Dell 2407WFPb Monitor - Bad Cap
  • sirzur
    • Nov 2007
    • 15
    #361
    Re: Dell 2407WFPb Monitor - Bad Cap
    For the board I am looking at, there is no question that the large cap is gone. One of the legs has rust like material at the junction with the capacitor
    • jetadm123
      • 2169
      #362
      I think you're in the 1% that needs to replace the large 450V cap. Others have also reported seeing that large cap leaking.
      • hartklep
        • Feb 2013
        • Netherlands
        #363
        I had the same problem with rust on the capacitor.
        When i desoldeer the Cap the leg fel off.
        With the Q651 i had the same problem.
        The best thing you can do is to replace the part from the list
        that mr MPX post.
        I had also an defective bridge rectifier
        By Farnel it only cost you abaut 35 euro
        • sirzur
          • Nov 2007
          • 15
          #364
          Yeah, I have had a look at the components and it "looks" fine - so I am kinda hoping someone will be able to answer my 3 questions
          I want to find out the resistance between the 3 legs of Q651 when it is on the board. I get a very small resistance between the 3 legs (about 115 ohm)
          Also what is the resistance across the Zener diode ZD601 on the board? Again, I get a small resistance.
          Would a 2W rating be sufficient for Resistor R670 (0.23 ohm) - this is the only other component that has obvious damage
          Thanks again
          • leapius
            • Aug 2012
            • 60
            • uk
            #365
            I thought I might hijack this thread to ask about my 2407 problem:
            The monitor is completely functional in every way apart from after about 10 seconds from start up it will suddenly flicker from normal to full brightness and stay that way until it is turned off. The brightness setting has no effect once it goes into this full brightness mode.
            I originally changed the inverter to solve a backlight problem as illustrated in this thread:
            https://www.badcaps.net/forum/showthread.php?t=22549
            Now I'm wondering if there is something wrong with my replacement or something else? Any suggestions?
            • hartklep
              • Feb 2013
              • Netherlands
              #366
              Thanks again
              You need an transistortester to check Q651 and the ZD601
              When you R670 is damage there is more damage.
              • jasonkoelling
                • Mar 2013
                • US
                #367
                I have a 2407WFPb with what I believe has a bad power supply. I bought a cap kit to try and repair the power board and after further investigation I found some burnt area's on the bottom side of the board. im confortable replacing caps but I think replacing anything else is a little over my head. any feedback would be great .
                http://s34.photobucket.com/user/jaso...ell%202407WFPb
                • selldoor
                  Slow Learner
                  • Dec 2010
                  • 7870
                  #368
                  You only replaced 1 cap in a row? All the caps are the same age same size in the same place - why would you think only one is bad?
                  Anyway on to the chip - it looks burnt but picture is not close enough to tell for sure.
                  If you are sure its gone then you have nothing to lose in trying to replace it?
                  Some mebers just snip the legs or dremmel them then remove the rest of the legs using tweezers - once you only have legs to unsolder it becomes a lot easier.
                  Is there a part number on the chip and also take note which way around it is on the board before you remove it.
                  Some members will not look at pictures hosted off site. you should post them like this
                  We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
                  Examples of what is needed
                  https://www.badcaps.net/forum/attach...7&d=1280167246
                  https://www.badcaps.net/forum/attach...6&d=1280167246
                  https://www.badcaps.net/forum/attach...4&d=1280167246
                  • jasonkoelling
                    • Mar 2013
                    • US
                    #369
                    Thanks for the reply. that chip , that is chipped does not have any writing or markings on it. I have seen the chip intact in other pictures and it is just black. Going to be hard to find. im almost to the point I would rather just replace the whole power board then to spend time tracking down what cap is bad. I replaced the only 2 that had corrosion on them.. the big 240v and that smaller that looks out of place. I was given this monitor broken for free so all i have invested in it is time and about $10-$15 in caps. Id be willing to sell it cheap if someone wants to take on the project as I dont have the time/know how to troubleshoot boards beyond replacing caps.
                    • terry
                      • Oct 2007
                      • 91
                      • Milton Keynes, Bucks
                      #370
                      Re: Dell 2407WFPb Monitor dead psu
                      Can anyone help , I was given a Dell 2407 monitor with a faulty power supply model numer 4H.L2K02.A01
                      The 400v cap was leaking, R670 blown, Q651 (2sk3502) blown and the main fuse has blown.
