Dell 2000fp main board
  • sabre504
    • May 2010
    • 449
    I have had this dell 2000fp for a while self test screen works so lamps and inverter board are ok .
    No inputs work so suspect the main board as have read a few threads on the problem .
    I was just wondering if anybody UK side had found the ram chip or a main board supplier ?
    Or maybe someone had one with a broken screen
  • sinip
    • Dec 2011
    • 18
    • Republika Srpska
    Re: Dell 2000fp main board
    Did you manage to find anything? I'm having the same problem and looking for the same solution...
    • sinip
      • Dec 2011
      • 18
      • Republika Srpska
      If you still need the chip, or at least its content, read https://www.badcaps.net/forum/showth...t=10014&page=2
      • sabre504
        • May 2010
        • 449
        Hi try this A29L800ATV-70F it specs out the same as the chip required
        I bought one but when i went to fit it i dropped it and snapped 3 pins
        so cant say if it works till i get another
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • ygorsan
          by ygorsan
          🧩 Problem Summary:
          • I
          07-28-2025, 08:34 AM
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
        • JDC
          by JDC
          ONN 100012588
          Long answer:
          07-15-2022, 07:39 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
