AOC Envision L19W861 failure
  • mrfixit01
    replied
    Re: AOC Envision L19W861 failure
    Originally posted by retiredcaps
    We need a clear focused picture on the backside of the power/inverter board. Yes, measure the resistance with power off and lcd unplugged.
    The secondary inverter transformer pins are the ones "leading to" or connecting to the blue high voltage caps.
    Here is a close up of the backside of the board. Measured resistance across terminals 8 & 9 displayed .45 m/ohms. I also tried to measure across the two blue caps but received no readings on any setting of my meter. However, I also found another flat panel lcd with similar ccfl plugs so I tried plugging it in to the AOC Envision. The display came up with my desktop and stayed on for several minutes.
  • mrfixit01
    replied
    Originally posted by mrfixit01
    Lol. Guess I missed that one. Sorry. Which one is the secondary transformer(s) or which terminals should I test? Power off I guess? Thanks.
    I see now it is 801, the one to the left center side of the board. Which terminals should I test? Do I ground one probe and test all of them? Sorry for being so slow. Trying to do a million things here. I appreciate all your help, just please be patient with me. I'm just trying to help out some other people with this and not charging anything for the work.
    Your previous post just showed up after I posted this one. I see it now. Will do tonight and report back here asap. Thanks.
  • retiredcaps
    replied
  • mrfixit01
    replied
    Post #8? What did you get for ohms measurements on the inverter secondary transformers?
  • retiredcaps
    replied
    I've already tried everything everyone has suggested. Please?
  • mrfixit01
    replied
    So, I guess no one has any additional ideas on the AOC Envision 19"? I'm open to any more ideas. I've already tried everything everyone has suggested. Please?
  • mrfixit01
    replied
    This appears to be a case of 'two seconds to black'. You can verify this by hooking up a source with audio and video, stepping through the inputs, and verifying that sound remains after the backlights go away. You test verified that the backlights are shutting down, they are not being shut down by the signal card.
    Possible causes include bad caps, bad CCFLs or the wiring to them, a bad inverter transformer, or a bad component in the inverter protection circuitry. I see several possible approaches. The easiest appears to be a very rudimentary CCFL test. Disconnect all but one CCFL. Turn on the power. Do you get a display on the screen (it will be dimmer than normal)? Turn off the power, disconnect that CCFL and connect the next one. Turn on power. Repeat for the remaining CCFLs. If one CCFL does not produce light, that CCFL or the wiring for it is bad. If all light to the same brightness, I'd pull the power supply / inverter board and look for any signs of problems on the back side. If nothing shows up, replace all the electrolytic caps on the power supply / inverter (with the possible exception of the large electrolytic).
    If you have another monitor with 4 good CCFLs with compatible connectors, try hooking up all four. If they stay on, the problem is the CCFLs in this monitor.
    PlainBill
    I guess by CCFL you mean the 4 plugs that go to the back lights. (I'm a real newbie, now.) I tried unplugging all the wires and plugging them in one at a time. The same thing happened as before, just dimmer. I already replaced all the PSB e-caps except the large one. I have looked at the back of the boards twice now and don't see anything abnormal. Thanks for all the help so far. Check back later.
  • PlainBill
    replied
    PlainBill here's what the cn902 labels are on the top right of the PB; (L-to-R) +12v, +12v, G, G, +5v, +5v, +5v, G, G, N/F, Dim.
    reading the +12v pins: 13.08v, the +5v pins: 4.96v, N/F fluctuated between around 200 & 400 mv off and jumped to 3.96v on. Dim read 2.6v on but varied between 4.0v & 28mv off. Turning pwr on then off Dim went from 28mv to 2.6v, jumped to 3.4v & dropped quickly back to 2.6v and steadied there until pwr off then back to about 28mv. Hope this helps. Thanks.
    PlainBill
  • mrfixit01
    replied
    Originally posted by alexanna
    Is this thing a television?
    Wonder if the flashing light is some kind or error code?
    According to their manual it is a sort of power on test. Normal action. Thanks.
  • mrfixit01
    replied
    Alexanna, yes, it's a TV. I can identify RF, Composite, S-Video, Component, HDMI, VGA and audio inputs.
    Mrfixit01, there are three possibilities, a failure of the backlight circuitry, a problem with the power supply, or a failure on the signal board. Because of your source of caps I will temporarily ignore the power supply as a possible cause of the problem.
