Gateway FPD1530 dims real fast?
  • CH40Z
    • Jul 2011
    Well i got this real old monitor that i need to use but every time i turn it on the LED green light turns on and for a couple of seconds so does the screen then it dims so much i can hardly see anything ( it looks black but you can see the things your doing .. just a bit though...) any ideas whats wrong? I think its something related with the black light. But idk since some times it stays one for a wile then it goes off.... I can take pictures of the insides if needed.
    -CH40Z
  • digge
    • Apr 2006
    • 296
    Re: Gateway FPD1530 dims real fast?
    Something making the backlight turn of, what that is is hard to just guess. So i would suggest you go ahead and take some pictures of the boards and post them here.
    • cook
      HP Power Supply 6632A: Fast Mode vs Normal Mode?
      by cook
      FAST MODE vs NORMAL MODE
      I have recently acquired a HP 6632A DC power supply. I am just beginning to use it and I have been reading the manuals for it. It is the first power supply I have ever owned or used. I am a very beginner hobbyist and do not have an engineering background, as may be obvious by my question...
      I can't seem to understand what the actual use is for the 'Fast Mode' or the 'Normal Mode' on the power supply. Although the manual states what the two modes do from a engineering/technical standpoint, I don't know enough to understand what it all means,...
      06-07-2020, 05:32 AM
    • SevenOFF
      Denon AVR-X4000 – Fast red blinking after 2nd relay
      by SevenOFF
      I’m working on a Denon AVR-X4000 that goes into protection mode (fast red blinking LED) shortly after the second relay click.
      According to the service manual, a fast red blinking LED indicates a DC detection (DC_DET) or ASO (abnormal current) fault, meaning the unit is detecting a potentially dangerous condition on the power amp or power supply side.
      Here’s what I’ve done so far:
      • Fully opened and cleaned the unit (a lot of dust inside)
      • Removed and visually inspected the AMP board → nothing visibly damaged or burned
      • Testing is done with
      06-18-2025, 09:54 PM
      TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
      FF Series (Very Fast Acting), 0603 Size
      Features
      ● Very fast acting at 200% overload current levels
      ● Low DCR
      ● High inrush current withstanding capability
      ● Fiberglass enforced epoxy fuse body
      ● Copper termination with nickel and tin plating
      ● Halogen free, RoHS compliance and lead-free
      Applications
      ● Notebook computers and tablets
      ● Digital cameras
      ● Memory cards
      ● Toys
      ● Bluetooth earphones
      ● Portable electronic devices​...
      10-07-2024, 05:50 AM
    • cnti
      Samsung 245B PLUS - BN44-00195A - bang and smoke - solved - tips
      by cnti
      Hi.
      BacCaps forum is awesome - thank YOU ALL for sharing knowledge!
      This is about DONG YANG PSU BN44-00195A failiure in Samsung 245BPLUS. It started with bang and smoke from the back of LCD. Downloaded diagram BM44-00192A - a bit different but I will use all parts names from this diagram [and real PSU].
      BIG CAP CP801 had 315V, on standby pin 5,2V. After shorting S_B ON (through 3,3k ohm resistor) 24V and 5,3V were missing, on CP801 was 312V.
      RM801 [real PSU: RM801 - 0,22 ohm 1W] - FAIL
      burned, measured 10M ohm.
      QM801 [real PSU:...
      10-19-2023, 05:33 PM
    • paparazzo79
      fast charging vs normal charging cellphone,damaging battery?
      by paparazzo79
      Hi friends.
      I see there are many clever people here.
      I purchased used Note 10 plus phone,and it doesn't have good battery cuz it's been used probably more then a year.
      Since I'm not an expert into phones but my own thought is that fast charging with high current wears out battery more quickly and damages cells compared to regular charging.
      I don't need fast charging at all so I disabled that option in phone,since I don't care if my phone will charge 1h or 2.5 h (with regular charging).
      But want to ask does fast charging damage the battery cells as time passes...
      05-16-2021, 03:27 AM
