245BW, can't find problem. No 24 or 6.3V, standby is good.
  • alexanna
    • Mar 2010
    • 1346
    #61
    Re: 245BW, can't find problem. No 24 or 6.3V, standby is good.
    The 450v 82uf capacitor has failed on this model,what i have noticed when it fails is a severe flickering of the back lights,But I wonder if it could cause other problems?
    Just something to think about.
    • PlainBill
      • Feb 2009
      • 7034
      On this particular supply, I don't think that is the issue. It seems unlikely I could overload both outputs and have it work perfectly if the mains filter cap were bad.
      PlainBill
      • Toasty
        • Jul 2007
        • 4171
        #63
        Samsung 245BW - No 24v or 5.3v - standby is good
        **UPDATE**
        I have received this unit (purchased) from epicelite.
        I recapped the PSU to my specs for caps using HE, FM, FC series'. It eliminates questions down the road. Since there has never been a list made of the originals I was unsure of what was in place when I got this unit.
        I did some Googling and came up with:
        http://www.ccl-la.com/blog/index.php...4-lcd-monitor/
        It is not the same monitor { 2493HM }, but it is the same PSU, BN44-00195A. A list of caps is provided, but the page is done as a graphic so the list and repairs can't be copied (easily). { Hello PaintShop camera mode! }
        { Elektrotanya skips right over this model number in it's BN44- series listing. }
        After recapping, a bench test showed the supply in correct working order as PlainBill had noted when he had it and tested it. BTW: It's 5.3v, not 6.3v as the thread title indicates.
        Reassembled the unit and the symptoms remain. Went to check the inverter and saw no 24v available. The meter would flicker occasionally on pressing the power button, but no significant reading, except that -something- was happening.
        Disconnected the interconnect cable to the Graphics board. Cycled the power and 24v came right up and stayed on the Graphics board connector.
        Shut the unit down and started probing the inverter board with the ohmmeter.
        Found both lower FETs shorted on the board. One D-S, the other G-S.
        An ohms test of the 3 transformers show them to be a match.
        Both FETS are from Anpec and listed as Enhancement Mode types.
        APM4030A - N Channel
        APM4050A - P Channel
        Not available anywhere in the US, but Anpec's site shows them as in current production.
        A suitable replacement could likely be found by datasheet-to-datasheet comparison, but I became bleary-eyed after the 6th sheet and went browsing.
        Found a salvaged inverter for cheap from a different model monitor { LS24HUBCFL }, but again, the board is the correct number, BN44-00163B.
        I figure that either I will get a working inverter or at the least the 2 FETs I need to finish this one.
        The question remains: What caused the FETs to blow in the first place?
        Both inverter onboard caps test good in ESR, value, leakage.
        The fuse is intact and the board shows no darkening from overheating.
        Toast
        veritas odium parit
        • Toasty
          • Jul 2007
          • 4171
          #64
          Caps List for BN44-0195A power supply Samsung 245BW :
          MAXIMUM HEIGHT = 25mm
          There is sufficient room around the caps that a 12.5mm can be used where a 10mm was, or a 10mm for a 8mm, etc.
          Mains (original to board) cap was not replaced. Tested good in ESR, value, leakage.
          CB804 - 22 / 50
          CB805 - 2.2 / 50
          CB806 - 47 / 50
          CB809 - 47 / 50
          CB812 - 47 / 50
          CB853 - 2200 / 10
          CM814 - 10 / 50
          CM851 - 1000 / 35
          CM852 - 1000 / 35
          CM855 - 470 / 35
          CM857 - 1000 / 10
          CP801S - 82 / 450 { ~30mm diameter, 20mm height }
          CP804 - 10 / 50
          13 caps
          I'll get some drawings and photos up when I can.
          Toast
          veritas odium parit
          • Toasty
            • Jul 2007
            • 4171
            #65
            ** UPDATE **
            Inverter board was received and installed. Unit now works very nicely.
            Awaiting some caps to redo the Video/Graphics board as kc8adu pointed out issues with the 225BW he has.
            I investigated mine and found some widely varying ESR readings on identical caps... 'nuff said!
            See Page 24 of this thread:
            https://www.badcaps.net/forum/showth...t=6930&page=24
            veritas odium parit
            • Yaaman
              • Jan 2014
              • 30
              #66
              Hello
              I know this is old topic but I've got very similar issue with exacly the same power board and I'll need your help.
              Blue led is solid, I can power on/off. I have no 5.3V and 24V.
              What I've done so far:
              - I recaped all electrolytic capacitors - Rubycon ZL, YXF, Panasonic FR (are they no good?) and FR and large Chemi-Con KXG (good enough?)
              - I changed two shorting transistors: QM802 and QM803
              - I removed yellow glue
              I measured voltage on ICM801:
              Pin 4 as ground
              1 - 4.27V
              2 - 4.27V
              3 - 2.66V
              5 - 5.10V
              6 - 3.21V
              7 - 3.21V
              8 - 5.08V
              9 - 14.55V
              10 – 0.2V
              11 - 4.98V
              12 - 6.88V
              13 - 0.00V
              14 - 7.08V
              15 - 14.98V
              16 - 2.58V
              ICB801S
              Pin 3 as ground
              1 - 24mV
              2 - 16.50V
              4 - 1.21V
              5 - 390V
              And few more:
              5.3V - 0.47V
              24V - 48mV
              Standby – 5.29V
              PSON – 3.25V
              Big Cap – On – 390V Off – 330V
              What would be my next step?
              • Yaaman
                • Jan 2014
                • 30
                #67
                Sorry first listed Panasonic is EB (are they no good?).
