Westinghouse Monitor Issue
  • White-Powder
    • Mar 2011
    So 2 Westinghouse Monitors in which the led on the front will turn green when plugging into my computer, but no display will show. After reading numerous threads, I opened my monitor to find that several of the caps are bulged. My monitor uses DAC-19M005.
    I happened to come across the following link to replacement caps and mosfets on ebay and I am wondering if this is a good solution? I know it may or may not fix the entire problem however. Ebay link: http://cgi.ebay.com/Westinghouse-L20...-/320608826408
    Second, if these above items do not completely fix the problem, I will be lost since I have no electronics knowledge when it comes to stuff like this. I also have never done any soldering to this type of electronics and I noticed on the back side such as the mosfets that the solder for each pin is not touching. How can I keep that from touching as I assume it would short out if it was one big blob.
    Lastly, is any member on here willing to replace the needed items for me for a small charge. I am on a budget and do not want to fork out tons of money. I would also pay for shipping and return shipping.
  • smason
    • 1652
    Re: Westinghouse Monitor Issue
    Where on the planet are you?
    • White-Powder
      • Mar 2011
      Wisconsin, sorry I forgot to fill that into my profile.
      • retiredcaps
        • Apr 2010
        • 9271
        There might be someone willing in your area to help, but if not, find a friend that has a multimeter and soldering iron. The kit on ebay comes with mosfets and a fuse which you may or may not need. To verify if your mosfet is shorted and if your fuse is open, you will need a multimeter.
        --- begin sig file ---
        --- end sig file ---
        • Lumberjack777
          • Dec 2010
          • 464
          Is that a DAC-19M005 (AF) (BF) or (DF)? You should find a revision number underneath the DAC-19M005 marking. I believe that model used the DF.
          Fortunately that is a very popular board, and you can buy them new from Hong Kong / China for about 20 to 25 bucks including shipping on eBay.
          If memory serves me right, I had a Westinghouse just like yours with the DF revision. (correct?) (maybe it was BF) Anyways, I ended up taking a chance and buying the AF revision on eBay and desoldering the green audio jack before installing it. My friend I sold it to said it's been working great for months now.
          I realize it's not as much fun as doing all the testing and soldering. But for 20 something bucks it was worth it to me to save the time.
          • White-Powder
            • Mar 2011
            Hmmm, I see those but they are used. I already ordered the parts to fix this one with better caps, a 4amp fuse and the two mosfets so I'll just see if I can fix this one and if not, I'll just buy one of those maybe.
            • Lumberjack777
              • Dec 2010
              • 464
              No, most of those listed from China and Hong Kong are new. Like this one - http://cgi.ebay.com/Power-Board-DAC-...item3365fc3d2d
              But hey, it's always good to get your feet wet and try and fix it yourself. Good luck!
              • DqMagetz
                Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
                by DqMagetz
                Good day!
                I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
                Here are the voltage readings:
                • Input – 19V (stable)
                • +LCDVDD – 3.3V briefly, then drops to 0V
                • EDP_HPD – 3.3V briefly, then drops to 0V
                • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
                • EC BKOFF# – 1.8V briefly, then drops to 0V
                • PANEL_OD_EN – 0.3V
                Is it possible that the EC chip is corrupted or damag...
                07-12-2025, 09:37 PM
                Westinghouse L2210NW LCD monitor - bad caps repair
                by momaka
                Here's another LCD monitor repair: Westinghouse L2210NW.
                Quick specs: 22” CCFL backlit LCD, 1680x1050 max resolution (16:10 aspect ratio)
                I got it with a bunch of desktops PCs from a repair shop that was trying to free up space a few years ago. It seemed like a cheap monitor, so I didn't really care that much at first when I picked it up (and indeed it is, picture-wise.) But hey, free is free, so I can't complain. Moreover, it looked clean and the screen didn't have any significant scratches or blemishes.
                Pictures of the monitor outside/case after a brief...
                01-11-2021, 01:14 AM
              • Rick_1234
                by Rick_1234
                Good evening, gentlemen.
                Things I tried
                06-22-2024, 04:44 PM
              • sew333
                Pc shutdown, monitor flickered with no signal after 10 seconds
                by sew333
                My pc:
                10850K stock 4800mhz stock Kraken X73 good temps
                2x16 GB DDR4 GSKILL 3000mhz XMP
                Seasonic Tx-850 Ultra Titanium
                Gigabyte Rtx 3090 Gaming OC
                Aorus Z490 Pro Gaming
                1 TB SSD
                4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                Power...
                02-22-2022, 10:27 AM
              • FercHeliX
                LG 1510S Monitor Issue
                by FercHeliX
                Hi
                There's this old LG 1510S LCD Monitor that had 2 issues, one with inverter board and one with image display (mainboard maybe), the issue with the inverter was that when i turned it on it goes off after 1 or 2 secs. and the problem was with the tuner caps on inverter board, after i changed the caps monitor stays on but there's another problem that if I turn it on by the power button, no signal message does not show on the screen, but if I let it stay on and disconnect by the power cable and connect it again the no signal message will appear, and one more thing...the 12V power is 17V before...
                01-28-2022, 08:20 AM
