Acer LCD monitor which are very dead
    • Jul 2011
    • 6040
    I have two Acer LCD monitor which are very dead nothing no led no image
    I do not see any bad caps I have not found any bad parts one of the monitor
    How ever there a few spot are mark where allot of heat has been at one time
    The other monitor has Sims transistor that pop so I know that board is bad
    any idea on the one that dose not seem to have any bad parts what could be wrong with it
    The model is # AL1716
    Date code 12/2005
    they are the same model #
    Thanks for any info you can give me
    I have fix one LCD moniter and one LCD tv already that had bad caps in them
    and one router and five switching power supplys Which work very well
    • Jul 2011
    • 6040
    Re: Acer LCD monitor which are very dead
    Here is some photos
    on the control board next the 2 cap off to one side you will see the fryed transistor
    on the power on both board the transistors Q902 and Q903 are discolored
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Be patient sam_sam_sam.
      The 'monitor guys' are kinda swamped lately but they should find this.
      I'm not one of them. [I don't like shipping screens so never got into it much.]
      If they don't find this in another day send me a PM and I'll tell you who to PM for help.
      I can tell you I see Elite brand caps on the yellow/brown board and those HAVE to go.
      They are horrible! - 'Replace on sight' kind of thing.
      I'm not -sure- if they often fail without bloating but it wouldn't surprise me.
      Mann-Made Global Warming.
      - Dr Seuss
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        If you are not familiar with cross-referencing caps then do this.
        Make a list.
        Show: Make - Series - uF - Volts - Diameter - Length - ESR - Ripple
        Use that as a guide to find good replacements. [Helps to post the list sometimes.]
        When you have the series I'll check if I have the data sheets & upload.
        [Current revision of their site does not work.]
        - Dr Seuss
          • Jul 2011
          • 6040
          Thank you for your reply
          I will post the cap value later on today or tomorrow
          • jetadm123
            • 2169
            Your photos are a little on the blurry side and it's impossible to make out the components on the control board. Let's try the following:
            1) Connect the boards back together.
            2) Set your meter to DC volts. Press the "power on" button on the front panel. Measure the output voltages on the wiring harness of the power board for each pin. If you measured 0 volts for each pin, try pressing the power button again and remeasure the pins.
            3) As for the burned out transistor. What is the silkscreen ID on the control board? Is it U406? If yes, then it's probably the reset controller, which if failed, will prevent the monitor from powering on. But you need to verify the output voltages first before going any further.
            4) Please provide better focused photos.
              • Jul 2011
              • 6040
              When check the voltages on the control board is one lead of the meter to " - " and the other lead to each pin or is it " + " to each on the comtrol board is the " - " or " + " off of the supply board
              Thank you for your help
              • jetadm123
                • 2169
                Place your negative (black) probe on a mounting screw. Measure each pin on the wiring harness with your red probe.
                  • Jul 2011
                  • 6040
                  Thanks for the info
                  I will check this later on to day
                    • Jul 2011
                    • 6040
                    Here is one more photo of the control board
                    That is the best that this camera can do I am sorry that the photo is not beter
                      • Jul 2011
                      • 6040
                      Here are the voltage reading at the control board
                      Black 0.06 volts
                      Brown 4.48
                      Red 14.48
                      Orange 0.00
                      Yellow 4.94
                      tie together
                      Blue 0.00
                      purble 0.00
                      • jetadm123
                        • 2169
                        Black 0.06 volts
                        Brown 4.48
                        Red 14.48
                        Orange 0.00
                        Yellow 4.94
                        tie together
                        Blue 0.00
                        purble 0.00
                        It looks like you're getting the 5V and 15V outputs. On your control board, please verify that the burnt transistor is U406. U406 should be stamped on the board itself. If it is U406, then it's probably a reset controller and not a transistor.
                        Once you have verified it's U406, with the monitor off and unplugged, go ahead and remove U406 and put the boards back together and plug the monitor back in and try turning it on.
