Re: 32" Goodmans TV
The common problem with these boards are the 2 small caps on top left hand side of board...C877 and C878. Change these to 15nf 1600V.
32" Goodmans TV
Re: 32" Goodmans TV
See attached. Zipped because Badcaps forum won't let me upload a txt or bin.
This has some channels programmed in and user customisations. It is NOT a factory default.
Most Vestel chassis TVs I have worked with will boot up with a blank eeprom. They will be a bit confused (usually the colours are off on the screen, panel sizes are wrong etc (usually thinks its a 1080p not 720p screen.)) But you can reset all this from the service menu.Attached FilesLeave a comment:
Re: 32" Goodmans TV
tom 66 what model eas you Wharferdale and can you upload a zip of the eeprom
thanks
Well, sort of. I got a Wharferdale in which had the same power supply, but that one is a bit temperamental in powering up. I swapped the PSUs around, and the Goodmans powered up. Although I had erased the EEPROM beforehand, so it was very confused; it thought it was in Turkey and had two HDMI inputs and various extra features. Luckily, I made a copy of the EEPROM, so I'll restore that later.Leave a comment:
Re: 32" Goodmans TV
Hi people,
I have been battling with a TV Bush ICLCD32... with a vestel 17pw20 v1 PSU.
Same symptoms, set comes out of standby all rails appear good, ESR on caps all measure fine, the two 15n for the main supplies test OK. But the set just flicks back to standby.
I have cured this, I de soldered pin 8 of IC807 and the set operated normally, the function of this pin is to generate soft start up it is toggled by a SMD fet connected to several fault detectors in the PSU. After de soldering I scoped the gate of the FET and found it stayed at a steady state however resoldering pin 8 and scoping again the voltage was very noisy and jittery. I had another PSU and swapped out Q837 (the FET) and full function was restored.. I do recall reading this elsewhere, sorry I cant acknowledge my peer.
Hope this helps
PeteLeave a comment:
Re: 32" Goodmans TV
Re: 32" Goodmans TV
Hey Tom,
How has your Goodmans 32" progressed, is it fixed now?Leave a comment:
Re: 32" Goodmans TV
Are you getting correct V's on all rails? Do you get as far as the screen trying to fire up? Set is in standby, LED solid > press power on remote > LED off > approx 5 secs > screen/backlights should illuminate, set runs.Leave a comment:
Re: 32" Goodmans TV
Well, I tried to replace the polyprop caps in the PSU, with no result. However, I'm been stuck repairing a plasma, a DVD player and another LCD so I haven't had a decent look at it.Leave a comment:
Re: 32" Goodmans TV
My description above is incorrect - I sprayed the sockets (cable ends) not the plugs (circuit boards) directly onto the end face so it would penetrate into the pin receptacles. So far (since last night) I've powered the TV on and off dozens of times and not once has it faulted, although I've done this in the past with the same results only for it to go awry again after being left turned off for a few days. So I'll see what happens over the coming days, but I wouldn't be surprised if this does correct things - I've had success over the years with this silicon remedy. It was your mention of fiddling with the connectors that made me think of it again.Leave a comment:
Re: 32" Goodmans TV
Re: 32" Goodmans TV
I disagree Tom, the LED is definitely indicating a fault(s) - my PSU is working fine, it's the M/b that's giving me the probs, and it all stems down to the output (or lack of) on the B/L signal. The M/b doesn't power down the PSU, it stays running and ALL rails give the correct V's. The problem is the signal to turn on the inverter - it turns it on but then instantly goes low again, whilst all other V's remain as they should.
I just fixed a 32" Acoustic Solutions with an identical PSU (17PW20.1). All I did was open the case up and fiddled with the connectors. It had a similar problem, although it would switch on normally, it would tend to switch itself off after a few minutes. These Vestel things drop like flies - I've got my eyes on a Logik 32" which I'm willing to bet has a 17PW20.1 PSU in it, and probably the same or similar chassis as the other 32" TVs.
re: Goodmans
In my case the STBY_ON_OFF line, driven directly by the CPU, was/is turning on and off. The question is - why? Well as I do not have source code for the firmware of the CPU I would not be able to figure that out. However, I'm suspecting that it definitely has something to do with the protection detect circuit. Because in my case, the rails were floating at around 11V for the 24V rail. No idea why; could be any number of issues. But the protection detect fires on 4.3V for a 5V rail, so it would easily be set off by that. So, CPU turns PSU on as soon as it is plugged in. I have determined this is normal behaviour because the Acoustic Solutions does exactly the same thing when it is first plugged in.
On mains power up, CPU switches PSU on for ~0.5 seconds. Not sure why - firmware bug - or CPU getting confused? As it is supposed to be in standby mode it then switches itself into standby and leaves the STBY_ON_OFF in the off state (high/low? - can't remember atm.) - this is of course if it is working. The problem I was having until I completely screwed up soldering was that this stage would get caught in a loop. The CPU was telling the PSU to fire up for this 0.5 seconds but then for some unknown reason was resetting, and the cycle continued until power was pulled, and it lasted for a good 2 seconds with no mains power (just running off the 220u mains filter cap), telling me that it wasn't drawing much current (from the filter cap) in this mode and the problem is likely something to do with how the current is controlled through the transformer, or something to do with the feedback. Whatever it is, the power supply rails are rising - but not fast enough - and the CPU is resetting. Why? Good question, one which I do not have the answer to...
