Fixed Hanns-G HC174D
  • newmike
    • Sep 2011
    Thanks to confidence gained by reading posts on these forums I dived in and repaired my Hanns screen above. Prior to repair it got progressively slower to show anything on the screen and while waiting the power light would flicker.
    So I removed 6 CapXon caps (board component numbers given) which all had swollen tops and replaced with Maplin.co.uk 105degc cap numbers given at end of lines:
    C261 C263 & C24 = 470microF 25V dia 10mm H 15 pin pitch 5 with maplin #DT66
    C244 & C241 = 1000microF 10v dia 10 H 15 pin pitch 5 with #DT69
    C?? = 470microF 10v dia 8 H 13 pitch 3.5 with #N90KF
    How chuffed do I feel!
  • karatzdi
    Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
    by karatzdi
    I know some might say... just buy another one. Sell it as parts..!
    So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
    Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
    Spent some time downloading the Service...
    06-11-2024, 08:38 AM
  • howardc64
    Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
    by howardc64
    TV was fixed just after removing Samsung's rear snap cover.
    This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
    Maybe PSU->backlight connector didn't have a good contact?...
    07-23-2025, 12:34 AM
  • howardc64
    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
    by howardc64
    Failure Symptom
    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
    Where is the short?
    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
    05-27-2025, 02:56 PM
  • RetroComputingGrotto
    Viewsonic VA2010wb (High Pitch Squeal At Power On)
    by RetroComputingGrotto
    I've got a monitor on my workbench at the moment that makes a high pitch squeal (that I cant hear as my ears are too old) when you power it on and lasts a couple of seconds before quitening and apparently it can be heard at regular intervals whilst on.
    On opening up the monitor and looking at the PCB the usual suspects showed their heads so I have already replaced all the electrolytic capacitors.
    The other issue that was reported with this monitor was the fact it took ages to start displaying anything after pressing the power button.
    What component(s)...
    02-03-2025, 06:00 AM
  • howardc64
    LG 55UN7000PUA fixed with just dis/reassembly
    by howardc64
    TV runs, backlight on, have sound and no image (dark grey/blue/black LCD)
    Disconnected right (looking from rear of TV) tcon-buffer board cable, LCD left half displays.
    No shorts on right buffer board.
    Started masking tcon-buffer board signals... (connection #1 in main board pic) about 20+ pins from top of connector... LCD fully displays with some anomalies.
    Gradually reduced # of masking signals... eventually down to 1. Removed that... LCD works perfectly.
    No obvious damage on right buffer board 3x COF to the panel like another 43" LG fixed ( link ) with...
    09-19-2024, 11:16 PM
