Thank you for any help here-I am trying to get this Samsung SyncMaster 914V back to life here and need some help. I have replaced most of the caps because I was losing the display after the system booted into Windows. After replacing the caps I seem to have corrected the drop out problem but now all I get on the display are straight vertical lines up and down the screen. Any suggestions would be greatly appreciated. Thank you.
Samsung SyncMaster 914V-No Display
Re: Samsung SyncMaster 914V-No Display
What color are the lines?Whatever I do, I consider it a success, if in the end I am breathing, seeing, feeling and hearing! -
Thank you for your time on this. Originally the screen would come up while Windows booted. The Win 7 logo would appear and the program would load. Then the screen went blank after about a minute. I changed out the capacitors near the rear or the PCB. There were 7 total. That seemed to correct the phase out problem but now the screen just has straight vertical lines-no colors-just B&W.They are in rows about 2" wide. Some parts of the screen are just black. Hope that helps--Thank you again for your time and inputComment
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by ChrissygizmoHello everyone, I’ve just been given a Samsung UE55JU6800K smart tv as it had white spots on the screen due to the led lenses falling off. After refitting them & putting the tv back together I thought it was a nice easy fix for a free bedroom tv , then I tried it before screwing the back into place. I realised that the right side of the screen was darker than the other side, I removed the screen again as I thought the backlights had failed but they are fine.
I put the screen back in place & turned it back on . The screen seemed to be ok again but different screens on the same... -
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...09-06-2024, 09:30 PM
- Loading...