This is why I suggest getting the LED to test the ON/OFF line. You could also use a logic probe - you can pick one up for about £15 from Maplins and it will tell you about the STBY_ON_OFF line. The logic probe might be better than the LED as it draws very little current from the control line. A cheap 12 MHz dual-trace analog oscilloscope nearby me is going for £30; a scope is really crucial equipment for debugging a power supply especially one of this complexity, but be careful(!) you *cannot* use it to probe the high voltage primary side!!! You will blow it up! Only the secondary side may be probed and you may not probe the inverter either. This has been my main limitation at the moment; I am considering getting an isolation transformer and a high voltage probe to allow me to probe the primary side of SMPSs. The voltage on parts there can easily be 400V, and my poor scope is limited to 250Vpk, and really only can measure 100Vpk, and I don't wanna blow it up!Last edited by tom66; 08-02-2011, 05:33 PM.Leave a comment:
Re: 32" Goodmans TV
I disagree Tom, the LED is definitely indicating a fault(s) - my PSU is working fine, it's the M/b that's giving me the probs, and it all stems down to the output (or lack of) on the B/L signal. The M/b doesn't power down the PSU, it stays running and ALL rails give the correct V's. The problem is the signal to turn on the inverter - it turns it on but then instantly goes low again, whilst all other V's remain as they should.Leave a comment:
Re: 32" Goodmans TV
Yep, you sure are having some probs with those Vestel boards - much the same as me ffs. I've had this thing running just fine for days, then I left it off for a few days and on powering up tonight I'm getting the flashing LED crap again. Only today it was a different flash/rate from previous, so up to now I've had four different 'errors' - but nowhere can I find a list of the error codes. But I have narrowed it down to the startup sequence; switch on (from stby) and after a couple of seconds the M/b should chuck out 3V2 on PL003/1 to PL803/1 which in turn goes directly to PL802/12 and supplies the inverter switch-on power. But instead of the 3V2 it's only giving around 2V9, and according to the service manual it should be between 3~5V, and I reckon the 3V minimum is crucial - and maybe there's not enough current either, but the output is too short for me to measure either V or A before it locks out. The backlights illuminate for a split second and then the set locks out and goes into LED flash again. So I'm gona have a closer look at the components supplying the VSUP_3v3_COM on the VCTP.
Back to your set, I think you are having the same probs as I was initially, both my PSU and M/b were playing up. I sorted the PSU and now all the V's are as they should be except the inverter V mentioned above. I'm away for the weekend but I'll get back on it Sunday, and have a closer look at your posts again too.
One thing that I heard about poly caps is they are very temperature dependent and they can heal when they are damaged, but they do lose a bit of performance in the process (usually in the form of capacitance.) It could explain the problems we are getting. The two caps, near the big transformer, C877 and C878, carry the *full* load of the PSU on alternate half-cycles so they are under a *lot* of stress. The peak current through those caps is probably on the order of 5A. They're quite expensive too - Digikey has them for $1 each - and manufacturers are always under pressure to make products cheaper, so it wouldn't surprise me if these are sub-par caps. Another form of bad capacitors, but not electrolytic, and there's not much you can do as there aren't really "good" poly cap brands unlike with electrolytics.Last edited by tom66; 07-30-2011, 01:29 PM.Leave a comment:
Re: 32" Goodmans TV
Back to your set, I think you are having the same probs as I was initially, both my PSU and M/b were playing up. I sorted the PSU and now all the V's are as they should be except the inverter V mentioned above. I'm away for the weekend but I'll get back on it Sunday, and have a closer look at your posts again too.Leave a comment:
Re: 32" Goodmans TV
I was researching the problem I have and it might be a bit more complex than I thought, but at least it is reasonably easy to fix.
This kit here claims to fix the stuck in standby and blinking LED problems. I have either one of those issues. So I am ordering the components featured in the kit and will try and fix it.
http://www.sparedparts.com/products/...k_light_faults
I have another Acoustic Solutions 32" TV I bought for cheap which appears to have the same problem, so if the Goodmans can be fixed maybe the Acoustic Solutions can be too.Leave a comment:
Re: 32" Goodmans TV
Okay, my remove the PFC mod actually seems to have worked.
At least, the PSU didn't explode...
Got standby 5V and 3.3V.
HOWEVER, it still doesn't start... Any ideas?
Across main filter cap I get ~330V in standby and 310V run. I'm hoping the run voltage is high enough; it's a bit on the low side. My last set must have had partially working PFC because run voltage was usually around 330V and standby was about the same. 310V bus corresponds to 219V AC, and the working range is stated at 220-240V.
I need to reflash that EEPROM and see if it fixes it.Leave a comment:
Re: 32" Goodmans TV
Ah, got my broken PSU today.
Interesting. The transformer for the PFC has been broken right off the board and is quite loose.
The fuse is also blown.
Apart from this though, it seems okay.
Was thinking of removing the PFC fet, and the PFC transformer. Replace the main winding of the transformer with a piece of wire. It wouldn't have PFC any more, but it should work just like mine did, on 328V.
I'll give it a go, haven't got much to lose.Leave a comment:
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by Paxman_SwedeHello!
I have studied the board and...-
Channel: General Capacitor Questions & Issues
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
by black6hostGood day!
I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
I'm going to replace the caps and I'll be the first...-
- Loading...
