Dell 2208WFPt
  • Freezer
    • Jun 2010
    • 124
    Dell 2208WFPt
    My latest project is a Dell 2208WFPt, a 22" widescreen computer monitor with LCD backlighting. The problem is it doesn't always display the image on screen. Sometimes you turn it on and you can see the image, but most of the time with you turn it on there is no image on screen. The flashlight test confirms the problem is the backlights aren't always coming on. Before I even open up the monitor I suspect bad capacitors.
    This monitor is noticeably newer than previous monitors I've worked on. Most monitors I've worked on are from about 2005, but this monitor dates to 2008, which means it failed in the 2 - 3 year time span.
    Disassembling the monitor is a bit of a challenge. You start by pressing the button on the back of the screen which releases the stand. After you remove the stand there are four screen in the back of the monitor (behind where the stand was). Next flip the monitor over so the screen is facing up. Now the tricky part. You need to pull/pry the black bezel up away from the screen. To do this I used one hand to pull up on the screen from the inside of the bezel (I got my fingernails between the bezel and the glass of the screen). At the same time I used a screwdriver in the other hand to pry at the bezel from the outside. The trick is to pry the silver frame away from the black bezel. You need to start on the side of the monitor furthest from the controls. Next work the top, then the other side. Finally you can work the bottom, but be careful the of the circuit board for the controls. The wire is soldered to the circuit board and there's very little slack. Once the bezel is free you can remove three tiny screws holding the circuit board to the bezel. This multi-part video shows the disassembly I've described thus far.
    Next you can lift out the screen. To remove the circuit board cage you need to remove all the wire connections, and there are 4 screws holding the cage to the side of the panel itself. Be careful with lifting up the screen, you must slowly lift it up and reach underneath to disconnect the LVDS ribbon cable.
    Finally you can remove the circuit boards. You need to remove both the video and power boards as the connecting cable makes removing just one difficult (if not impossible). There are 3 screws in the video board plus the 4 hex screws by the VGA and DVI connectors. The power board has 4 screws plus 2 black screws by the AC input plug, AND there are two silver screws on the backside which hold two heat sinks in contact with the metal cage. Finally, the video and power boards are free.
    Immediately I noticed 2 bulging caps on mine, located at C127 and C128. I also noticed this monitor has a lot of capacitors in it. Typically a monitor power board has 5 or 6 electrolytic capacitors in it, but this monitor's power board has 20 (not counting the big reservoir capacitor). This monitor has a mixture of CapXon and Su'scon caps. I used my ESR meter to test all the caps and only those two were bad (ESR of about 89 ohms). But given those caps failed in less than 3 years time, I decided to replace every caps on the power board (again, excluding the big one). I used all Panasonic EB series (or FM series where EB series were not available). This ended up being a more expensive repair at $13 including shipping.
    After replacing all the caps and reassembling the monitor, it powers up first time every time.
    Hopefully this review of my repair helps someone else.
  • jetadm123
    • 2169
    Re: Dell 2208WFPt
    Interesting board. It's stamped 2007, yet it looks like an earlier board because of all the discrete components used . Did they use any surface mount (smd) components on the bottom of the board? Also, it would have been better if you used all Panasonic FM for replacements, since the EB series is not really a low-esr cap.
    • Freezer
      • Jun 2010
      • 124
      Re: Dell 2208WFPt
      No, the bottom of the board had no surface mount components.
      Good to know about the FM versus EB, in the future I'll use only FM components. I was using EB because of the long life.
      • retiredcaps
        • Apr 2010
        • 9271
        Re: Dell 2208WFPt
        On some uF and V, Panasonic FR is equal to FM, but has longer life (10K hours vs 5K hours).
        --- begin sig file ---
        --- end sig file ---
        • tarkus
          • Oct 2011
          Re: Dell 2208WFPt
          noobie on this site and have same problem with a Dell monitor. Would you have kept a parts list when you replaced caps, if so could you pls. post. thanks
          • Executor
            • Dec 2012
            Re: Dell 2208WFPt
            I just wanted to thank you for your post, Freezer. Using it as a guide, I was able to refurb a 2208WFPt that a customer had dropped off for us to take to recycling. In my case, all five of the CapXon 330μF 35v caps were bad, bulging and leaking electrolyte. I replaced them with Panasonic FM caps, which only cost me $7 incl. shipping for a pack of 20 on eBay, and it now works perfectly. Now we have a much nicer monitor at our main diagnostic workstation.
            • Fiddler1
              • Jun 2014
              Re: Dell 2208WFPt
              This is what is wrong with my monitor! Thanks for a great vid on youtube as well.
              • k-h
                • Sep 2014
                Re: Dell 2208WFPt
                This is an old thread now but I just got a Dell 2208wfpt which shows no picture at all and was able to take it apart thanks to that video and found the board had a blown cap. Mine is the C815. I'll replace it and see how it goes.
                • turmix
                  AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                  by turmix
                  Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                  The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                  At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                  During another reassembly, I made a mistake, and...
                  01-29-2024, 03:48 AM
                  by momaka
                  03-15-2023, 10:17 PM
                • abajor
                  A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
                  by abajor
                  Having this very weird issue.
                  The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
                  I swapped with a working screen from an A2141 waiting for parts.
                  The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
                  The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
                  04-27-2024, 01:37 PM
                • 3D Modelka
                  AOC 27 monitor Q27G2WG4 doesn't display logo or image on screen
                  by 3D Modelka
                  Hello. I have a problem with my AOC 27 monitor, specifically model Q27G2WG4, which I have been using for 3 years. The monitor stopped turning on: when I turn it on, the backlight turns on, the indicator starts glowing white, but the logo on the screen does not appear, and there is no image. However, if I check in the Windows system, the monitor is displayed as connected and working. I tried connecting it via HDMI and DP, but the result remains the same. If I turn the monitor on and off multiple times, it will eventually start and work. However, when the monitor is working, there are no issues....
                  02-09-2024, 02:42 AM
                • ChristianBr01
                  Dell 34 inch U3419W Monitor with thin stripes on partial screen
                  by ChristianBr01
                  I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
                  This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
                  This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
                  Does someone have seen this before?...
                  05-23-2025, 06:06 AM
