fpd2485w/lp2407 on screen display problem
  • tgrhp
    • Aug 2011
    I have followed some of the threads from this forum and replaced broken capacitors on the power and inverter board, and 3 voltage regulators [1 on usb and 2 on video input board] on my fpd2485. This fixed 2 problems of mine: unreliably turning on, and able to detect signal after a period of no signal [eg. waking computer from sleep].
    However, after I changed the broken caps, but before I replaced the voltage regulators, the monitor suffered a power surge during an electrical storm. Now all of the on screen display is extra wide. The gateway logo and menu are both stretched horizontally and ugly. Everything else seems to works fine. vga and dvi inputs are normal and not stretched.
    Also in the process of replacing the parts, my touch panel has stopped working. No lights or response. I am wondering if others have been able to fix this by replacing the ribbon.
    Any help would be appreciated.
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
  • Chrissygizmo
    by Chrissygizmo
    02-10-2025, 12:33 AM
  • spice_disc
    Vizio TV M50-C1 reboot cycle and static on screen
    by spice_disc
    I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
    The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
    09-08-2024, 02:37 PM
