Re: HP lcd L1502 15"
Thanks guys!
HP lcd L1502 15"
PlainBillLeave a comment:
Samsung's and LG's mostly die from bad caps. those are usually the easiest to fix.
Especially the 22" Samsungs (T220, 2233BW, 225BW, 226BW etc. ..)
those are a good start. they're pretty common and there are quite a few threads on here
PS: *jealous about your tablet pc* >.>
:/ school made us buy tablets. Its what they call "paperless campus". They make you buy the pc then they charge a student arm and a leg for the maintenance and repairs.Leave a comment:
PS: *jealous about your tablet pc* >.>Leave a comment:
Thanks guys
I was looking for some big screens online, but they go for too much. Any suggestions where I can pick some up?Leave a comment:
A very good suggestion. I'm using a 23" KDS wide screen monitor that cost me about $20 - $15 for the non-working monitor and $5 for the caps to fix it. With a little judicious use of your time you could be using a much larger monitor and have made money on the upgrade!
Good job... Next time look for a bigger screen to fix.Leave a comment:
Hello Everyone!
Today I received my C5707 transistors. I went ahead and solderd them in and as you can see on the picture I am using my fixed and working monitor to post the update
I changed only one set of C5707's and resoldered the other two. I also resoldered all the transformers. Hopefully this monitor will last me another few years
I am a college student, so I try to save any way I can. I just wanted to say thank you to everyone who helped me fix my monitor (retiredcaps, plainbill, th3, kaboom, alexanna and steve2). I would not be able to do it without you guys. I have learned few things about electronics along the way. So thank you guys again!! You helped me save some money!
sincerely,
leoLeave a comment:
I just tried testing it in circuit and it read 0.3 ohms. So I think it is good. Thank you Retiredcaps!Leave a comment:
Thanks Paul. Now my next step is buying transistors. I will let everyone know about my results.Leave a comment:
Yes.
KSD1691GS
Works fine. 512-KSD1691GS at Mouser. They are TO-126.
Replace ALL caps and resolder inverter board around transformers, tuning caps, brightness PWM and AC inlet, as well as any other cracks you see.
-PaulLeave a comment:
it was actually a fuse, not resistor.
Here is the link:
http://cgi.ebay.com/REPAIR-KIT-E172F...item4aa96195f6Leave a comment:
I have seen some repair kits on ebay. They include some additional resistor. I remember reading here on the forum something about changing it, but it might have been on the dell monitor. Do you think I will need to do that?Leave a comment:
Thank you guys. You have been very helpful and I feel like I am learning a lot!Leave a comment:
by B0r1sPSU - BN44-00878A
Symptoms:
The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
A weak clicking sound was coming from the transformer.
Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
Progress:
After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I... -
by slimmy182Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
Looking on google I found this:... -
by beetle1303I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...3 Photos-
by mikelu53I have a UN60D8000YF with a BN44-0432A power supply and a BN41-01622C main board.
The set was working then not,then started clicking.
Wilth the power supply disconnected from the main board I can occasionally get it to power the LED back lights , getting it to stop clicking is luck.
Checked caps and diodes and mosfets the best I could. When it stop clicking there is 5v and 18v on the connector to the main board.
A schematic or suggestion would be great.
Thanks -
by bffargoLG 60PB66550 NOV 2014
PSU: EAY63168603
PCB: EAX65359531 2013.11.01 Rev:1.0
Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
Symptom:
While watching, just went black and started clicking relay every few seconds.
Initial diagnosis:
Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
Deeper diagnosis:
Pulling pins #1/#2 (Blue/Grey) from the connector housing... - Loading...
