HP lcd L1502 15"
+ More Options
Latest Activity
  • Th3_uN1Qu3
    replied
    Re: HP lcd L1502 15"
    That's the logic board. It's kinda obvious that it won't do it without the logic board connected, since the logic is what instructs the inverter to turn on.
  • leov
    replied
    Hi PlainBill,
    Thanx for taking time to look into this for me. I used united chemi-con caps from Digi-key.
    Also, I found out that the problem occurs when I connect little circuit board that has VGA connector on it. If its not connected, there is no clicking heard on the big board.
  • leov
    replied
    Originally posted by sabre504
    Hi did you test the transistors that you have arrowed (probably 5707 or 5706 markings on them )
    Also did you resolder the 4 x transformers
    If you check threads that deal with Dell 172 monitors they have the same type of board and have the same symptoms
    Hi sabre, Thank you for replying to my post. I appreciate your help. The transistors are 5707. How do I go about testing them? I have very limited understanding of these things. I did not resolder the transformers.
  • PlainBill
    replied
    Originally posted by leov
    Hi guys. I am very new to this, but was hoping you would help me fix my lcd. Originally, the screen started to turn itself off randomly. I was able to restart it, but after few days it shut down and I was not able to bring it back to life. I replaced all 25V 470 uF caps on this board. They were not blown, but looked like they were starting to "inflate". (sorry, i am not sure what the proper terminology is to describe it). That did not fix the problem though. When I connect the power cable I can hear a clicking noise coming from the parts that I circled on the picture. They turn really hot if the power cable is connected. Would someone please tell me what I should do next? How do I go about testing the other components on the board? Thank you.
    This is a classic example of the problems with these monitors. As sabre504 said, replace both transistors (2SC5707). Also resolder all pins on the 4 inverter transformers. Just for luck, I'd also replace the cap that was clicking.
    What brand and series capacitors did you use as replacements for the bulging caps?
    PlainBill
  • sabre504
    replied
  • leov
    started a topic HP lcd L1502 15"
    HP lcd L1502 15"
  • B0r1s
    Samsung UE49KS7000SXXH - fast clicking sound in standby mode
    by B0r1s
    PSU - BN44-00878A
    Symptoms:
    The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
    A weak clicking sound was coming from the transformer.
    Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
    Progress:
    After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
    01-17-2023, 04:58 PM
  • slimmy182
    [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
    by slimmy182
    Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
    I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
    Looking on google I found this:...
    01-14-2023, 11:55 AM
  • beetle1303
    Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
    by beetle1303
    I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
    On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
    01-13-2025, 08:49 PM
  • mikelu53
    Samsung UN60D8000YF Clicking BN44-0432A
    by mikelu53
    I have a UN60D8000YF with a BN44-0432A power supply and a BN41-01622C main board.
    The set was working then not,then started clicking.
    Wilth the power supply disconnected from the main board I can occasionally get it to power the LED back lights , getting it to stop clicking is luck.
    Checked caps and diodes and mosfets the best I could. When it stop clicking there is 5v and 18v on the connector to the main board.
    A schematic or suggestion would be great.
    01-21-2023, 03:14 PM
  • bffargo
    2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
    by bffargo
    LG 60PB66550 NOV 2014
    PSU: EAY63168603
    PCB: EAX65359531 2013.11.01 Rev:1.0
    Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
    Symptom:
    While watching, just went black and started clicking relay every few seconds.
    Initial diagnosis:
    Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
    Deeper diagnosis:
    Pulling pins #1/#2 (Blue/Grey) from the connector housing...
    09-09-2022, 07:34 PM
