor etc. does that mean that these are not shorted and are ok?
    Have you ever stopped to think and then forget to start thinking again?
    As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
  • PlainBill
    • Feb 2009
    • 7034
    Re: HFE and Testing
    Hooo, boy!!! Lots of good questions, let's see if I can come up with some good answers, and tehn elaborate some more.
    1. That is one method of testing a bipolar (base, collector, emitter) transistor. Mosfets work on a different principal, and this tester may not give meaningful results.
    2. If a transistor is rated at a beta of 400-650 and you get a reading in that range, the transistor is good.
    Now for the comments. Using this feature of your dmm is overkill in most cases. The only exception in monitor repair would be if you suspected you had a bad (low hfe) lot of 2SC5707 transistors (used in the inverters in Benq, Dell, and HP monitors).
    A simple base-collector, base-emitter, collector-emitter resistance check will find any shorted transistor without the need of pulling it from the circuit board. There are a very few cases where the resistance test will give a false 'bad' reading - chiefly on the horizontal output transistor of CRT monitors. If your DMM has a diode test function, a simple base-emitter, base-collector test will ensure you aren't dealing with an open transistor.
    PlainBill
    • killian6pk
      • Apr 2010
      • 502
      Re: HFE and Testing
      Thanks Plain Bill you are always johnny on the spot with your answers. I appreciate it and I know everyone you help appreciates it also. I don't know how your read my mind, but the 5707 is what I was thinking about when I asked this question. I have one of the Dell/BenQ 172fpb 17" monitors that I decided to try to work on and that was the part I knew was bad sometimes. So add mind reading to your many other abilities.
      • retiredcaps
        • Apr 2010
        • 9271
        Re: HFE and Testing
        These Benq boards have well known documented problems. Check c5707s, fu9024, and the picofuse. Resolder all the inverter transformer pins.
        --- begin sig file ---
        --- end sig file ---
        • Mikeley
          ESR Man
          • Oct 2010
          • 41
          Re: HFE and Testing
          I had one of these today with one shorted 5705. I always replace the 5707's in pairs due to lot to lot variation in transistors which can cause failure upon replacement. Both transistors in the royer need to be close gain wise. fu9024 and fuse were fine but will be testing it before it goes back together.
          While I'm waiting on deliveries, I re-soldered all traffo, caps, trannies, diodes, links inductors etc on the inverter and also replaced 2 1000uF 10V caps(ESR >> than spec). All others had excellent Capacitance and ESR... so brazenly I have left them in! Will be picking it up again after the Ireland v's Wales rugby tomorrow morning! Come on Ireland!
          • tvguy12012012120
            by tvguy12012012120
            02-07-2025, 05:13 PM
          • acedogblast
            [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
            by acedogblast
            First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
            Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
            03-01-2023, 08:24 PM
          • redbaron1007
            Onkyo HT-R510 turns on and then immediatly off
            by redbaron1007
            I picked up an Onkyo HT-R510 that when I plug it in and press the power button will turn on and then a couple of seconds later turn itself off. When it turns on you can hear the relay click and then immediately click again and shut the power to the system off. I spent about 5 hours today trying to troubleshoot it and I did make some progress that may not actually tell me anything. It's still not really working and I'm not quite sure where to go next.
            Here's everything I've done so far.
            The first thing I did was open it up and check for any burn marks exploded parts...
            11-14-2021, 09:55 PM
          • bauto601
            KDM 480W PSU upgrade succes! (opinions?)
            by bauto601
            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
            A "nice" YoungYear unit? - Badcaps
            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
            12-26-2023, 03:05 PM
          • redbaron1007
            Sundown SFB-8000D What are these transistors?
            by redbaron1007
            I had a Sundown SFB-8000D amp come into the shop yesterday that wasn't giving any output. The guy who brought it in said he bought it off some crack head on Facebook marketplace for a good price, but bought it knowing it was broken. Apparently the original owner was cutting out the transistors to the right of the ones pictured whenever one would blow and take the output out. Best I can figure he also cut the legs on the S5 and S6 ic's as well and soldered them back together.
            My problem is Sundown decided in the factory to remove the original markings on the IC's and now I can't figure...
            11-12-2023, 07:30 PM
