Re: DAC-19M009 dead?
1) See attachment for pin numbering.
Any reading under 30 ohms suggest the mosfet is shorted and potentially bad.
2) Did you measure that smd fuse in post #9? Your photo is too blurry for me to know where it is.
DAC-19M009 dead?
This may be a daft question, but I'm using the data sheet here Is the orientation of the MOSFET the same in the picture and in the pin diagram? That is, in the picture at the 'base' of the MOSFET is a cut-out semicircle, is this on the G1/D1 side of the MOSFET?
If that is the case, then S1-G1 is really low (like 0.1 ohm), but all the others are like 1000k (so the MOSFETs are shorted). The alternative is that the circle on the top of the MOSFET marks pin 1. If that is the case, then S-G is off scale, G-D is off scale, and S-D is around 1000k (so they seem OK, and the 0.1 ohms in the previous test was actually testing resistance between the two D1 and D2 pins, so being really low would make sense)Leave a comment:
See
2) Shorted Transistors/MOSFETs
https://www.badcaps.net/forum/showpo...0&postcount=13Leave a comment:
They should be AOP605 MOSFET
"F102" 4A SMD FuseLeave a comment:
Check the U202 and U203 mosfets to see if they are shorted or not. A few people report them as bad.Leave a comment:
Hahha quite true, I'll find a replacement and give it a go. The other reason I hadn't replaced it is that the supplier I got the other caps from didn't have a 22uF 50V low ESR - if I can't find a low ESR one, is there anything else that would be better than general purpose?Leave a comment:
Doesn't matter if it looks OK, it's probably dead.
It's an important startup capacitor.
As for the sound, sounds like the PSU is trying to startup over and over.Leave a comment:
Thanks for the fast replies
I measured 0.5 ohms
(attached) But I think that the logic board is fine. I tested this again with the working DAC-19M009 and it worked perfectly
Originally posted by seancI can see a little capacitor near the bottom of the PSU - have you changed this?
Also, is the board meant to make different sounds when it isn't plugged into anything? While I was testing the pins, I had only the power cord connected, I didn't plug in any of the CCFLs. I recorded this http://******/miVE9M (it was going the whole time I was testing) but I couldn't localize the sound. It doesn't do this when the logic board is connected.Leave a comment:
I can see a little capacitor near the bottom of the PSU - have you changed this?Leave a comment:
2) Post a picture of the logic board.
3) What are the DC voltages on the connector pins between the power/inverter and logic board? Those secondary voltages should be 24V DC or less. Use a ground screw for your black probe.
4) Hookup a working computer with your favourite wallpaper to the lcd. If you shine a flashlight on it, can you see the wallpaper?Last edited by retiredcaps; 06-10-2011, 04:30 PM.Leave a comment:
DAC-19M009 dead?
I have a Chimei 22" monitor with a problematic Delta DAC-19M009 inverter. When I plug it in and turn on the power, after a couple of seconds the green power LED flashes once, and then nothing else happens. I opened it up and had a look at the caps, but they all seemed fine. I replaced them first with some general purpose caps I had (which didn't work) so I've changed all of them except the big one for Panasonic FC and FM caps. But this hasn't changed the problem. The rest of the system is fine, I tested it with a known good DAC-19M009 and it powered on OK (at least, it was when I started! Unless something else I did broke it in the meantime...)
There didn't appear to be anything else wrong with the board. There are some scorch marks in the photo of the back (near soldering points) but those weren't there originally (my clumsy soldering :P). When I turn it on, there is a high pitched squeal exactly as I would expect from it normally turning on, and then the green light turns on. But then the LED turns off, and nothing else happens, the CCFLs never light up. If I cycle the power at the wall, it doesn't do it again immediately (nothing happens), I have to wait a minute to start it all again.
Any ideas? I don't have much experience with electronics or working with mains power so I'm not really comfortable measuring the voltage across the big cap while it is powered onTags: None
by double_DDHi all,
As the title suggests, how can I be sure that my EC chip is really dead?
I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard... -
by whirlpoolHello everyone
IMac model 2017 intel i5 Completely died after updating the operating system , no lights are on the board. I changed the power supply before just to gain experience, but again the problem has not been solved .. I have done a lot of research about it ...
I checked the SMC U5000 and pp3v3 pp5v. If you look at the schematic, the first light is called le0301 with the abbreviation in pp3v3 S5 circuit. before this I get 12 volts, 5 volts and 3 volts in U7600 well. but after U7600 and before reaching LED1_S5 everything is cut off . I reflowed the u5000 with a temperature... -
Hello everyone hope all doing well!
I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...3 Photos -
by BetonHi guys!
I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
I have a bench PSU and if I try to inject voltage the voltage... -
Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)... - Loading...
