Samsung Syncmaster 245B Black screen and blue Power LED
  • ForceMajeure
    • Jun 2017
    • 3
    • Sweden
    #61
    Re: Samsung Syncmaster 245B Black screen and blue Power LED
    Sorry for doing a Necro, but I have the same problem and I have resoldered the 3x 68 ohm resistors and one was a bit high but only 10 ohm. (changed it anyway) But it didn't fix the problem.
    Then I checked the inverter board and found 4 CapXon (CapXCon) and 3 of them seems like they are bulging. so here are some pics (Electro sensitive people be aware. xD)
    C38 Ref.
    C39
    C40
    Close up
    I should change these for some better ones, right? Could that be the problem?
    Thanks!
    • vinceroger69
      • Mar 2012
      • 6714
      #62
      yes they are bad so you need to change them all try to get some panasonic brand replacements
      • ForceMajeure
        • Jun 2017
        • 3
        • Sweden
        #63
        Panasonic 220 uf@ELFA
        They have Rubycon, Elna, Nippon Chemi-Con and Jamicon also. Are they just as good or?
        Maybe I should change some of the 8-10 caps on the PSU board while I'm at it?
        • ForceMajeure
          • Jun 2017
          • 3
          • Sweden
          #64
          So I changed the caps on the inverter board to Pana and replaced the 3 resistors to a big 204 Ohm one.
          Any other things I should check? Maybe re-solder some of the components on the PSU as well?
          • GabDr
            • Nov 2018
            Hi All,
            I have been following the threads on this forum for some time to try to fix my own Syncmaster 245b with blue LED but no other power. I had already changed the 3 faulty resistors a few years back but this time something else went wrong.
            At first I looked at all resistors and the schematic to find out that RB801 was not right. Replacing it did not fix it. I then searched and read a lot on this forum only to find that it was probably the capacitors. I found the 18nF CM802 at 170pF (too low). Since I could not find a meter to measure all others (the one I had stopped at 100uF...) I ordered a copy of all capacitors (electrolytics) and replaced them all, plus the 18nF.
            Further testing showed everyting to work fine though not the 5V and 24V... was forgetting to short S_B and PSON to simulate the ON button. Then I got the 5V and 24V!!
            I am now writing this with that monitor so I wanted to thank all contributors to the forum for their great expertise and especially for taking the time to explain and give enough details that even not so expert people like myself can try and learn how to fix electronics!
            • LeolaJD
              • Apr 2010
              #66
              I've been reading this thread and my situation is that I replaced the 3 resistors, the monitor was working, and I thought I was done. The next day I wanted to use the monitor and it was back to being black. I took it apart and checked the CM802 and it measures 17nF. Not sure if that would be considered faulty. No capacitor looks bulged.
              • ulthi
                Samsung QE50Q60TAU - Flashes black/blue screen
                by ulthi
                My tv is not able to turn on. I flashes between black and vague blue screen (see video)
                I have tried different resets and have also replaced the main board - but nothin has changed.
                Any suggestions?
                https://youtu.be/acYQ-ImmhWA
                Today, 01:48 PM
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • gbbradshaw
                Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
                by gbbradshaw
                Hi.
                I have the Samsung TV Model: UE65TU7000KXXU VER:02/UTU7000 which has developed the following issue: blue screen while the sound it's still working. This happened after the screen developed some horizontal lines at first and then the next day suddenly turned into blue background. the screen was not damaged or anything. I can't access the menu. I have taken the tv to a local tech to have a look and he said that he thinks that it might be the pcb board as the back-lights are working and the sound aswell . I was hoping maybe you can guide me if I should buy the pcb board or not? Thanks
                02-22-2023, 01:31 AM
              • mar1in
                Samsung TU8000, backlight and sound on, stuck in blue screen
                by mar1in
                I've got this Samsung here that would be stuck in a boot loop.
                After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                Thanks in advance
                11-08-2023, 05:43 PM
              • Chrissygizmo
                samsung galaxy ao2s very temperamental after screen replaced
                by Chrissygizmo
                Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                Ive eventually managed to get it on and working but it's very temperamental...
                The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                05-26-2024, 12:05 AM
