NEC lcd1970NX Lines ( bad nichion caps from 2004?)
+ More Options
Posts
  • DigitalStone
    • Jan 2011
    • 39
    Picked up a 19 inch NEC. It has two inches of vertical lines that don't quite look right. You can see a video of it below that another guy posted.
    Mine does it as soon as it receives an image from the pc.
    http://www.youtube.com/watch?v=JlUtZ4_hYYU
    Tried VGA cable and got the "crazy" pixels.
    Switched to a HDMI cable on another pc and again "crazy" pixels.
    When the menu shows up saying there is no input it looks normal.
    There are nichion caps on the board that reads 2004 for mfg date. (j2060193 pcb-019 2004.10.07) and the power board.
    Read in the forums that some of nichions were not quite up to specs during that time.
    Did a close up visual inspection and none of the caps show any signs of bulging.
    Is it safe to assume the caps are from the "bad" nichion era and replacing
    them would fix the display?
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: NEC lcd1970NX Lines ( bad nichion caps from 2004?)
    that's either a problem with the panel itself, or the LCD controller chip (i bet it's BGA..)
    the only nichicon series affected are HM and HN ..
    • DigitalStone
      • Jan 2011
      • 39
      Would replacing the board fix the problem?
      I thought it was odd that when the "no signal" image popped up it was clean
      and when it got a signal then it would act up.
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
      • black6host
        Replacement caps for Samson Resolv studio monitor 65A Amp board.
        by black6host
        Good day!
        I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
        I'm going to replace the caps and I'll be the first...
        02-06-2024, 08:22 PM
