Acer LCD monitor which are very dead
  • alexanna
    • Mar 2010
    • 1346
    Re: Acer LCD monitor which are very dead
    It come to life after I pull U406 which is a reset controller
    Good, jetadm123 suggested that in an earlier post.
    So we all know was the reset controller causing the voltage to be low on the front power switch?
      • Jul 2011
      • 6037
      I had to get the nerve to pull that tiny little chip with out messing up the board both control boards work and both power board work I am going to get that chip and install it before I start using these two monitors
      On one of the monitors I have to re-lamp that because one of them broke while I was taking apart
      I want to thank every one who has post there suggestions this has help alot and have learn allot in how to repair LCD Monitors
        by momaka
        03-15-2023, 10:17 PM
      • maralexbar
        How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
        by maralexbar
        I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
        It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
        If anyone knows how to force the external monitor as primary for Notebooks of those models
        11-02-2024, 09:18 AM
      • noah95
        Dead Acer AL 1916W Monitor
        by noah95
        Hello everyone, i have an old acer monitor "AL 1916W"
        it was totally dead but after i replace some bad caps now the led turns green and red when it's in sleep mode.
        but the picture at all no backlight or a dim picture in the LCD.
        i just wanted to know how can i test the backlight and the lcd or from where to measure the voltage going to the backlight or the lcd, to know if the problem in the psu or not.
        i did test most of the component there if there's a short but they seems fine.
        03-25-2022, 03:12 AM
      • bripoll
        Acer Veriton N4670GT Dead
        by bripoll
        Hello, I have an Acer veriton n4670GT that, due to a fall to the ground, only started if I did a BIOS reset.
        The power button ar ok, and when power off windows, then if press power button, this power on, but goes to boot loop, like press power button forever
        It crossed my mind to try a BIOS update and when I finished it turned off and no longer starts in any way.
        I have a flash programmer, but the file you download from the Acer website has a .CAP extension, it is not a .BIN
        I have programmed it, but it still won't start, it is dead
        Before programming...
        11-23-2023, 02:56 PM
        09-06-2024, 05:27 AM