                      I have replaced the 400V cap, R670, Q651 (2sk3502) and the main fuse, No bang but still no power out.
                      I then replaced the IC651 (L6561D) but still no power out.
                      I have the 300v DC @ L610 TO R605, 166V from R605 to R604 and only 19v from R604 to C614, after that @ T601 no volts.
                      • jasonkoelling
                        • Mar 2013
                        • US
                        #371
                        Anyone know where to get a replacement or alternate board for the 2407? for under $50.
                        Iv found a few online but they are all over $50 and it just isnt work that much to me.
                        4h.l2k02.a01
                        5E.L2K02.001
                        4H.L2K02.A11
                        https://www.myallparts.com/-p-188.html
                        • selldoor
                          Slow Learner
                          • Dec 2010
                          • 7870
                          #372
                          Can you post a good clear picture of your power supply board
                          • terry
                            • Oct 2007
                            • 91
                            #373
                            Here are some pictures of the power board, hope they help. The large green cap is fine, the marks are where it was glued the other way up on the power board I removed it from.
                            Terry
                            • selldoor
                              Slow Learner
                              • Dec 2010
                              • 7870
                              #374
                              Quick questions - I have to go out
                              The Big cap IS the right way round?
                              There is a small yellow torpedo fuse F701 just to the left of the big cap - does that test ok. Resistance and voltage both sides with respect to ground screw.
                              I think on the Main Board - all these posts and I cant spot a single decent picture of the whole board- near one of the connectors there may be a small black rectangular fuse with a 20 or 2.0
                              on it - if you can find it can you test it as well.
                              • terry
                                • Oct 2007
                                • 91
                                #375
                                The big cap is the correct way round, I have checked F701 and that's fine. I have had a good look at the board and I can not see any more fuses.
                                I have just uploaded some full size pictures to my website, if you want to have a look at them that would be great. www.linfotech.co.uk/psu1.jpg www.linfotech.co.uk/psu2.jpg
                                Terry
                                • selldoor
                                  Slow Learner
                                  • Dec 2010
                                  • 7870
                                  #376
                                  Yes the small black fuse maybe is on the Main Board
                                  It was that I was wanting a picture of
                                  On the back of the psu the solder around one of the heatsink joilnts looks a bit odd touching the other trace? (maybe just the picture)- perhaps just try cleaning it up a bit.
                                  • terry
                                    • Oct 2007
                                    • 91
                                    #377
                                    Here is a picture of the video board the only fuse on it is the white 3A one. this is ok, I know to power board is the problem, if I use a bench test PSU then the monitor works great.
                                    • selldoor
                                      Slow Learner
                                      • Dec 2010
                                      • 7870
                                      #378
                                      Hmm- right - it must be on the board under the metal plate but if you say you can power it up externally then it must be ok SO- back to the psu.
                                      Can you carefully test the volatage across the legs on the Big Cap.
                                      Meter on vdc600.
                                      Maybe also check your mains voltage meter on VAC600
                                      • terry
                                        • Oct 2007
                                        • 91
                                        #379
                                        Yes volts on the main cap correct, I have found out I have no volts on the 200A6 chip (pin 6), or on the transistor that powers chip L6516D (pin 8), but the volts are correct on the 200A6 chip (pin 8). I have 19 volts out of R604 which I think is where the chips get there power. After R604 no power at all.
                                        • selldoor
                                          Slow Learner
                                          • Dec 2010
                                          • 7870
                                          #380
                                          Yes, but how many volts on the main cap?
                                          • keepread
                                            Dell monitor PSU vs Dell laptop PSU
                                            by keepread
                                            Hi there!
                                            Someone gave me their old monitor, it's Dell S2715ht.
                                            The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                            Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                            10-30-2025, 04:45 PM
                                          • MORETTIGIAN
                                            by MORETTIGIAN
                                            Title:
                                            Description:
                                            Procedure performed:
                                            - Removed backplate
                                            - Reapplied thermal compound
                                            - Reassembled card
                                            09-18-2025, 12:14 PM
                                          • Borse2008
                                            by Borse2008
                                            • There’s
                                            07-15-2025, 04:55 AM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
