Samsung SyncMaster 914V-No Display
  • fasner
    • Sep 2011
    • 15
    Thank you for any help here-I am trying to get this Samsung SyncMaster 914V back to life here and need some help. I have replaced most of the caps because I was losing the display after the system booted into Windows. After replacing the caps I seem to have corrected the drop out problem but now all I get on the display are straight vertical lines up and down the screen. Any suggestions would be greatly appreciated. Thank you.
  • alexanna
    • Mar 2010
    • 1346
    Re: Samsung SyncMaster 914V-No Display
    Do you know if the problem with the screen was there initially? Or is this a new problem?
    What color are the lines?
    • fasner
      • Sep 2011
      • 15
      Thank you for your time on this. Originally the screen would come up while Windows booted. The Win 7 logo would appear and the program would load. Then the screen went blank after about a minute. I changed out the capacitors near the rear or the PCB. There were 7 total. That seemed to correct the phase out problem but now the screen just has straight vertical lines-no colors-just B&W.They are in rows about 2" wide. Some parts of the screen are just black. Hope that helps--Thank you again for your time and input
      • alexanna
        • Mar 2010
        • 1346
        Make sure you have the ribbon from the signal to the panel installed correctly.
