This Viewsonic VA2026W needed one capacitor replaced
  • lkvee
    • Feb 2009
    • 198
    Got it from Freecycle with power and brightness issues when turned on. My Google-fu didn't turn up a specific solution, so I'll post one here to document what I've done.
    I replaced one bulging Samxon capacitor at 1000uF. If it wasn't specified for 10V, then it was specified for 16V.
    I hope this fix will last, but I'm ready to replace more capacitors, too.
  • ipman
    • Jul 2011
    • 159
    Re: This Viewsonic VA2026W needed one capacitor replaced
    Caps nearby heatsinks have a hard life. Anyway, harder than those in cool well-ventilated spaces.
    If you want to keep the device for a long time, it may worth recapping some other caps like the biggest one.
    • jetadm123
      • 2169
      With the exception of the large 450V cap, replace ALL the other small caps with low-esr caps such as Panasonic FR, FM or FC series caps.
      • ipman
        • Jul 2011
        • 159
        Ops, sorry, not the biggest one filtering HV.
        • im_trying
          Dell Latitude 5310 2 in 1 Laptop does not power on, shorted capacitor replaced but not solved
          by im_trying
          Laptop does not power on but has a fix white light on power button, when connected to power.
          I found, while trying to diagnose, a hot spot in the motherboard and found it to be a shorted capacitor (see photo below) on the 2.5v (2D5V_S3 on schematics). After replacing it with one from a donor board, still, the board does not turn on...
          The usb-c meter reads upon connection 20.1v and 0.00a, with some occasional flashes to 0.03amps. After 10/15 seconds circa, it goes to 5.2v and draws an almost constant 0.07amps. (same behaviour as before)
          To my fingers, nothing seems...
          05-08-2025, 12:01 PM
        • veedo
          Asus FA507R no power, capacitor needed
          by veedo
          Hello
          I've got an Asus laptop which received with no power, so I found that one capacitor been damaged. I don't have schematics for that board which is DANJMMB11A0 REV:A
          Without that caps laptop is turning on fine so problem more likely is sorted but I would like to put back the correct one as it should be.
          If any way could help with sorting out specification somehow, I just know that my meter shows 11,2uF but is it 50V or 10V ?? or any others.
          See attached photo off the capacitor, maybe someone have same motherboard and can check it for me please.
          03-24-2024, 01:16 PM
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • chth96
          by chth96
          06-02-2024, 07:31 PM
        • supravit2000
          Sony PS4 ADP400DR - help needed figuring out shorted pads under capacitor C 31
          by supravit2000
          Hi!
          A friend of mine gave me a dead PS5 to look at. I am totally inexperienced, but when a damage is simple (i.e. failed DAP41 on PS4s, etc.), when replacing just the IC and the other very common failing parts of these consoles, problem is fixed. So I checked the voltage of the PSU - none was present. Model is ADP 400DR. I have a bunch of spare parts around, so first thing I did was to replace the IC DAP 053 (they seem quite expensive, so I put a replacement unit - TEA2016AAT. When plugged to the power outlet, 12V did come present.
          So I reassembled the PS5 and pressed the power...
          07-20-2024, 07:26 AM
