vx922 recapped still fluctuating power
  • blutch
    • Mar 2011
    • 18
    i also have a vx922 with fluctuating power from the 12v rail between boards. i have replaced all caps but the large 400v. still the power goes from 12v to 4v and repeats over and over. and the screen and green power light blink in time with it. what else could be the problem?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: vx922 recapped still fluctuating power
    1) A clear focused picture of your boards using the manage attachments function would help. Please do not post inline as it slows down loading of pages.
    2) If you disconnect the logic board and ccfls, does the power board (now standalone) have steady 12V DC?
    3) What brand and series did you use for replacement caps?
    --- begin sig file ---
    --- end sig file ---
    • jetadm123
      • 2169
      Sounds like a possible short in the system. Power supplies for this monitor were supplied by different manufactuers, so without photos, help will be limited. If it's the power supply I'm thinking about, with power off, try checking the 4 surface mount transistors under the board marked "DK"? for shorts. Post some clear focused photos of the top and bottom of the power board. Do not post them inline, use the "manage attachments" button.
      • blutch
        • Mar 2011
        • 18
        is the circled fuse 1 supposed to be connected to the12v connector ? looks like the fuse moved , but is still connected well.
        as for power when disconnected from the rest. no very minimal. when they are all connected, and the power switch is off, i get a steady 12.42v.
        as for the type of caps, not sure it was all i could find at alfatronics. but i have all new panasonic fm caps comming from digikey soon.
        thanks
        • blutch
          • Mar 2011
          • 18
          ok i sent the pics.
          when i disconnect the power board completly, minimal voltage.
          as far as caps....NRWA series M for the two 470uf 25v (mine are 35v), and another no name with just an M on it for the one 330uf 35v, also the 2 big caps on the logic board g-luxon 411b(M) 330uf 16v, and one sheng 100uf 25v on the logic board.
          if i put it all together again and plug it in with the power switch off i get a constant 12.42 v on the 12v connector between boards
          • alexanna
            • Mar 2010
            • 1346
            Originally posted by jetadm123
            Sounds like a possible short in the system. , try checking the 4 surface mount transistors under the board marked "DK"? for shorts. .
            Look on your 4th picture lower right corner just above the white glue.
            • blutch
              • Mar 2011
              • 18
              what do you see?????
              • alexanna
                • Mar 2010
                • 1346
                I guess it could be the angle or lighting, But 2 transistors look melted to me.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  I give up. See
                  https://www.badcaps.net/forum/showth...773#post156773
