White IBM lCD Screen
  • Decade
    • Dec 2005
    • 37
    Hi!
    One of our IBM lcd monitors at work suddenly turned white nothing shows up just white.
    Never had anything like it before so wonder if any of you have had any similar trouble, the model of the monitor is IBM 6637-AB0 have no schematic so if anyone got one and could share it with me I would be more than happy
  • Rainbow
    • Aug 2005
    • 1375
    Re: White IBM lCD Screen
    White means that the backlight works but the panel does not. Check the output voltages of the power supply.
    • Decade
      • Dec 2005
      • 37
      Thanks Rainbow!
      Yes I know about the backlight, I'll open it up and check the PSU I might as well take a snapshot of it
      There is no menu and the brightness can't be adjusted, I'll be back later.
      • harp
        White screen repairs
        by harp
        To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
        Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
        On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
        05-13-2024, 03:43 AM
      • EazyBone
        Sharp LC-65Q620U White Screen
        by EazyBone
        Another TV topic!!
        I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
        The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
        Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
        08-21-2024, 12:56 PM
      • hcinne
        Dell G15 ryzen edition black screen 2 amber 1 white
        by hcinne
        I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
        07-23-2024, 07:56 AM
      • Chrissygizmo
        Panasonic TX-48CX350B backlights but white screen , blank screen
        by Chrissygizmo
        Hi all, I’ve got a problem I hope someone can help me fixi.
        I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
        01-11-2025, 03:18 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