                          • Jul 2011
                          • 6040
                          This is on the control board that there are no burn part on it and it dose not turn on ether and nether board work
                          Both power board are the same as far as the reading are concern
                          I have two control boards
                          Thanks for your help with this monitor
                          I also check for power at the ON and OFF switch there is 0 volt but all other switches have 3.25 volts
                            • Jul 2011
                            • 6040
                            Dose any one have any idea on what to check next
                            I want to use this monitor as a learning tool
                            On one of these monitor I took the screen apart and saw that the clf tubes on this one are very black on one end and the other end is a little bit black but should keep the power board from even coming ON
                            • alexanna
                              • Mar 2010
                              • 1346
                              When you check the front power switch, you should see a voltage toggle as the button is pushed. usually from a high voltage to a low voltage.
                              Do any of the voltages go low as the front power switch is pushed?
                                • Jul 2011
                                • 6040
                                No the voltage at the ON and OFF switch is 0.00 volts with out switch pushed
                                And all other switch start at 3.25 and then go to 0.00 volts when switch is pushed
                                I am a little confused about this that the ON and OFF switch has no voltage at all
                                I check all what look like to be ether a fuse or a resistors with a marking of
                                "0000" on it sim chips all have 0 on the meter is a short
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  That sounds like either you are reading the wrong side of the switch, or the switch itself is defective. It's very simple, actually. I count 12 pins on the connector to the control panel. One or more of those should change voltage when each front panel switch is pushed. There are several ways to troubleshoot this - trace the wires, check each pin while a helper repeatedly pushes each button, etc.
                                  I have never heard of a front panel switch failing like that, but I would be foolish to claim it couldn't happen.
                                  PlainBill
                                    • Jul 2011
                                    • 6040
                                    I check all of the switches are good
                                    It only the power switch that has no voltage at all
                                    I will recheck to make sure this is the case
                                    I just do not understand why this switch has no voltage at all unless somthing is bring the voltage down to (0)
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      DUH!!! Yes, something is probably wrong!!! It's your job to figure out what.
                                      There are several possible explanations. One common design has five inputs of the control chip pulled high by a resistor. Signal lines go from the inputs to one side of five switches. The other side of each switch is grounded. When a switch is pressed, the input is pulled low.
                                      Possible failures include a switch that is shorted or contaminated, a broken wire or trace on the circuit board, a bad connector, open resistor, bad solder joint, bad input on IC, shorted capacitor. An elementary first step is to identify the function of each wire from the signal board to the control panel.
                                      PlainBill
                                        • Jul 2011
                                        • 6040
                                        It come to life after I pull U406 which is a reset controller
                                        Here is the link to a service manal for the controller board
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • maralexbar
                                          How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
                                          by maralexbar
                                          I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
                                          It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
                                          If anyone knows how to force the external monitor as primary for Notebooks of those models
                                          11-02-2024, 09:18 AM
                                        • noah95
                                          Dead Acer AL 1916W Monitor
                                          by noah95
                                          Hello everyone, i have an old acer monitor "AL 1916W"
                                          it was totally dead but after i replace some bad caps now the led turns green and red when it's in sleep mode.
                                          but the picture at all no backlight or a dim picture in the LCD.
                                          i just wanted to know how can i test the backlight and the lcd or from where to measure the voltage going to the backlight or the lcd, to know if the problem in the psu or not.
                                          i did test most of the component there if there's a short but they seems fine.
                                          03-25-2022, 03:12 AM
                                        • bripoll
                                          Acer Veriton N4670GT Dead
                                          by bripoll
                                          Hello, I have an Acer veriton n4670GT that, due to a fall to the ground, only started if I did a BIOS reset.
                                          The power button ar ok, and when power off windows, then if press power button, this power on, but goes to boot loop, like press power button forever
                                          It crossed my mind to try a BIOS update and when I finished it turned off and no longer starts in any way.
                                          I have a flash programmer, but the file you download from the Acer website has a .CAP extension, it is not a .BIN
                                          I have programmed it, but it still won't start, it is dead
                                          Before programming...
                                          11-23-2023, 02:56 PM
                                          09-06-2024, 05:27 AM
