LG 1918s No power
  • ethernet
    • May 2009
    • 11
    LG 1918s No power
    Sympoms are:
    No power on
    Transformer clicking
    Diagnosys and Tests:
    No 5V VSB
    No voltage on large cap 100uf 450V
    Bridge rectifier OK
    Mains fuse OK
    0.47uf capacitor OK
    ALL caps look OK but not replaced
    My main concern is why is there NO voltage on large cap?? Can somebody please shed some more light on this case?
    Thank you
    • Jul 2011
    • 6046
    Re: LG 1918s No power
    Can you post some photo of you control and power board
    and see if can find what up withe monitor
    • PlainBill
      • Feb 2009
      • 7034
      Originally posted by ethernet
      Sympoms are:
      No power on
      No 5V VSB
      Bridge rectifier OK
      Mains fuse OK
      0.47uf capacitor OK
      Thank you
      That would sound like a tester error. Agree with 3sam, pictures would be a major help.
      PlainBill
      • sabre504
        • May 2010
        • 449
        • United Kingdom
        How did you test the bridge rectifier ?
        And have you checked the thermistor ?
        • jetadm123
          • 2169
          If you have zero volts across the main capacitor, then how can you have a "clicking sound"? Suggest you remeasure the voltage across the main cap. Black probe on negative cap lead and red probe on positive cap lead. Be careful as this is high voltage, approx 165 VDC if you're in the USA.
          • ethernet
            • May 2009
            • 11
            Thank you for the replies,
            We have 230AC here so i set the dmm to 750V AC and messured the leads on the large capacitor. No volts.
            I thought it was the transformer clicking but i could be wrong, sound is coming from that area. I will post pictures tomorrow when i am able to access the monitor.
            Diode checked the bridge rectifier - no shorts and no reverse current flow
            Thermistor looks ok but i forgot to test it. That would explain the problem i think.
            Thank you for the answers, i will reply back tomorrow
            • jetadm123
              • 2169
              The voltage across the main cap is DC, not AC. You should see approx. 230x1.4 = 322 VDC
              • sabre504
                • May 2010
                • 449
                • United Kingdom
                If your large cap is showing voltage and there is clicking coming from the board then the thermistor should be ok .
                Pictures as stated will help others maybe spot something else that needs testing and can better guide you
                • ethernet
                  • May 2009
                  • 11
                  Oops i was measuring AC on the large cap.
                  Large cap has DC Voltage 345V, ALL caps have been replaced except those two small starter caps. Yes i am aware of the irony that the monitor won't start and i have not replaced the starter caps. They are not currently on stock and will replace them when they are available.
                  Here are the pictures:
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
                    09-06-2024, 05:59 AM
                    HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                    This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-12-2024, 02:15 PM