                • selldoor
                  Slow Learner
                  • Dec 2010
                  • 7870
                  #68
                  So have you checked out the inverter board as per toasty
                  • Yaaman
                    • Jan 2014
                    • 30
                    #69
                    Yes. Non of the FETs are shorting.
                    U5 - 4.73K
                    U3 - 10K
                    U4 - 10K
                    U6 - 4.71K
                    Fuse F1 not blown
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      #70
                      So - if you unplug the inverter board does the 24v come up on the power supply?
                      • Yaaman
                        • Jan 2014
                        • 30
                        #71
                        No, only 35mV. But when I keep the probes on it's going slowly up to about 47mV.
                        • Toasty
                          • Jul 2007
                          • 4171
                          #72
                          Check the long blue cap as in post #46.
                          Check the power resistors in the drains(?) of QM802/803. One mounted horizontal next to long blue cap and one vertical.
                          Make sure you are measuring from ground on the correct side for the 5.3v & 24v. Once you cross the fat white line and cuts in the board you are on a different circuit.
                          On the foil side, check the SMD components on the COLD side between the large transformer and the connector for the 5.3v standby. This would be near the optoisolators. (See attached pic.) I have found SMD resistors burned and a transistor there also. Use some good light and magnification to carefully inspect (jeweler's loupe).
                          A clear, well lit photo of that area would help.
                          If you follow the 24v circuit from above the transformer to the connector/area for the 5.3 & SB voltage, there is a wire jumper that you can lift one side of and see if the 24v comes up. ( J830 ? ) If it does, the fault is in the section near the opto's, as I mentioned.
                          There is a "balance" circuit used here that looks at the 24v & 5.3v. (2 zener's and a dual diode) If either one goes too far out of spec (high or low) it causes one of the opto's to send a signal to the shutdown pin on IC801S.
                          T
                          veritas odium parit
                          • Yaaman
                            • Jan 2014
                            • 30
                            #73
                            Both QM802/803 are brand new.
                            I haven't got correct value to replace 12nF blue cap. Closest value I've got is Wima MKP 100nF 400V. This is almost impossible to buy in the UK. Only Farnel has it but minimum order of £20 apply :/
                            All SMD transistors and resistors in the section you mentioned seems to be ok. I will attach pic in few minutes.
                            One more I think important information. The input voltage on the large transformer is 0V.
                            • Yaaman
                              • Jan 2014
                              • 30
                              #74
                              A picture you asked for
                              • Toasty
                                • Jul 2007
                                • 4171
                                #75
                                RT852 looks blown. Same appearance as in my pic above. IIRC it's a 100Ω.
                                T
                                veritas odium parit
                                • Toasty
                                  • Jul 2007
                                  • 4171
                                  #76
                                  <<Both QM802/803 are brand new.>>
                                  I know that. I'm saying check the power resistors right in front of them. Usually they go when one or the other FETs blow. Current limiters (fusible resistors).
                                  veritas odium parit
                                  • Yaaman
                                    • Jan 2014
                                    • 30
                                    #77
                                    Oh yes, the power resistor is blown. That was the very first component I checked but I can swear it was good. Strange... ok I'll replace it and I'll report.
                                    Oh yes RT852 shows 168R.
                                    • Yaaman
                                      • Jan 2014
                                      • 30
                                      #78
                                      Closest value I'got at home is 1.4R 5W. Do you think it would be ok just for tests?
                                      • selldoor
                                        Slow Learner
                                        • Dec 2010
                                        • 7870
                                        #79
                                        @Toasty If he needed to rplace the Long Blue cap could he use one of these?
                                        http://www.ebay.co.uk/itm/PANASONIC-...=e100084.m1843
                                        • Yaaman
                                          • Jan 2014
                                          • 30
                                          #80
                                          Good shot. I didn't find it because it is not in caps category. Thanks.
                                          Hopefully I won't need it and the new RT852 will sort it out.
                                          • temyth
                                            Sentey ATX PSU - ERP650-PS - Trying to find out the right Standby IC
                                            by temyth
                                            Greetings! I have this ERP650-PS atx power supply, it is a relatively simple psu, the primary has a driver IC that controls the two main mosfets (two 20n60S5), together with a Classic Standby circuit with a PWM IC (not a FET like the VIper22A) , relatively similar to the SDC606P.
                                            The whole point is that I got this power supply years ago when I had no knowledge, apparently the PWM IC was burned because someone turned the power supply on with the switch at 110v in a 220v network (classic error). Important detail: the power supply at the time came without the primary capacitors.
                                            01-07-2024, 04:50 PM
                                          • gugutm
                                            a1989 820-00850 stuck at 5v 0.041a Help
                                            by gugutm
                                            I'm new to the forum,sorry english is not my first language too, i got a basic plus knowledge, but now i am in this situation where i need some help , i spend good few days reading forums , here and outside , to help my problem solve, with no luck
                                            long story short, i bought macbook pro a1989 820-00850, clean no water damage which was stuck on 5v 0.200/300a i read a lot of forums what that could be , it indicated to faulty corrupted t2 rom
                                            of course before jumping to conclusion and connected to DFU , i believe i done basic checks...
                                            01-04-2025, 09:35 AM
                                          • psssst
                                            Yamaha TSX 120 Standby Problem
                                            by psssst
                                            Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                            03-01-2024, 07:25 AM
                                          • Yanleb
                                            UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
                                            by Yanleb
                                            My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
                                            Disconnecting the main board from the power supply makes the backlight come ON.
                                            I did disconnect the panel cables and the WIFI modules, the board is still dead.
                                            I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
                                            Thanks.
                                            11-18-2024, 12:34 AM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
