LG 1918s No power
  • ethernet
    • May 2009
    • 11
    LG 1918s No power
    Sympoms are:
    No power on
    Transformer clicking
    Diagnosys and Tests:
    No 5V VSB
    No voltage on large cap 100uf 450V
    Bridge rectifier OK
    Mains fuse OK
    0.47uf capacitor OK
    ALL caps look OK but not replaced
    My main concern is why is there NO voltage on large cap?? Can somebody please shed some more light on this case?
    Thank you
    • Jul 2011
    • 6024
    Re: LG 1918s No power
    Can you post some photo of you control and power board
    and see if can find what up withe monitor
    • PlainBill
      • Feb 2009
      • 7034
      Originally posted by ethernet
      Sympoms are:
      No power on
      No 5V VSB
      Bridge rectifier OK
      Mains fuse OK
      0.47uf capacitor OK
      Thank you
      That would sound like a tester error. Agree with 3sam, pictures would be a major help.
      PlainBill
      • sabre504
        • May 2010
        • 449
        • United Kingdom
        How did you test the bridge rectifier ?
        And have you checked the thermistor ?
        • jetadm123
          • 2169
          If you have zero volts across the main capacitor, then how can you have a "clicking sound"? Suggest you remeasure the voltage across the main cap. Black probe on negative cap lead and red probe on positive cap lead. Be careful as this is high voltage, approx 165 VDC if you're in the USA.
          • ethernet
            • May 2009
            • 11
            Thank you for the replies,
            We have 230AC here so i set the dmm to 750V AC and messured the leads on the large capacitor. No volts.
            I thought it was the transformer clicking but i could be wrong, sound is coming from that area. I will post pictures tomorrow when i am able to access the monitor.
            Diode checked the bridge rectifier - no shorts and no reverse current flow
            Thermistor looks ok but i forgot to test it. That would explain the problem i think.
            Thank you for the answers, i will reply back tomorrow
            • jetadm123
              • 2169
              The voltage across the main cap is DC, not AC. You should see approx. 230x1.4 = 322 VDC
              • sabre504
                • May 2010
                • 449
                • United Kingdom
                If your large cap is showing voltage and there is clicking coming from the board then the thermistor should be ok .
                Pictures as stated will help others maybe spot something else that needs testing and can better guide you
                • ethernet
                  • May 2009
                  • 11
                  Oops i was measuring AC on the large cap.
                  Large cap has DC Voltage 345V, ALL caps have been replaced except those two small starter caps. Yes i am aware of the irony that the monitor won't start and i have not replaced the starter caps. They are not currently on stock and will replace them when they are available.
                  Here are the pictures:
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
                    09-06-2024, 05:59 AM
                  • meraklinetx
                    Asus Z97-a power cycle, no boot no cpu voltage
                    by meraklinetx
                    Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                    05-10-2023, 06:08 AM
