BenQ 17" FP767 LCD One Second To Black
  • eddie fabry
    • Jun 2011
    I have a FP767 BenQ 17" LCD monitor that worked OK and then it developped the following fault.
    After I switch it on to display my Windows XP page the monitor display comes on for a fraction of a second and then goes black for another fraction of a second and then back on again and off again and so on and so on.
    What causes this intermittent display. Is there a way to fix it?
    Thank you, Eddie
  • retiredcaps
    • Apr 2010
    • 9271
    Re: eddie
    The standard procedure here is to post clear focused pictures of all your boards using the manage attachments functions so the pictures are attached to this forum. Please do not post inline because it slows down the loading of pages.
    After you have posted the pictures using manage attachments, we can suggest test points or see if the caps are known bad series.
    --- begin sig file ---
    --- end sig file ---
    • seppde
      Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
      by seppde
      I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
      ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
      The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
      In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
      02-09-2024, 05:19 AM
    • AJ847.63e
      BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
      by AJ847.63e
      Hi All.
      Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
      The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
      09-18-2023, 06:42 PM
    • ChatBTC
      Benq EX3501R
      by ChatBTC
      Hi!
      I am new to this site, and found it via LLM ChatGPT.
      I got a BenQ Ex3501R monitor which i have had for a while now, it works pretty good until recently, it struggles to turn on, i can see the purple welcome screen is shown for a brief time before it vanish again, usually it stays on for a couple of seconds before the main computer screen is shown, but image is still kept black, before i just had to turn it off and on a few times and that would leave it on, but now it takes ever longer to stabilize the image on the screen, ocasionally i can see the computer desktop...
      01-24-2025, 08:49 PM
      BenQ JoyBook S52 S53 Laptop Schematic
      Quanta ED3...
      11-01-2024, 02:03 PM
      BenQ S72 Laptop Schematic
      Inventec Grasshopper Rev 3.0...
      11-01-2024, 07:23 AM