    In the upper right corner of the power supply / inverter board is CN202, an 11 pin connector linking the power supply / inverter to the signal board. It appears the pins on the connector are labeled. We'll try this the quick way first. One of the pins turns the inverter on and off, another controls the brightness. The first is commonly labeled BL_ON (or something similar), the second is commonly labeled BRI. I'm interested in the behavior of the BL_ON pin. With the TV off, but (hopefully) connected to a signal source, monitor the voltage on that pin while you turn the TV on. It should start at 0 volts, jump to over 3 volts when the backlights come on, and then may, or may not drop back to 0 volts when the message vanishes. Report the behavior.
    IF you are unable to identify the pin I am referring to, either list the labels on the connector or post a picture.
    PlainBill
  • mrfixit01
    replied
    Originally posted by jetadm123
    You have two heatsinks opposite each other with a cluster of cap between them. The devices mounted on the heatsinks are diodes that output the 5V and 12V. With your black probe to ground, use your red probe and measure the voltage of the middle leg of each diode and record the voltage.
    jetadm123 I checked the diodes. the one on the left read 13.12v on both legs. the one on the right read 5.0v on both legs with center hot (red).
  • mrfixit01
    replied
    Wow Guys!!! Thanks for all the info. I have been at work all day but will print this thread and try to follow up on it tonight or tomorrow. Super Helpful... Oh, it does have a tuner so it can be used as a TV or just a monitor. Presently it is used as a closed circuit surveillance monitor. B
  • PlainBill
    replied
    PlainBill, I Am always learning when I read about things posted in the forum.
    Is there a possibility the source of video in may need to be manually selected?
    Yes, but usually a 'No Signal' message would last for longer than 1 second.
    My thought processes was that it would be easier to suggest checking the BL_ON line than hooking up a working signal source and stepping through the inputs. After all, some TVs require hitting 'Input', selecting an input, then hitting 'OK'.
    PlainBill
  • alexanna
    replied
  • PlainBill
    replied
    PlainBill
  • alexanna
    replied
  • retiredcaps
    replied
    The inverter transformer is PT801. Report and measure the resistance of the secondaries.
  • jetadm123
    replied
  • mrfixit01
    replied
    Here's the parts list of those I did replace. (1 ea) 25v-1000uf, 10v-680uf, 25v-470uf, 16v-470uf, 16v-330uf, 50v-22uf.
  • mrfixit01
    replied
    PlainBill:
    Thanks for asking. I bought a kit from LCDalternatives.com which claims "We only sell high quality capacitors manufactured by Panasonic, Nichicon, and Illinois". I can't tell by looking at the caps what brand they are, however. Some are gold/black some are black/silver or white color.
  • ngml
    Repair of an LG split AC system indoor unit PCB
    by ngml
    I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
    This indicates an error in the communication between the outdoor and the indoor unit.
    The outdoor unit is fine, so the problem is the indoor PCB.
    The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
    I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
    Does anybody have the schematics of this board,...
    02-01-2025, 12:55 PM
  • bauto601
    KDM 480W PSU upgrade succes! (opinions?)
    by bauto601
    Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
    A "nice" YoungYear unit? - Badcaps
    The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
    12-26-2023, 03:05 PM
  • valvashon
    Repair Success! Middle Atlantic UPS2200R-IP
    by valvashon
    Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
    Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
    02-06-2024, 12:54 PM
  • carrzkiss
    Cyberpower cps1500avr not charging batteries
    by carrzkiss
    Hello, all.
    Cyberpower Battery Backup Unit.
    I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
    When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
    In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
    Checking the voltage, it was down to 22v.
    I quickly removed everything...
    06-15-2024, 02:10 PM
  • madcrow
    Tearing-like display artifacts on Philips BDM4065UC
    by madcrow
    Hi There,
    Anyone familiar with this kind of display artifact?
    Gallery: https://imgur.com/a/tYc2dWK
    At a superficial glance, it sort of looks like screen-tearing. But that square-wavy boundary is weird...
    The phenomenon was detected on
    • 3 screen <=> PC combos consisting of
    • 2 different screens (same model: Philips BDM4065UC)
    • driven by 2 different PCs via
    • 2 different Nvidia GPU models (one desktop, one mobile) multiple generations apart,
    • running on 3 different Nvidia drivers, each with siginficant age-gap,
    • under Win10 Pro 22H2.
    Connections...
    10-26-2024, 01:38 AM
