HP L1706 alternating colors with or without signal
  • eddiesomesan
    • Feb 2011
    Hello. I am working on a HP L1706 LCD.
    The problem with it is, when I power it up, on the whole screen appears a color which is changing to another after few seconds and so on. So on the LCD there are some alternating colors like some kind of a test mode. Tried it plugged in and even without the signal cord I have the same problem. Everything looks good inside.
    A few months ago I have recapped the ps zone and it worked great until now.
    Any sugestion is appreciated.
    Thank you.
    Re: HP L1706 alternating colors with or without signal
    Thank you.
    Check if the LVDS cable is properly connected.
    • AstutePauciloquent
      Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
      by AstutePauciloquent
      Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
      I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
      11-23-2023, 11:02 PM
    • CoinCoin88
      Garage door RX unit (Cardin S38C) does not short relay to send opening signal
      by CoinCoin88
      I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
      Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
      09-15-2025, 03:36 AM
    • howardc64
      Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
      by howardc64
      Failure Symptom
      No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
      Where is the short?
      Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
      Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
      05-27-2025, 02:56 PM
    • JayPoorJay
      Converting +/- 5v to a Usable Hz Signal
      by JayPoorJay
      Good morning.
      I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
      This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
      The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
      08-07-2022, 08:35 AM
    • Scruit
      What is a normal composite signal range for a C64?
      by Scruit
      Hello all,
      Working on my first C64 / Breadbin / 250407. Purchased as non-working. Getting black screen.
      More detail below, but for those that want to get right to the question.... Here are a few waveforms comparing the Pin15 output on the VIC chip (luma/sync) to the pin 4 on the AV socket (composite signal).
      https://imgur.com/gallery/PpqcqPY
      My question is: Is the composite waveform range of 0.1v-1v too low for a c64?
      More detail:
      Symptoms are that that I get...
      04-28-2022, 05:33 AM
