I'm searching for a fix for a Viewsonic vx2235wm monitor and found this site almost immediately. Over the past weekend, the power at my work went out and my boss' monitor stopped working. I'll give the symptoms that I've noticed and hope to get tips on further troubleshooting or repairs. All my testing was done using the VGA connector, not DVI.
When you power on the monitor, the blue light flickers for 1-2 seconds and then goes dark. If the monitor is left powered on but NOT connected to the PC video, the message for "No Video Signal" will appear after 10-15 minutes and the power light will come on in the orange power-save mode.
One time last night I powered the monitor on (same blue light flicker for a couple seconds) and I left the PC Video connected. After about 20-30 minutes the PC video suddenly appeared on the monitor. I used the monitor for several hours with no problems. At one point I powered it off and back on, it came right back up. However, I turned it off for the night and It exhibited the same flickering blue light then dark symptoms in the morning. I haven't had time for further testing yet.
Any ideas on what the problem is or further tests I should do? If I can get it working, I get to keep the monitor
. Thanks.
