Acer 1716 problems
  • Skoffer
    n00b
    • May 2011
    • 32
    Acer 1716 problems
    Ok, guys, I've been reading around on the forums, and decided to ask you guys what I should do.
    I have recently taken up a hobby of fixing LCD monitors with Capacitor problems. Been buying them cheap and reselling them. I have been pretty successful so far.
    But, I have run into an inverter that won't be fixed by replacing the caps.
    The issue is that when "cold" the monitor will display for about 1 minute, then the back light cuts off. Then, if you turn it off and back on, it displays the Acer logo, then cuts off, then flashes the backlights 1 more time, then nothing.
    This inverter has 3 - 25V 470 μf, 2 10v 1000μf, 1 - 10v 470μf, and 1 - 50v 22μf. I replaced them all with the exact voltage and μf rate Rubycon and Samxon caps that I got from Badcaps.
    I resoldered the tranformer pins and also replaced the large 470v cap with a known good one. still no dice.
    Any suggestions would be helpful. I have a multimeter and have also check the resistance on the fuse. It appears to be good to go.
    What should I try next?
  • alexanna
    • Mar 2010
    • 1346
    Re: Acer 1716 problems
    Here's what I would.
    Verify the backlight on voltage stays the same when the lamps shut off.
    Identify the inverter secondary coils and see if they are within 3%of each other.
    Substitute known good CCFLs.
    • Skoffer
      n00b
      • May 2011
      • 32
      The CCFLs good. The panel has been tested with a good inverter. no issues.
      • sabre504
        • May 2010
        • 449
        • United Kingdom
        Peel back the glue and check the resistance between the 2 pins circled red
        and do the same to the 2 pins circled yellow and post results
        • Skoffer
          n00b
          • May 2011
          • 32
          multimeter is showing infinite resistance across both. What exactly is that component?
          • Rtech
            • Jul 2010
            • 1095
            Dependant on the Board that is fitted. resistance MAYBE approx 856 ohms for both coils !!! what resistance scale was your meter set to ??
            • Skoffer
              n00b
              • May 2011
              • 32
              I had it on the lowest setting. I didn't realize it could be so much, I will retest on a higher setting.
              EDIT -
              Ok, It is showing 1013 across the red
              and 1010 across the yello.
              • Rtech
                • Jul 2010
                • 1095
                Alexanna asked you to check B/Light voltage ??
                With everything plugged in,including a PC input,check the Voltage on the On/Off pin,should be between 3 and 5 volts DC as long as the Logic board has a signal from the PC and has recognised it.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Those are the secondary inverter transformer pins. Your readings suggest they are good.
                  PS. We prefer pictures uploaded here using the manage attachments functions and not inline.
                  --- begin sig file ---
                  --- end sig file ---
                  • Skoffer
                    n00b
                    • May 2011
                    • 32
                    I don't really know what you are talking about. Any chance you can explain in more detail? Where are the On/Off pins?
                    I'm not very experienced using a multimeter. Which setting should I have it on? Where do I put the black wire, where do I put the red?
                    • Skoffer
                      n00b
                      • May 2011
                      • 32
                      Sorry about that. I'll remember next time. It won't let me edit my original post, or I would change it, now.
                      • Rtech
                        • Jul 2010
                        • 1095
                        On the very short side of the Board, there are 8 pins which plug into the Logic Board, they will be labelled on the boards, and you need to put the black probe on Ground and the Red on the On/Off pin and measure DC volts.take your time as obviously there will be Power On, so be very careful.Also Have you got any Spare Loose Backlights, Or another 17 " Screen that is working ??
                        • Skoffer
                          n00b
                          • May 2011
                          • 32
                          I don't have any loose backlights, but I do have a few cracked panels I could probably pull the backlights out of. I DO have another 17" screen that works, but the panel that I am currently testing this inverter with came out of a perfectly fine working monitor. I know that the backlights in this panel work.
                          I am getting 3.26V on the On/Off pin.
                          • Rtech
                            • Jul 2010
                            • 1095
                            In that case, if you are TOTALLY satisfied the B/Lights are good, then the chances are the problem is one of the Mosfets.To take you through that tonight,I'm afraid I cannot do.You need to Get the Part codes off them, and then the data sheets.
                            • alexanna
                              • Mar 2010
                              • 1346
                              If you have good CCFLs that are in broken panel, I would suggest removing them. In future repairs they come in handy because you are able to see if each inverter coil has the ability to light the CCFLs, and if they are of equal brightness.
                              I want to clarify, Dose the on/off pin stay the same voltage when the lamps shut off?
                              • jetadm123
                                • 2169
                                Since the monitor seems to work fine for the first minute and then shuts down, it might be a possible indication of a bad solder joint and/or a component that is overheating. Try cooling the power board with a fan to see if you can get it to remain on for a longer period.
                                • Skoffer
                                  n00b
                                  • May 2011
                                  • 32
                                  Yes, the voltage stays the same. It didn't fluxuate at all.
                                  • alexanna
                                    • Mar 2010
                                    • 1346
                                    Try with CCFLs that are not inside a panel.See if you notice anything different between the bulbs
                                    • Skoffer
                                      n00b
                                      • May 2011
                                      • 32
                                      Ok, I pulled the CCFLs out of a cracked panel that I have. That monitor worked fine other than the cracked screen, so I am aobut 99.999% confident that these CCFLs are working properly.
                                      Anyway, I plugged them in to the monitor and got the same response. When I turn the panel on, they light up, then go off, then flash 1 more time, then nothing.
                                      I have another inverter that I am having a similar problem with, I may post pictures of it later, but it is also off of an Acer LCD and is nearly identical to the one in this thread, except it only has 7 pins instead of 8 pins to the logic board. Anyway, if we can figure out the problem on this one, I'm hoping it will also solve the problem on the other.
                                      Any advice on how to test the mosfets would be much appreciated. But, looking at this board, I'm not sure if I would have the soldering skills to replace them. I've gotten pretty handy with soldering caps, but the mosfets are tiny.
                                      • Skoffer
                                        n00b
                                        • May 2011
                                        • 32
                                        Actually, I can't get the backlights to stay on for any longer than a few seconds, now. The only time it lasted for a minute or 2 was right after I had replaced one of the caps. But, before you tell me to replace the caps again, I have already done this and it didn't solve the problem. To be clear, I have replaced the caps on this board twice, and the second time didn't change the behavior at all. Even if I leave it for a few hours, now, it still just blinks twice and then nothing. btw, the LCD is displaying the image, I can see the desktop when I shine a flashlight on it.
                                          09-06-2024, 05:27 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:00 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                          Acer Swift SF314-511-511S + Pack Gold Acer 14'' Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift SF314-511-511S + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF314-511-511S + Pack Gold Acer 14'' boardview and SF314-511-511S + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 03:10 AM
