Hannspree HF237
  • ixtlan
    • Aug 2011
    • 12
    Hannspree HF237
    What a forum this is.
    Great info and experience abounds!
    Sorry for the length of this post but I did want to provide details.
    Well that said I have a problem with a Hannspree HF237 monitor.
    I have replaced the caps and still seems to have an issue with 2 seconds on and blank,
    Power led stays lit.
    I have read about the 2 second problem and using a flashlight to see if the backlights are off.
    Dont really understand how to do this to be honest.
    Do I shine the FL into the screen and see if I can see the image?
    Or do I need to get behind the screen?
    From the front I see nothing fyi.
    That newb question asked.
    I have replaced the caps and still have the problem.
    Nothing visually appears damaged or otherwise unusual on the board.
    It will run for hours and then when the power is cycled (reboot or via power switch) it may not come on except for a brief time or not at all.
    If left on it may start working. And may not.
    If it does it will be 5 minutes before it does then it goes blank after a few seconds again.
    It started initially with taking longer and longer to come up.
    This progressed to what it does now.
    At a loss to where to look now.
    Thanks for any brainstorming offered.
    And again apologies for the long post.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Hannspree HF237
    Better a longer post than one with little useful information. (We just love the "I have a monitor itson't work rite tellm e howe to fixit." posts - I just ignore them. Still, you faile to provide a couple of vital pieces of information.
    I've had very little success with using a flashlight. The idea is to hold it at an angle and verify you can see an image on the screen.
    The symptoms are contradictory. A monitor taking longer and longer to come up typically is caused by bad caps. What brand and series did you use? * At the same time, the behavior of the CCFLs sounds like they may be nearing their end of life. when they first turn on, is there a pinkish tinge to the picture?
    Another thing to check is the resistance of the inverter transformer secondaries. A low resistance can indicate shorted turns.
    It's been said, many times, many ways. No , not 'Merry Christmas', but 'Please provide pictures.* One, an over-all view of the internal parts of the monitor showing everything together, then pictures of the top and bottom of the power supply. Please attach them using 'Manage Attachments' - below the text entry area.
    PlainBill
    * = The two things you neglected to provide.
    • ixtlan
      • Aug 2011
      • 12
      Re: Hannspree HF237
      Ok the flashlight explanation helps.
      But I can see nothing at angle or otherwise.
      Next is the Caps.
      Replaced them with Panasonic, Nichicon or Rubycon I purchased as a kit from a reputable supplier who actually refereed me here for further advise.
      When the LCD does turn on it is instantaneous.
      No noticeable pink or otherwise.
      I will need to check the inverter resistances and get back with you.
      Here is a pic of the board.
      I will need to disassemble again to get better ones.
      I want to review the How To for pics also.
      • jsog
        • Feb 2011
        • 220
        Re: Hannspree HF237
        Did you replace the small cap in the center of the board also?
        • ixtlan
          • Aug 2011
          • 12
          Re: Hannspree HF237
          As a matter fact no I did not.
          I overlooked it completely
          50v 10uF brand is Su'scon.
          Is that brand a suspect one possibly?
          • PlainBill
            • Feb 2009
            • 7034
            Re: Hannspree HF237
            Su'scon is a suspect brand - I would say 'replace on sight'. That cap performs a vital function. It's the start-up cap. When it fails the power supply won't start. Of course, it's so small that it doesn't have a vent, so a failure is invisible. And it's inexpensive to replace - under $.50, so I usually replace it unless it is a high reliability brand.
            I recently had a very frustrating experience with a power brick for a 17" LCD TV. The TV would try to turn on, but fail. When the power brick was tested with an external 2A load it worked flawlessly. After substituting another supply for the power brick, the TV worked perfectly. Opening the power brick revealed three 'tier 2' brand (not as good as Panasonic or Rubycon, not as bad as Capxon of Elite) caps whose ESR was borderline high. Replacing them did not fix the problem. The startup cap was buried under a mass of glue. After replacing it, the TV worked perfectly.
            PlainBill
            • jsog
              • Feb 2011
              • 220
              Re: Hannspree HF237
              SUSpect Capacitor Often Nonfunctional ?
              Those little caps do sometimes bulge. FPD1765s have a 220uf 16v 6.3x11.2mm on the processor board that makes a nice little hemisphere dome. Can't recall the brand, might be Sus'con. Didn't save any of them.
