HannsG HG281D Problems
  • will_raymo2000
    • Feb 2011
    Hello all,
    I have been scouring the internet for a source of help for this truly annoying problem and have finally found you guys. It seems quite a common thing that an LCD turns on fine but than blacks out by my problem seems to be a little intermittent...
    It sometimes stays on for 30mins or more without blacking out but then the 2 second blackouts come. Sometimes non stop for 5 or so minutes and then nothing for a while. I have noticed this problem occurring from about 3 months ago but thought it was a problem with my graphics card/HDMI Lead but I replaced both these and the problem continued.
    I have found a temporary solution - changing the resolution from 1920x1600 to 1680x1050. This resolves the blacking out problem but for obvious reasons the screen no longer looks sharp and crisp (the reason I bought the screen in the first place.)
    Just wondering whether this sounds like a PS issue or maybe a logic board problem? I was just finding it hard to compare this problem with other problems in threads on here as the change in resolution resolves the problem.
  • alexanna
    • Mar 2010
    • 1346
    Re: HannsG HG281D Problems
    Originally posted by will_raymo2000
    Hello all,
    Well some pictures sure would help, use the managed attachments.
    I would be curious to know what the back light on signal is doing when the monitors lamps shut off ,also dose the dim voltage change.
    • HTR-Informatique
      Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
      by HTR-Informatique
      YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
      I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
      On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
      I also changed the screen because the PC fell and the screen was broken.
      I changed the battery with a new and original battery.
      I also had corrosion/oxidation on the...
      02-09-2025, 06:51 AM
    • Zeonalbasta
      Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
      by Zeonalbasta
      i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
      The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
      09-13-2024, 01:17 PM
    • Gibon378
      Problem with stopping audio and video for no reason
      by Gibon378
      PC Specs:
      • CPU: Ryzen 5 1600
      • GPU: GTX 1080 Palit JetStream
      • MOBO: ASRock ab350 PRO4
      • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
      • PSU: XFX 650W (don't remember what model)
      • OS SSD: ADATA SP920
      • OS: Windows 10 21H2
      Problem description:
      Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
      11-19-2022, 09:41 AM
    • perzyk23
      Lenovo T580 - LCD Panel problem - error 0288
      by perzyk23
      Good morning,
      I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
      10-25-2024, 12:42 AM
    • lazaro.089
      Asus Zephyrus M16 / GU603ZW problem
      by lazaro.089
      Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
      CPU: Core i9-12900H
      Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
      Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
      The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
      08-26-2025, 06:33 PM