              • ixtlan
                • Aug 2011
                • 12
                Re: Hannspree HF237
                I will see if I can find one local and swap it out.
                Will let you know the outcome.
                Little bugger slipped by me.
                Goin blind I guess.
                Thanks for pointing it out.
                • PlainBill
                  • Feb 2009
                  • 7034
                  Re: Hannspree HF237
                  Goin blind I guess.
                  The first time I encountered a bad start-up cap, I saw it, but focused on the obviously bulging output caps. Imagine my consternation when the monitor STILL wouldn't work. Imagine the hours lost until I found the answer here. (Thanks, Mike.)
                  PlainBill
                  • ixtlan
                    • Aug 2011
                    • 12
                    Re: Hannspree HF237
                    Found a cap at the local Radio Shack.
                    It is an axial type and not marked + or - though.
                    One lead was wrapped around the cap.
                    The only markings are 10uF 50 v the brandname nichicon and a series of B P across the body.
                    Is this a non polarized?
                    Will it matter what is pos and neg?
                    How do I tell and can it be used?
                    • jsog
                      • Feb 2011
                      • 220
                      Re: Hannspree HF237
                      I would not use that one. Radio Shack is the wrong place to go, an electronic supply house is better. Or Digikey, if you're able to wait a few days: http://search.digikey.com/scripts/Dk...name=P10316-ND
                      • ixtlan
                        • Aug 2011
                        • 12
                        Re: Hannspree HF237
                        It is a recommended brand so I am not concerned with that so much.
                        Even though it did come from RS.
                        But can I use a non polarized cap in a polarized position?
                        Or if it is a polarized cap, how do I tell what is pos and neg?
                        • jsog
                          • Feb 2011
                          • 220
                          Re: Hannspree HF237
                          Nichicon is a good brand, but they make different series of caps for different jobs. That one is a non-polarized capacitor meant for audio filtering, the wrong type, size, and maybe 85 degree instead of 105 degree. You'd have to bend one lead around and under, insulate it to keep it from shorting to the can, and then worry about whether the cap is too large for the space. Radio Shack doesn't have low ESR caps, although that might not be a big deal for startup caps. Being non-polarized is the least of its problems.
                          • ixtlan
                            • Aug 2011
                            • 12
                            Re: Hannspree HF237
                            It is 85 so I will just fore-go using it.
                            And order one in instead.
                            • ixtlan
                              • Aug 2011
                              • 12
                              Re: Hannspree HF237
                              Finally got back to this.
                              Supplier sent me a new cap to replace the one I blindly missed.
                              I put it today and results are still not good.
                              Some details roundup here:
                              Initial start-up went well and got a screen and it stayed on for over 30 minutes.
                              So that looking good I rebooted the computer.
                              Screen came back on and all looked well.
                              So next step was power cycle the monitor.
                              Did not come back on but power LED was still on.
                              Waited for 10 minutes and screen flashed on for 2 sec and then back off.
                              Turned monitor off and waited 10 min and then back on.
                              Result was got a screen for about 5 minutes then blank.
                              Power cycle monitor and on 2sec and off.
                              I am going for the transformer next.
                              Will ohm it out and post the results prior to change-out to hear your opinions.
                              One step at a time and eliminate as I go I suppose.
                              Too bullheaded to just give up.
                              • PlainBill
                                • Feb 2009
                                • 7034
                                Re: Hannspree HF237
                                Symptoms match what I observed with an aging CCFL. But do check the transformers first - it's a lot easier than checking the CCFLs.
                                PlainBill
                                • ixtlan
                                  • Aug 2011
                                  • 12
                                  Re: Hannspree HF237
                                  Hopefully I can get back to this and ring out the transformer today.
                                  But I got a Dishwasher to fix today.
                                  When it rains it pours...
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    Re: Hannspree HF237
                                    Or in the case of a dishwasher, leaks over the kitchen floors.
                                    PlainBill
                                    • ixtlan
                                      • Aug 2011
                                      • 12
                                      Re: Hannspree HF237
                                      Transformer readings:
                                      Meter set to 20k ohms
                                      Transformer has 4 pins on one bank and 5 on the other.
                                      I assume the 4 pin is the primary (1-4) and the 5 pin is sec (5-10)
                                      Primary
                                      1-2 = 0.00
                                      1-3 = Open
                                      1-4 = Open
                                      2-3 = Open
                                      2-4 = Open
                                      3-4 = 0.00
                                      Any Primary to any secondary = Open
                                      Secondary
                                      5-6 = Open
                                      5-7 thru 10 = 0.00
                                      6 - 7 thru 10 = 0.00
                                      7 -8 thru 10 = 0.00
                                      8 -9 thru 10 = 0.00
                                      9 -10 = 0.00
                                      So I am guessing using my rudimentary electrons skills the transformer is good.
                                      Is this a likely conclusion?
                                      • alexanna
                                        • Mar 2010
                                        • 1346
                                        Re: Hannspree HF237
                                        Primary
                                        1-2 = 0.00
                                        1-3 = Open
                                        1-4 = Open
                                        2-3 = Open
                                        2-4 = Open
                                        3-4 = 0.00
                                        Secondary
                                        5-6 = Open
                                        5-7 thru 10 = 0.00
                                        7 -8 thru 10 = 0.00
                                        8 -9 thru 10 = 0.00
                                        9 -10 = 0.00
                                        The primary will read real close to 0 ohms resistance, secondary side usually will read somewhere between 500 and 1500 ohms, give or take a few.
                                        You may have to remove the transformer from the circuit to make sure your measuring the correct pins.
                                        The primary windings will be the thick ones, and the secondary will be the thin wires. It is recommended that the secondary windings measure within 3% of each other.
                                        • FallenOne008
                                          Asus G712L No Screen Backlight
                                          by FallenOne008
                                          Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
                                          The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
                                          03-31-2025, 08:27 PM
                                        • signal.quest
                                          Samsung LN40C630K1F LCD TV No Backlights and Flashlight Test Fail
                                          by signal.quest
                                          I have been working on a Samsung LN40C630K1F LCD TV. On power up the backlights only briefly light up when first powered on then they go out (2 seconds to black). The flashlight test also fails. The sound works fine. Please see attached pics.
                                          I have researched the forums a lot. I have watched the videos of trying to locate the bad CCFL or transformer and bypassing. I can't find any evidence of a bad transformer/CCFL. I verified I get 376V from the big caps to the fuse. I have used a small/cheap oscilloscope and it looks like the MOSFETs on the inverter...
                                          09-30-2024, 11:21 PM
                                        • tom_h
                                          Sceptre X505BV, blue LED, no display
                                          by tom_h
                                          Hello all,
                                          I have a Sceptre X505BV-FMDR8HJ1PE8 tv that had been gradually over time taking longer
                                          and longer to come on, now it will no longer display any image. Original symptoms
                                          are the red standby LED would turn to blue immediately when pressing the power on
                                          button, but there would be a delay for the "SCEPTRE" image to appear on the screen
                                          and backlight to come on. The delay kept getting longer, then it would go from blue
                                          LED back to red. Then when I pressed the power on button again it would bring the
                                          display up and work fine....
                                          10-05-2023, 06:53 PM
                                        • deviantcode
                                          I have a thinkpad p1 gen 3 20th-ct01ww. Recently I've had 2 that after windows updates, it no longer detects the battery
                                          by deviantcode
                                          I have a question regarding one of these lenovo laptops. I have a thinkpad p1 gen 3 20th-ct01ww. Recently I've had 2 that after windows updates, it no longer detects the battery. I have tried rolling back the bios update and that didnt fix it. Is this something that requires modifying the original bios to fix or is it bios related at all ? Is this issue common. thanks.
                                          01-31-2025, 08:56 AM
                                        • aprilmixtape
                                          Asus Tuf Dash F15 (FX516PC Rev 4.0) IC chip no longer able to be read
                                          by aprilmixtape
                                          I recently ordered a CH341a to try and fix my 2021 Tuf Dash F15 after seeing a video about Asus laptops being diagnosed as having fried mobos when they have corrupted bios. After following the steps from a YouTube video and flashing the IC chip (W25R128JVSQ; detected as a W25Q128BV on AsProgrammer) the laptop booted up for the first time in 2 years. I looked around my room for the M.2 drive I had removed from it and as soon as I came back the laptop had turned off. I assumed it automatically turned off due to inactivity but when I pressed the power button, the backlight and power button would...
                                          12-18-2024, 10:02 PM
